xflyer Samba Member
Posted: Fri Jul 07, 2023 5:59 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
wherbusche, Best to know what year the Vanagons are as there are different relay wiring(s) and relays on some of them. _________________ 1989 Campmobile, 1984 7 passenger beater Vanagon
Both with cool A/C |
Busfixer Samba Member
Joined: March 13, 2016 Posts: 56 Location: Midland, Texas
Posted: Tue Dec 03, 2024 3:38 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
Help! I almost have the wiring bypass built but ran into a snag. When testing the diodes pictured below (50V, 10A), I cannot get voltage to flow through either diode regardless of orientation. 12.8V flows through my test leads hooked in series to my volt/ohm meter, but it quickly drops to 0V when I insert either diode in series. Am I doing something wrong or are these diodes bad? I must admit that I am a rank amateur in the electrical category.
Puzzled, Busfixer
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5964 Location: Bemidji, MN
Posted: Tue Dec 03, 2024 3:43 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
Digikey RARELY makes a mistake but those are NOT diodes!!! those are capacitors. here's what that part number should look like:
_________________ -dan
www.thefixitworkshop.com |
jlrftype7 Samba Member
Posted: Tue Dec 03, 2024 3:46 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
| Busfixer wrote: |
Puzzled, Busfixer
Does your Meter have a Diode testing position on its dial? Not all do, but, so many do that I need to ask.
It will look like an Arrow, with a line drawn across the arrow.
Here's a Fluke Meter as an example, the Diode test is one to the right of the Middle/Top OHM symbol, like 1 o'clock on the dial.
S:Paid:MS:CSM-2295:YF1CA5:20501201:APZ_1&gclid=7c2e0a20f8cb1aa6c3716d6f729eac6" target="_blank">https://www.grainger.com/product/4EB18?gucid=N:N ...d6f729eac6 _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
tjet Samba Member
Posted: Tue Dec 03, 2024 7:48 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
Thanks Dan, jlr and TJet - I believe Dan is right and these electrical components are capacitors. Dan, when I put them in series as described previously, they would show 6V, 3V, 1V then 0V, allin about 1-1/2 seconds. 0V steady after that. So your recognition of them being a capacitor combined with the quick voltage falloff to0V sounds like you are correct. I will call DigiKey tomorrow. JLR, attached below is a pic of my fine Harbor Freight multimeter in the Diode test position and it reads “1”. Apparently this means no flow. Confirms capacitor idea. Thanks for teaching me that function. TJet, if I don’t get satisfaction from DigiKey, then I may go your route. Thanks for the links.
Thanks again to all - I love the Samba! Busfixer
Posted: Wed Dec 04, 2024 6:46 am Post subject: Re: dead van diagnostic tools, wiring bypass |
DigiKey is 80 miles from my house... a company of over 5,000 employees in a town of 8,800!! 3 million sq ft. i've been ordering from them for 40 years and have never had a wrong order but mistakes happen.
frustratingly, before Amazon and DeJoy ruined the USPS, i could order parts in the afternoon and have them in my mailbox by 10am next day for $2.99 USPS 1st Class shipping. now it takes a week to get here and has pretty much circumnavigated the state of Minnesota before arrival. _________________ -dan
Backtotheeightiesagain Samba Member
Posted: Fri Dec 06, 2024 5:52 am Post subject: Re: dead van diagnostic tools, wiring bypass |
There is an emergency bolt on box that fires random sparks into the distributor.
Not seen another one and there is nothing on the Internet about it. Just connect to 12v and King lead. In cap.
Useful diagnostic tool bypass the distributor.
Unfortunately no one makes it now |
Posted: Sat Dec 21, 2024 12:57 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
Follow-up: I finally received the correct diodes from digi-jet and built the diagnostic wiring harness. I added an optional short lead in case I wanted to power the harness from the alternator stud instead of the positive battery post.
I originally built the harness to diagnose a hard shutdown problem at highway speeds. While I was waiting on DigiJet diodes, I replaced the original ignition switch, changed coil power tap on fuse panel from D15 to D23, and cleaned several relay, coil and distributor connections on 2 yr old parts. The problem disappeared.
But I now feel a lot better having the diagnostic harness in my 88 Bus wherever I go.
