tim3 Samba Member
Joined: February 01, 2004 Posts: 558 Location: Los Angeles, CA
Posted: Wed Dec 04, 2024 12:08 am Post subject: Lets be clear about Lowering and BMW E30 Springs thread |
Ok so I finally got a 412. 1974 4-door. I read through all the lowering techniques. Yes I know the issues.. its clear but what isnt clear is how much drop the regular BMW E30 springs vs the BMW E30 M3 springs drop front of the car. I can find regular BMW E30 springs on ebay but the only M3 versions I can find are aftermarket and lower an E30 M3 an additional 0.25".. i would appreciate a clear answer on my question not some long winded explanation that doesnt answer my question. Ive searched high and low for the difference in drop height and how much of an overall drop BMW E30 springs achieve but all Im finding is vague info that devolves into a discussion about all the stupid issues these cars have. I get it.. but im here to get a clear answer about this question and yes I'll also do all the other stuff with the struts/bushings/ect. But please can someone just tell me how much E30 and E30 M3 springs drop the car (not just it levels it or tangets about spring rates, strut rebound, hitting bumps, bushings, strut bearings, audi struts, or w/e stuff that doesnt answer this question above)
Thanks in advance
_________________ Click to view image |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23553 Location: Oklahoma City
Posted: Wed Dec 04, 2024 9:58 am Post subject: Re: Lets be clear about Lowering and BMW E30 Springs thread |
Sigh.....
You want a simple and quick answer?...not one person on this planet knows.
Springs have very little to do with ride height in a MacPherson strut unit. In fact....they have virtually nothing to do with it.
All of that stuff that you have no interest in....makes all the difference. Shorter springs simply FIT the RANGE differences you make with the bushings, spacers and strut rod.
These rules apply for super beetle and type 4 only.....simply because we have very little weight in the front end.
Struts will extend to the telescopic range of the strut rod when the wheels are just lifted off the ground. That is your max limit. Then....you will get a SMALL amount of combined rod and spring compression when the wheels are back on the ground and the weight of the vehicle is on it.
You want to lower this at rest height some more?....well....put softer springs on it and it will droop lower at rest.
So why can't you just do that witha shorter spring instead of a softer one?.....because if the spring is just a smidgen too short....and you go over a bump where the wheel leaves the ground....the strut rod extends fully....and the spring comes unseated and drops sideways. If you are lucky it just bends the lower spring perch. If you are turning when this happens....it gets hooked on the center and bends the fender.....been there and done that. It's how I know.
Strut springs for a street car need to be progressive. Soft area for compression for setting height....and heavier springs in the lower section for load control.
If you want to use some other spring...either stiffer or softer....that's fine but your main work is going to be adjusting the extended rod height to get the maximum range FIRST....and then testing your springs to get the kind of at rest stance you want along with proper compression and rebound action (a chunk of that is also valving).
It's not simple and it's not about just slamming in a set of "lowering springs". This is neither torsion bar or trailing wishbone suspension where you can get away with that.
However, the rear suspension is like that. You can use some lowering springs in the back and get an immediate result. However, you still have to be sure that your shock total extended length is not now too long because if you drive over a huge bump and the tire leaves the ground you can unseat the spring.
How much drop for BMW E30 springs? Who knows. No one does because its not JUST the springs that allow or cause the drop.
There is maybe one guy who could tell you from about 6-7 year back (Greg?)....and I can tell you from following what he did.....it's the whole combination and not just the springs.
For the most part you can get ~1.5" drop just with the stock springs (which are excellent by the way)...simply by installing the Audi cartridge mod and adjusting your bump stop spacers. This is also about 200% better handling with this combo.
Visually, on the front end a 412....the appearance of a 1.0" drop looks very much like 2.0"+...because it lifts the rear, pivoting around the rear axle and causes the control arms to "squat". This brings the fender wells past the lip of the tire and the rail edge of the rocker panel down past parallel with the ground (slightly) towards the front.
There is no simple method for lowering a 412. While the actual work is very easy.....it's a lot of trial and error....and....4 out of 5 things you try can either make for poor handling and ride or actually damage something at the extremes (like your ball joints).
Nice looking car! If someone tells you they have a simple or concise answer as to how much ANY set of springs will drop your car.....and you have not told them the rest of the combo....or they have not dictated the whole combo along with said springs.....they are full of shit.
