Painting/Sanding inside the HOOD vents.
talljordan
talljordan is offline
PostPosted: Thu Nov 21, 2024 8:10 pm    Post subject: Painting/Sanding inside the HOOD vents. Reply with quote
Hey all,
As you can see my painter did a very poor job of painting inside the hoods front fresh air intake vent, seems he painted right overtop some existing dust. Now I am left to pick up the pieces.
Any suggestions as to how I might rectify this?
1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end
jitbba
jitbba is offline
PostPosted: Fri Nov 22, 2024 8:32 am    Post subject: Re: Painting/Sanding inside the HOOD vents. Reply with quote
You'll need to fashion some sort of "tool" with sandpaper to get between and under. I forget the ease of access, but can you get to that area with the hood open and reach it from the backside?
My other ride is a Zildjian
talljordan
PostPosted: Fri Nov 22, 2024 11:34 am    Post subject: Re: Painting/Sanding inside the HOOD vents. Reply with quote
Yes, I can access from the back side to sand.
Definitely more worried about the painting process Sad
Kafer_Mike
Kafer_Mike is offline
PostPosted: Fri Nov 22, 2024 11:51 am    Post subject: Re: Painting/Sanding inside the HOOD vents. Reply with quote
You mask the hood and vent ribs, then dust through the vents with several light coats of paint. It will take a bit to cover that way, but better than blasting paint in there and having it run. You usually do that area first before painting the entire hood -- same as the vents in the rear of the car.
Kafer_Mike
Build 'em fast...or let 'em sit.
jitbba
jitbba is offline
PostPosted: Fri Nov 22, 2024 1:04 pm    Post subject: Re: Painting/Sanding inside the HOOD vents. Reply with quote
On your first pass of color, ignore the vents and paint as though they are not there. On the second pass, slightly angle the gun to be parallel with the inside metal. As previously noted, do not TRY to get the paint in there as you'll most likely cause a run with too much buildup.
67ctbug
67ctbug is offline
PostPosted: Fri Nov 22, 2024 7:59 pm    Post subject: Re: Painting/Sanding inside the HOOD vents. Reply with quote
Yup, I have painted the vents on the back of the car separate and then done the rest of the car and let the over spray land.
'67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
talljordan
PostPosted: Fri Nov 22, 2024 8:49 pm    Post subject: Re: Painting/Sanding inside the HOOD vents. Reply with quote
Ill give it a shot. Unfortunately I plan to spray the colour with those shitty "preval" cannisters. We will see how it goes.
Worst case I guess I re-sand and do it over with a real gun
Prawnabie
Prawnabie is offline
PostPosted: Sun Jan 19, 2025 10:43 am    Post subject: Re: Painting/Sanding inside the HOOD vents. Reply with quote
I removed the base panel from in the engine bay to do mine, then fixed it back in with rivets and structural panel adhesive after painting.
