thom Samba Member
Joined: October 12, 2000 Posts: 6141 Location: Sacramento
Posted: Wed Dec 04, 2024 1:45 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
I was able to fit 335/80R20 on the back of my single cab
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
AS350driver  Samba Member
Joined: April 17, 2016 Posts: 1346 Location: The Heart of Dixie
Posted: Thu Dec 05, 2024 11:05 am Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
thom wrote: |
And they even fit with no hacking of the fender wells! |
70bus  Samba Member
Posted: Thu Dec 05, 2024 11:22 am Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
You can prolly fit the s/c on the back of the Unimog with no hacking. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater |
AKdude Samba Member
Joined: May 16, 2016 Posts: 46 Location: The Far North
Posted: Tue Dec 17, 2024 8:48 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
215 75 15 KO2'S fit fine, no rub, 1/2" taller than the 205 75 15 Grabbers, and a heavier and straighter sidewall. Will try at 40psi and air down as needed for off road. |
Squilly Samba Member
Joined: March 01, 2011 Posts: 168 Location: CO <-> CA
Posted: Wed Dec 18, 2024 1:31 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
I've had the 215/75/r15 BFG KO2s on my both my buses for a few years now and have mostly good things to say about them. Haven't had any issues with rubbing and the wear is what I would expect on both of them.
I agree that around 40psi seems to be a good pressure to run. Although they can handle way more the ride just become super harsh. Aired down they have tons of grip on every surface aside from mud.
However, they're pretty heavy when compared to other tires - 32lbs. I do wonder about adding that unsprung weight to the bus and it's impact on the lifetime of the reduction boxes, trans, and brakes. Acceleration and brake performance is obviously reduced with heavier tires, but it's not like buses with these on them are set up to be high-performance anyway...
I haven't seen enough wear on the other parts to switch yet and the KO2s just look awesome. If I were starting over I might look at the Falken Wildpeak AT4W (heavier though at 38lbs ) or Toyo Open Country (28lbs). Grabbers still seem like the best to me for a 14" setup.
Wade Samba Member
Joined: February 13, 2007 Posts: 128 Location: NorCal
Posted: Wed Dec 18, 2024 2:27 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Here is my '56 with the Coker Firestone 6.70 bias plys. I wouldn't exactly call them "meats" but they are a bit larger than normal.
I love the tall look, and also the sturdiness of these tires. They drive really well. No flexing.
-Wade
AKdude Samba Member
Posted: Thu Dec 26, 2024 11:41 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Oh gorgeous patina queens...and capable! Perfect. 40psi it is then. |
Malokin Martin Samba Member
Posted: Mon May 26, 2025 11:59 am Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
So I decided to take the Pepsi challenge.
These are both in flat lip 15 inch rim bus’ with stock suspension
1.) Wildpeak A/T 215/75 R15:
The tread is a little less aggressive, but surprisingly they make a little more noise. Not super loud, but a bit. The great part is they’re “D rated” up to 2095lbs, so for a camper they’re working really well. They fit nicely but do rub if I make an aggressive full turn at full lock, but that’s only happened twice in 2 years and it’s been minimal.
2.) BF Goodrich AT 215/75 R15:
I really like the look of the tread on these. They’re “C rated” up to 1765. Not loud at all, but that could be a function they’re on the pick-up truck. I think I’ve had them rub once at full turn and full lock, but that’s only happened once in 2 years and it’s been minimal.
Overall im happy with them both. |
70bus  Samba Member
Posted: Mon May 26, 2025 1:10 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
What PSI on the truck? How's the ride at that pressure? _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