Another issue will pop up at some point in the future and the harness is ready!
Thanks, Busfixer |
do.dah Samba Member
Joined: August 27, 2015 Posts: 869 Location: Washington
Posted: Sat Dec 21, 2024 1:02 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
If you have it,, you won't need it!!
The inverse; If you don't have it, you're gonna need it, REALLY REALLY BAD!! |
Posted: Sat Dec 21, 2024 1:37 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
those diodes can break pretty easily so cut a section of chopstick longer than the leads and wrap electrical tape around the whole mess to bind them to the chopstick support. _________________ -dan
Posted: Sat Dec 21, 2024 3:48 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
Dan I was going to wrap the diodes with electric tape but thought the reason they were bare in previous photos was that they get hot. How about a popsicle stick and electrical tape?
Busfixer |
Posted: Sat Dec 21, 2024 4:28 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
| Busfixer wrote: |
Busfixer |
you've got 2 - 10 amps diodes in parallel... 20 amps of service for something drawing less than 10 amps so you'll be fine with them wrapped in tape. popsicle sticks are fine as long as it was grape flavor. _________________ -dan
reevesme Samba Member
Posted: Tue May 13, 2025 2:28 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
Your device helped me to fix my vanagon today. Thank you, thank you, thank you!!!!
83.5 with a 2.1L engine (replacement) and digijet ignition system. Was having a hot start issue that could have cancelled our trip to Moab.
Coil wasn't get enough current. DIsconnected the fuel pump jumpers first, then the coil feed. Then it would not start again. Reconnected the coil feed; boom fired like a champ.
Thank you, thank you, thank you!!!! |
tjet Samba Member
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 4710 Location: United States, Iowa
Posted: Wed Oct 22, 2025 6:15 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
I've been posting in the topic Stupid and Lazy, but I've completed the full test harness and now have some dialogue that direct me here for further reflection and advice.
I hooked up all connections as in the original post. I then pulled out of the garage, and let the bus idle while dealing with a few Family matters outside of my VW realm. Around 18 minutes of idling the engine stalled, and I felt around the engine compartment for hot spots. The coil was warm, not hot. Everything else was either cool, or about the same temp at the engine case. On key to start, it fired up immediately, so I went back in the house, but as I closed the door, my wife said 'it just died again' because she can hear much better than me. So again I went out and keyed it to start, again success on running. For a few times over the next 10 minutes, it cut, I restarted without switching off the power to the test harness.
I pulled it back into the garage and cut power to the test harness to shut down. Thus, I am hopeful that this entry to Mark's topic can lead to the resolution.
Thank you, one and all.
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Thu Oct 23, 2025 4:15 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
87 Westy riddle might be solved by one or more of the following: cleaned grounds, tightened (more) all connectors to the coil AND temporarily hung my new-in-box lifetime warranty coil (same as the one in place) and like magic, no hiccups whatsoever on my commute home today.
Pie in face, I guess..
Good results I likely should have tried the first day it started getting under my skin.
Still glad to have built and used the test harness!!
Posted: Thu Oct 23, 2025 4:22 pm Post subject: Re: dead van diagnostic tools, wiring bypass |
| bobbyblack wrote: |
| I've been posting in the topic Stupid and Lazy, but I've completed the full test harness and now have some dialogue that direct me here for further reflection and advice. |
coupla things... it would be helpful to describe *exactly* how the engine dies. does it bobble and bibble then snuff out? just a dead cutoff?
you need to know if it is fuel or spark. to that end, put a timing light on the coil wire and observe the flash during death. is it erratic? solid flashing even when the engine is dying? you are looking for the flash presence in the 1/2 second between the start of engine death and rotation stop.
it would be useful to observe fuel pressure during death also. something like a plugged charcoal canister may trigger a low fuel pressure just as the engine dies. or just try idling while the gas cap is loose.
it would also be good to observe a noid lamp during the death spin down. to give a little more time for observation, wedge some cardboard in the throttle to get the idle speed up to around 2000 rpm.
these data points, IF observable, will give you a sense of whether it is the Hall, the ECU, the coil, or a fuel issue during the death rattle. in short, you need to be with the patient at their last breathing moment and not duck into the house for a cold one!
at least it is repeatable! _________________ -dan
