Heater Channel Baffles
Fun With VDubs
Fun With VDubs is offline
PostPosted: Fri Dec 13, 2024 3:20 am    Post subject: Heater Channel Baffles Reply with quote
Looking through the ankle vents and down the defroster tube openings I notice there are baffles directing the air through the heater channels. How far rearward do they extend from the defroster tubes? The reason I ask is that I'm installing a diesel heater up front and am running the hot air in the opposite direction through the channels. I'd like to cut a pair of new vents into the channel just behind the front seats.
Swing on over to our YouTube channel. There we post work we're doing on our VWs, and the adventures we take them on.
@FunWithVDubs
View user's profile Send private message Send e-mail YouTube Gallery Classifieds Feedback
aquifer Premium Member
aquifer is offline
PostPosted: Fri Dec 13, 2024 6:06 am    Post subject: Re: Heater Channel Baffles Reply with quote
I’m 63% sure that the heated air runs in a metal tube inside what is always called the heater channels. That may not be true for aftermarket “heater channels”, but when I restored my first 67, I had to repair a rust hole in the bottom of the driver side channel, and I could see inside there. I was surprised to learn that there is a tube inside the channel that is actually where the air goes.
Maybe what I remember seeing was just part of the short tube that directs air to the heater channel from under the back seat, and doesn’t actually run the whole way forward. The rust hole was toward the back of the heater channel, so it’s possible that’s what I remember seeing. It’s been 25-30 years ago, which is why I’m not 100% sure!
Someone here will know for sure. You might edit your post to show what year your car is. Maybe VW did it different over time.
Project vehicles:
1967 Beetle #1. Bought in 2024, mostly original, October 1966 build date. Java Green.
1967 Beetle #2. Bought in the mid 80's, restored myself in the late 90's, June 1967 build date. Java Green.
1998 Jaguar XJR. Bought in 2015, rust free AZ car, refurbished myself. Driven in nice weather.
Parts needed:
Original brown rubber floor mats for a '67
Original gazelle seat upholstery for a ‘67
finster
finster is offline
PostPosted: Fri Dec 13, 2024 8:17 am    Post subject: Re: Heater Channel Baffles Reply with quote
see this thread - https://www.thesamba.com/vw/forum/viewtopic.php?p=9990308
the inner tube runs from the rear inlet to the front
you will have trouble feeding anything into it - if you remove the bottom plate then you can replace the inner heater tubes - this guy used 2" dia galvanised tubing
Fun With VDubs
PostPosted: Fri Dec 13, 2024 8:20 am    Post subject: Re: Heater Channel Baffles Reply with quote
Right you are about me needing to specify the year, it's a 1960. I did notice that our '70 Beetle does have round tubes running through the heater channels. I guess I should ask; in the earlier years did they have these separate heating tubes?
@FunWithVDubs
67rustavenger
67rustavenger is offline
PostPosted: Fri Dec 13, 2024 9:06 am    Post subject: Re: Heater Channel Baffles Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=493257
The thread above is a heater channel replacement on a 60 Cabriolet.
It should be the same for your 60 sedan. Scroll down and you can see the remnants of the rusted out inner heat transfer tube.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
finster
finster is offline
PostPosted: Fri Dec 13, 2024 9:12 am    Post subject: Re: Heater Channel Baffles Reply with quote
dec 56 was the introduction of the inner heater tubes