Ray |
tim3 Samba Member
Posted: Wed Dec 04, 2024 7:14 pm Post subject: Re: Lets be clear about Lowering and BMW E30 Springs thread |
This group kinda sucks. Its been nearly 20 years and not one of you can give an estimate how much a stock e30 spring will drop the front of the car vs a e30 m3 spring.. guess this is why no one really gives a shit about type 4s because the forum is full of the same fear mongering bullshit over and over again for 20 years.. we get it the suspension fucking sucks. I asked a simple question.. thanks for writing a fucking bible like you have for the past two decades. _________________ Click to view image |
Posted: Wed Dec 04, 2024 8:08 pm Post subject: Re: Lets be clear about Lowering and BMW E30 Springs thread |
| tim3 wrote: |
| This group kinda sucks. Its been nearly 20 years and not one of you can give an estimate how much a stock e30 spring will drop the front of the car vs a e30 m3 spring.. guess this is why no one really gives a shit about type 4s because the forum is full of the same fear mongering bullshit over and over again for 20 years.. we get it the suspension fucking sucks. I asked a simple question.. thanks for writing a fucking bible like you have for the past two decades. |
Hey...asshole....no one knows how much a BMW E30 spring drops a 411/412...because its not necessary for most minor drops to about 2" that are kind to the car and therefore no one does it.
Maybe 3 people have done it......AND...as I stated ...as someone with far more fucking experience with any type 4 than you have....unless you have done it and have the exact...COMPLETE combination and recipe.....no two set ups will drop it exactly the same even if you use the exact same springs.
Again....its NOT....NOT....NOT....NOT...about the springs. Its about the complete combination of strut rod length, springs and valving. Where did you somehow glom onto the idea that BMW springs are a requirement for lowering the suspension?
Did you read that in some book?
You act like its a must have....like we MUST drop the car...and we can only do it with BMW parts......
Here is something cool....why don't you tell us how much you need to lower your car....and we can probably tell you how to do it in the blink of an eye. No shit!
Are you just that young...or just that stupid?
If you want help, there is virtually nothing most of this group cannot accomplish with a type 4 and we would be glad to help.
However.....you sound like a complete dick.
Ray |
Posted: Sat Dec 07, 2024 6:02 pm Post subject: Re: Lets be clear about Lowering and BMW E30 Springs thread |
Just so you understand that I am not being a complete asshole….here is some data for you.
https://www.thesamba.com/vw/forum/viewtopic.php?t=764509 For reference, this is my thread on rebuilding struts specifically for the 1974 model 412 using the Audi cartridge mod
This lowering thread below is a good one and also has Bill K’s input. He was who I was thinking of when I said "Greg" in my last response.
He has done the BMW spring mod on his 411 and 412 IIRC and used to sell kits for it but that was in 2010.
Also contact Wally on the STF. His highly modified 412 has modified and lowered suspension. This was years ago. I know he is still on there but do not know if he still has his 411.
https://www.thesamba.com/vw/forum/viewtopic.php?p=7437142
The point I am going to make…again….is when these guys tell you how much the EXACT spring they used lowered their car….do yourself a favor and ask them what the TOTAL RECIPE is. What spring, what mount, what strut cartridge, brand and series, what spacing length for that cartridge, what spacers and shims are in the stack up….all of it…..because just knowing and using the springs will get you nowhere.
You will see this from the data in the links below.
Below is data from this BMW thread:
https://www.rtsauto.com/e30-stock-spring-options-and-spring-rates/
Looking at the BMW E30 data you will SEE why just getting the springs, no one can give you the simple answer you want.
First, WHICH BMW E30 spring are you using?
There are at least 4 with unloaded spring heights from 345mm to 305.7mm and each one of these has differing spring tension at normal full extension and at maximum complete, coil bind compression (which you would never do while driving).
So….while the Tallest BMW spring of 345mm is 40mm shorter than the 385mm of the shortest 411 spring, they are both tall enough to capture the stock upper and lower spring perches which are 282.6mm apart.
See the point I am making?
