G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT
Page: Previous  1, 2
marco_lh
marco_lh is offline
PostPosted: Sun Nov 17, 2024 6:27 am    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
jimf909 wrote:
Wow! That's impressive.
This is where the challenge began !
I figured the challenge began a few years earlier, like where you were trying to build the adapter to achieve .003 tolerance. Laughing
Superb.
What would you recommend as for the alignment tolerance?
I couldn't find any handbook literature on the alignment requirement, only discussions on forums, so I referred what seemed logical. It was also in-line with what I learned at school regarding motor coupling adjustment.
It was actually pretty easy to achieve. I attached the transaxle with an engine block, no clutch or flywheel. The assembly was put vertically not to influence the dial gauge reading. I then attached the dial gauge on the input shaft and adjust the relative position of the adapter layers until I reached the desired alignment. The adapter was designed with a series of screws to clamp the layers together.
jimf909
jimf909 is offline
PostPosted: Sun Nov 17, 2024 7:50 am    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
I don't have a recommendation because what you did is well beyond my practical experience. The point I was trying to make is that I would have found that task alone to be quite a challenge yet you cleared the hurdle relatively easily. Also, when I read that you needed to align the parts to achieve a max .003 tolerance my brain started going through exactly where the play would be (I assume it's the play in the mating splines) and what would be the detriment of not being w/in your defined spec (load on the bearings?) which led me to possibly understanding the nature of the challenge at this stage which sounded challenging to me.
Thanks again for posting. You gave me some things to mull over when contemplating how quality is achieved.
- Jim
Butcher wrote:
Guilty as charged.
DanHoug
DanHoug is offline
PostPosted: Sun Nov 17, 2024 8:53 am    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
the Ghost of Phaedrus walks alongside many in this forum....
-dan
www.thefixitworkshop.com
inhabor
inhabor is offline
PostPosted: Sun Nov 17, 2024 4:28 pm    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
ml
Great project. I had the same problem with my adapters the first time I drove the bus. There was grease everywhere. I solved the problem with a little bit of great stuff.
marco_lh
marco_lh is offline
PostPosted: Mon Nov 18, 2024 5:46 am    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
Yeah I had to add some Gasket maker too, but it was not enough let alone without the added plastic protector. I guess you have really great stuff Very Happy !
If I was to provide complete kits to customers, even with my new design I'd die-cut some thin star shaped gasket that also covers the head of the m10 screws to avoid grease spillage....
Or supply T4 CV joint just as @Alika suggests!
By the way, thank you Alika for your comments. Did you actually buy or test the T4 CV joint on a T3 shaft?
His alternative would tremendously simplify the spacer and would prevent any of this !
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon Nov 18, 2024 8:35 am    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
of course, I did it back in 2009. Can't find GKN cv's anymore though, only cheap brands like Meyle.
uberaudi
uberaudi is offline
PostPosted: Mon Nov 18, 2024 12:12 pm    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
This is a great thread...thanks for documenting all you have done. With 996 transaxles being sub 1k, this is a very viable option to consider for those looking to rebuild their stock trans. I know I am!
'84 Adventurewagen 1Z TDI, '08 Audi Avant Quattro 6spd BHW TDI
GreggK
GreggK is offline
PostPosted: Mon Nov 18, 2024 8:01 pm    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
I love seeing this level of smarts.
'86 2wd Poptop transplant
FAS TDi engine swap. Peloquin LSD
https://www.thesamba.com/vw/forum/viewtopic.php?t=692188&highlight=slow+but+steady
tdivan82 Premium Member
tdivan82 is offline
PostPosted: Tue Nov 19, 2024 8:34 am    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
Wellington wrote:
Amazing.
My first thoughts were the TDI would not develop the HP required for the 996 transmission,
For a transmission, it's torque that matters. A tuned 1.9 liter TDI can actually put out MORE torque than a stock Porsche 996. Very Happy
marco_lh wrote:
I'll be adding a ground strap directly from the starter. It's a good idea. I can't believe I did not think of it before!