Just being 40mm shorter than the shortest stock 411 spring with the S704 M series spring, or even 80mm shorter than the shortest stock 411 spring ….if you are looking at the E30 M3 Evo-3 which is 305mm fully extended….both of those BMW springs will load into that 282.6mm of space on the standard 411/412 strut between the top plate and lower perch.
Without knowing how much difference in spring force each spring will have at that 282.6mm loaded height, you have no idea how much the weight of the car will compress that spring when just sitting…IF it compresses the spring at all.
How heavy is your car?
How much weight is commonly going to be in the trunk?
Are you using oil strut cartridges, low pressure gas or high pressure gas catridges?
The only way anyone can know how much any given BMW E30 spring will lower their 411/412 with no other changes to the strut at all….is to try them on and test .
Then, if you want to have actual operating struts… since new strut cartridges are unobtanium….you need to graft in another strut cartridge like we have done.
When you do that, it could have (or require) either the stock spacing in length between top plate and lower perch or you could lower or even raise the car while installing this new strut cartridge.
So, here is the data from that thread so you don’t have to click if you do not want to:
Front Springs:
S704 M sport suspension package (pre 09/87) 31331132742 with Pink dots:
Spring force = 3514 – 3686 Newton at Ln length 140 mm
Spring rate at upper/extended level: 26.328 N/mm or 150.336 lb per inch
M-tech suspension package (09/87+) 31331130054:
Spring force = 3426 – 3614 Newton at Ln length 126.5 mm
Spring rate at upper/extended level: 28.569 N/mm or 163.133 lb per inch
E30 M3 springs 31331130046:
Spring force = 3117-3283 Newton at Ln length 126.5 mm
Spring rate at upper/extended level: 25.952 N/mm or 148.189 lb per inch
E30 M3 Evo 3 springs 31332226781:
Spring force = 2970-3130 Newton at Ln length 116.5 mm
Spring rate at upper/extended level: 26.875 N/mm or 153.46 lb per inch
Overall heights in order (S704 not available, albeit overall longest of the 4):
NOTE: from a different source, BMW E30 for S704 “should be” 345mm
31332226781 (E30 M3 Evo 3)> Ln: 116.5 mm / Overall: 305.7 mm
31331130054 (Mtech) > Ln: 126.5 mm / Overall: 313 mm
31331130046 (E30 M3) Ln: 126.5 mm / Overall: 318 mm
Spring Rates in order- lowest to highest:
31331130046 (E30 M3) > 148.189 lb per inch
31331132742 (S704 M package) > 150.336 lb per inch
31332226781 (E30 M3 Evo 3)> 153.46 lb per inch
31331130054 (Mtech) > 163.133 lb per inch
The BMW spring mod is a good one. But most people who do not want to really lower any lower than flat and level….have no used it and probably do not need it. Its why you do not see much about it.
Just for a recap to what I have done....wth stock springs:
With some recent changes to my front mounts I have lowering.... of 1.25” using the Audi strut mod and an adapter bushing. I have a further 26mm of lowering just by having 205/55 -15’s on the car instead of the stock 185/75 tires that it had when I bought it.
That’s 2.25” of lowering using the stock spring plate spacing ( minus 1.25”) and low pressure gas struts with an adjusted adapter stub. It also has probably 15%-ish greater at rest spring load.
At this point I do not need to do anything to the rear end yet. Its barely noticeable that the front is slightly lower than the rear….but the front is significantly lower than a stock car.
With finally finding an answer for a NEW balljoint that these cars can use (yes, it takes a little fabricating...the how to is coming soon!)….this could easily bring an extra 0.75” drop in the blink of an eye if I want it. This would leave the front at 3” lower than stock.
At that point I will have to adjust the lower eye position on the rear shock by ¾”.
All of this…3” of lowering….without BMW springs.
And I have not even mentioned the Volvo spring mods that are out there. They are all worthwhile mods if done well.
But you are either going to have to buy a complete answer...meaning a finished "RECIPE" from someone like Bill K...or you will have to just buy some springs and start testing like I have done...Bill has done and Wally and others have done.
Just sayin….
Ray |
412STi Samba Member
Joined: September 25, 2015 Posts: 31 Location: Germany
Posted: Sun Dec 08, 2024 6:59 am Post subject: Re: Lets be clear about Lowering and BMW E30 Springs thread |
As Ray has already written,
there is no information or records for the many decades.