I just did this job myself, some photos near the bottom of page 1 in this thread.
- George
'82 Westy TDI (ahu)
'96 Passat TDI
vanis13
vanis13 is offline
PostPosted: Tue Nov 19, 2024 8:43 am    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
tdivan82 wrote:
Wellington wrote:
Amazing.
to link to a SPECIFIC post in a discussion, click on the "page" icon right in front of the word "Posted" in the post header. It will open up as a link to that specific post in the discussion. Then you can copy/paste that address to link to -
https://www.thesamba.com/vw/forum/viewtopic.php?p=10304753#10304753
tdivan82 is offline
PostPosted: Tue Nov 19, 2024 9:02 am    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
A ha, I was looking for how to do that but missed the tiny little icon! Thank you.
- George
'82 Westy TDI (ahu)
'96 Passat TDI
WillDahThrill
WillDahThrill is offline
PostPosted: Wed Dec 11, 2024 12:14 pm    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
Amazing job! And I'm so happy to stumble across this thread.
Glad to hear that you are open to making this an open source project. I wonder if you have thought any further about how to document this to make the process a little easier for folks like me trying to decide on tackling a project like this. I would love a step by step kit with instructions, but of course that's going to be out of reach at least at this point in the project.
I think to start, a parts list is needed and should include alternatives with pros and cons if possible. Some people will have different engines, different mounting angles, different junk yard parts available, etc...
I'm sure you did a ton of research and it would be good to get some more of your conclusions documented in the thread. Do you have a list of transmission codes for example?
Someone else mentioned these are sub-$1000 transmissions...wondering how to source one since what I see on marketplace right now for $2k is on that needs a rebuild already.
For example, I have an ALH mTDI mounted upright (not slanted over at 50 degrees or whatever it is). It would be good to have an additional adapter drawing for that. I'm also in a '72 so not the Vanagon...please don't kick me out because of that Embarassed
For Axles, you made spacers in order to reuse existing axles. Are there other/better options if buying new?
For shifters, i like that you have CAD designs you've shared! I've also read that the boxster shift cables can work? Ultimate Engineering is also an option i believe.
I'm coming from an 010 Auto trans so I'll need a full clutch setup too. What is the right flywheel. I think I need to get the original bus clutch pedal and linkage...wondering what else though.
Looking forward to seeing this develop further as a project and hope to contribute some day by doing the conversion myself!
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Dec 11, 2024 1:40 pm    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
Laughing
These are big $$ transmissions. I have a 911 that I'm working with now and the trans is 10k for a basic rebuild and a 5k core
and same thing, a 3k 911 trans is a core what doesn't have a hole thru the side of it
I mean, what's being proposed here is in the realm of syncro $$
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
marco_lh
marco_lh is offline
PostPosted: Thu Dec 12, 2024 6:38 am    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
Back in 2018 when I bought mine, they were selling around 1500$ CAD.
I just checked this morning and there are a couple options for Non rebuilt transaxles under 65K miles between 2K ~ 2.5K$ USD. This is for the Non turbo 996 version.
WillDahThrill
PostPosted: Thu Dec 12, 2024 1:02 pm    Post subject: Re: G96.31 transaxle adapter kit to TDI @ 50º - OPEN SOURCE PROJECT Reply with quote
dang so $2k for an LSD with 176k miles that pops out of 6th might actually be a decent deal?
According to a blog post on FCP Euro (link below), "the .01 and .31 boxes grew two inches at the tail. Gearbox mounting stayed the same, but the driveshaft on the C4 models was shortened by two inches to accommodate the longer case."
I wonder if you had any issues with these specific changes and if a different gearbox would be more ideal...any comment on that?
https://www.fcpeuro.com/blog/the-definitive-guide-to-porsche-996-transmissions
also info on the 997 trannies:
https://www.fcpeuro.com/blog/the-definitive-guide-to-porsche-997-transmissions
Page: Previous  1, 2
Page 2 of 2