Someone who has lowered their car with BMW springs may have posted a photo somewhere at some point.
Unfortunately, I don't have a photo of mine.
It's been over 30 years since I did the conversion and the car has been dismantled for almost as long and has been in the process of being rebuilt for a few years.
What I can contribute is the following:
I installed springs from the E30 4-cylinder and my shock absorbers were shortened custom-made ones from Koni.
If you want to do this conversion, you should definitely only use the original 4-cylinder springs (316/318).
They work even if the rest is still original (old shock absorbers, etc.), without losing the preload when fully extended. (Better and safer with adapted dampers, though)
You shouldn't use the springs from the 6-cylinder, as they are designed for a heavier engine. And we don't have one in the front.
What I would also definitely not use are M3 or other sports suspension springs. These are even shorter than the original 4 cylinder springs and therefore have no preload at all.
No guarantee that all of this is still correct. I wrote it down more from memory.
Found some pictures on my PC
with BMW E30
with BMW E30
with E30 6Zyl.-Spring and Bilstein
E30 Spring
E30 Spring
@Ray
Wally sold his sedan to a Dutch friend (Joost) years ago. _________________ Gerold
The morning brings a mystery, the evening makes it history
The oil can not be, was none in it. |
Posted: Sun Dec 08, 2024 7:52 am Post subject: Re: Lets be clear about Lowering and BMW E30 Springs thread |
| 412STi wrote: |
@Ray
Wally sold his sedan to a Dutch friend (Joost) years ago. |
Hello Gerold! Thank you for the reply and pictures. At one time across the STF and maybe some other forums I have seen pictures of the black 412 Wagon and maybe the red one with the distinctive wheels.
Virtually all except for the beige 412 are not really lowered but are instead leveled or even slightly raised like the black one. But having the E30 Spring mod and the right damper/strut should greatly increase ride control and handling.
To an extent, a similar but probably smaller level of better/tighter control can be gained with the stock spring....IF.....you have also adjusted/modified the new strut cartridge height and used a cartridge with better valving than stock which again depends on which 411/412 spring you used/started with.
Each 411/412 spring is going to require a different set of internal spacers, bump stop etc....and because of how they are wound (and it varies considerably across the three families of 411/412 spring).....and from what I have seen, with stock springs, about 2" of lowering is about all you will safely get.....with good control because of the progressive nature of the spring.
Of course there are many things I have tried but also just as many that I have not tried. All of what I have put into the recipe I use....could be changed totally, simply by using a strut cartridge with different valving or going from gas to oil charged.....or really.....even just using the most progressive of the 411/412 springs (probably the middle years like mine) and flipping the spring over so the "load bearing" coils are against the chassis.
The really useful thing I have always commented on about the E30 springs are these things.
1. There are a wide range of them to play with
2. They are close enough to the correct/same diameter as the factory 411/412 springs to work.
But, as you noted in your reply, you made this happen with a modified full custom Koni strut cartridge. Kudos on that!
The cartridge itself....what the valving is (and it does not have to be exact to factory and probably should not be in my opinion) ....what the length is, can it be spaced/shimmed properly to fit and work and create the effect you need .....are the key to the operation.
Just like all other ACVW, restoring or working with the type 4 is subject to the tastes of its owner. All owners of 411 or 412 in recent history are buying cars that are already decades old with MANY miles on them.
The factory front "wet" strut cartridges ....while they are a marvel of design and give a nice soft ride, the vast majority or them you will find over the past 30-40 years.....are already dead.
If you want to drive the car at all, you have to replace them with SOMETHING. The average 411/412 owner is usually happy to be able to replace them with anything!
Pretty much the last aftermarket manufacturer of replacement strut cartridges to quit manufacturing these was KYB in ~1999. So anything you find is already 25 years old at best.
Those and other NOS oil filled cartridges (like BOGE, Sachs, Gabriel, Monroe and the rare Koni) can still be serviceable if they were stored properly.
But then you run into the problem/choice of "personal taste"
The original struts were very soft, too high in the front end and had not enough rebound valving. Most of those aftermarket strut brands mentioned above were nearly exact copies of the valving the factory used.
Among the personal tastes of owners.....the vast majority mostly just wish they could go down anytime to a local parts store and simply buy a replacement cartridge they could drop into the car that would work even if it were exactly like factory. Most of them are not even looking for "lowering". They just want the car to work and be safe. Even fewer want to lift the car.
However, those days of just being able to buy a factory level aftermarket cartridge have been gone since 1999.
If you drive your car a lot like I used to, just living off of the rare NOS replacement was not an answer. That is why I started looking for an answer many years ago.
Having driven various 411 or 412 cars since 1978 when I first started driving, the rough roads all over this country in areas I drove in....many times with 200+ pounds of cargo in the front trunk.....gave a short life that gave to the rebound damping of virtually all aftermarket strut cartridges....this indicated that whatever answer I found should have better damping if I could possibly manage it.
And at the same time, if whatever I found could also manage about a 0.75" to 1" drop....and get the nose level....that would be ideal.
No matter which answer your personal taste drives you to.....stock, improved stock, lowered or raised....the object you should be working for alongside that height and handling preference is to find a common, high quality replacement cartridge that you can replace at any time without excessive $$$ or long searching.
And, the length, diameter, valving and spacing of whatever cartridge you decide on will be the PRIMARY key to what your final height and handling is no matter what spring you choose to build the strut around.
Ray |
ubercrap Samba Moderator
Joined: July 01, 2004 Posts: 1068 Location: Ridley Park, PA
Posted: Sat May 10, 2025 6:39 pm Post subject: Re: Lets be clear about Lowering and BMW E30 Springs thread |
Bilstein made a run of strut cartridges in the last few years, but they were also like ~$500 for a pair or something. Probably worth it for a highly original setup. In Germany and other places, you can't just put random stuff together, no matter how cleverly done, like we can- probably the reason these were made again.
Ok, here you go, you can get them still:
https://www.bmptuning.com/products/34-000311?srslt...6cVpVuN5Ed _________________ '74 412 wagon
(2) '74 412 2dr. sedan
'73 412 2dr. sedan |
Posted: Sun May 11, 2025 11:00 am Post subject: Re: Lets be clear about Lowering and BMW E30 Springs thread |
| ubercrap wrote: |
https://www.bmptuning.com/products/34-000311?srslt...6cVpVuN5Ed |
There is at least one person on this forum that has used these. I never quite got a "how are they" review.
They may do quite well and be similar to the Audi cartridge in valvig as they are listed as Bilstein "B-6" cartridge. These are rated a little bit above stock valving.
In fact...I would say by my experience, they are very similar to stock valving but with higher load capacity (stiffness).
My only experience with a B6 rated Bilstein were the set I put on the rear of my Golf mk6 back in about 2017. On smooth normal pavement they were just like stock. When I loaded the hatch/trunk....they handled it better and were still smooth and level. But when unloaded and going over sharp bumps....they were a bit too hard.
Some notes from Bilsteins site:
The B4 spec: (stock)
| Quote: |
| Mustafa Yavuz from Technical Support at BILSTEIN knows his stuff. Every day, the master mechanic helps with questions about suspension and shock absorber technology, advises independent workshops and car drivers. “In most cases, our BILSTEIN B4 OE replacement shock absorber is the right choice”, says Yavuz. “If the customer was satisfied with the driving characteristics of the intact OE suspension, then the B4 is exactly the right shock absorber for them. After all, it restores the optimal driving experience, just like on the first day.” This shock absorber offers the highest OE quality and has a high market coverage and availability, so workshops cannot go too wrong with it. |
The B6 spec: (stock +)
| Quote: |
| The BILSTEIN B6 shock absorber offers higher performance reserves for a variety of demanding everyday situations. With its special damper setting, it is particularly suitable for vehicles that are often heavily loaded, for trailer operation (caravans) or for vehicles with a gas tank. The use of BILSTEIN B6 shock absorbers is also recommended for external loads such as a bicycle carrier with heavy e-bikes. This is because the additional weight in the rear area greatly increases the drawbar load acting on the rear axle, which impairs driving stability. But even dynamic drivers benefit from the improved driving characteristics. A particular advantage is that an additional spring change is not necessary. Since 2022, there has also been a special product line, BILSTEIN B6 Camper and B6 Camper Advanced, especially for campervans. |
Ray |
whobba Samba Member
