What did you do to your Bug Today?
Page: Previous  1, 2, 3 ... 454, 455, 456, 457, 458  Next
Cusser
Cusser is offline
PostPosted: Mon Jan 06, 2025 3:42 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
Cusser wrote:
The used regulator I'd purchased through Samba seller Brian Hawkins looks like it will fit fine, was from a 1978 convertible; the spring location (spring broke/is AWOL on mine) is different, VW likely moved that for a good technical reason.
Anyway, today I was able to remove the driver door window regulator using the magazine article as a guide. I also removed the vent window assembly as I have a few parts on order to fix some of its stuff, like the latch; so I did not complete the repair today.
Success ! Installed the used driver door window regulator, new rubber for the vent window, new vent window latch. This was pretty involved, the articles from Hot VWs in early 1996 helped the most.
I've updated my 1971 Super thread on this with photos https://www.thesamba.com/vw/forum/viewtopic.php?p=10329484#10329484
Chinaclipper
Chinaclipper is offline
PostPosted: Wed Jan 08, 2025 12:54 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
This weekend, I replaced my rear shocks on the 1971 super. I have no idea how old they were, but I'm just gonna guess that they were more than a few years old.
The old ones weren't too difficult to remove. I had my trusty air tools.
The bolts and nuts were nasty. I replaced all the nuts and washers and cleaned up the bolts.
I also replaced a lens on my front fender. I REALLY want to keep the Hella lenses. Is there anyone out there who maybe has had any luck trying to re-stain or rejuvenate the faded Hella lenses?
China Clippers Official 1971 Super Beetle Project!
https://www.thesamba.com/vw/forum/viewtopic.php?t=728089&highlight=
Cusser
Cusser is offline
PostPosted: Wed Jan 08, 2025 5:13 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
This morning I replaced the right outer tie rod end on my 1971 Super. I also removed the control arms and had a shop press the old ones out, I tried using sockets and bench vise, but I felt I might break something or my body. I decided to use a shop to press these out rather than try a loaner tool or buying extractor kit.
Then I installed new urethane bushings into the arms using my bench vise, pretty straightforward. Hopefully tomorrow I'll re-install the control arms into the VW.
Rome
Rome is offline
PostPosted: Thu Jan 09, 2025 5:47 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
30 years ago I adapted '67 Beetle reverse lights with their clear glass lenses for auxiliary turn signal lights on an early Beetle. I cleaned off the inside surface of the lenses using a toothbrush and non-ammonia glass cleaner, set them outside in the sun to warm up, and applied 2 light coats of orange "candy" effect model paint from a hobby store. Worked out well. The candy paint is very thin so you really need to apply light "mist" coats instead of a usual heavier coat which will likely cause runs. You could use similar technique on your amber blinker lenses.
Cusser
Cusser is offline
PostPosted: Thu Jan 09, 2025 6:43 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
I got the front end completed on my 1971 Super today, with new bushings for control arm and sway bar; also new steering damper bushing and right tie rod end. Here: https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=40
stagewex
stagewex is offline
PostPosted: Sun Jan 12, 2025 6:34 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
When I first bought my '73 Super in 2021 the seller told me it had a slow drain on the battery from (he thought) an aftermarket car alarm. I've left that alarm in place because it is the same one my Dad had in his bug in 1971 and it actually works. Plus I didn't let the "drain" bother me because in driving the car on a regular basis it never ran down the battery.
So in almost 4 years now that has happened 3 times when left and not started in say 4-5 weeks.
Over the years I've found and corrected most of the butt connectors and bad wiring with soldering and upgraded connectors. If there is a bad ground or connectors someplace I have not found it yet.
About two weeks ago the battery was close to dead in my driveway so the usual PITA taking the rear seat out and hooking up the charger for a few hours. A few friends on mine that own vintage and antique cars suggested what they have, a charger/maintainer that they installed in their engine compartments.
Of course they can pop the hood and look at them. For me install would be under the rear seat but I do/did want to see status. So on recommendation bought this NOCO that was highly recommended:
When I went to install the negative lug on the battery came off without loosening it. I had put some fog lights on the car a month earlier. The lug bolts were tight but kinda crushed into itself. So that may have been why the battery was running down in the first place, who knows? I used some aluminum from a pie plate to help make a tighter bite:
That worked fine.
I installed facing out so I could see & monitor battery status. In the future I might flip it around so only the power cable is shown. But I was doing this outside in the cold so for now and it being not in the way, this was fine:
Put the seat back in:
And hooked-up to house power, My 52 year old beetle Tesla:
It only took a few hours for the only indicator light to start blinking Green indicating 75-85% charged. But it took almost 24 hours for it to read straight and stay Green. This charger de-sulfates the battery and that is a long process for a little 2amp version. But it will correct or fix anything on the battery if possible. Which is kinda amazing.
Just went thru a period of ultra cold weather where I didn't drive or start the car in about 12 days. Other than the finial install and charging on Dec. 17th it wasn't till yesterday that I turned the key and she came to life with all lights and other stuff showing brightness. I'm short of 100% recommending yet as the loose lug may have been the problem in the first place and also the only other times the battery ran down was several weeks of not being used. But my friends with this same charger ($39.00 on Amazon) swear by it and leave it "on" all the time on their cars. I just hated taking that seat out and back on.
I maintain six (6) motorcycles and do not Winterize them. I start and ride them at least once a month if not too cold or snowbound and am a diehard Deltran Battery Tender owner. But this NOCO brand is a step higher in my limited opinion than the BT 12V battery charger/maintainers I use on the bikes, snowblower and generator battery's. I'll come back to this posting after the Winter to offer a final "you should get this" as my friends and a huge amount of positive reviews indicate. What my hope is to NOT use it (plug it in) at all to see if in fact it did correct and maintain the battery from the get-go.
https://www.amazon.com/s?k=battery+charger+maintai..._sb_noss_1
BIGMIKEY
BIGMIKEY is offline
PostPosted: Wed Jan 22, 2025 2:18 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
I use an earlier version of the NOCO Genius. Been using it each winter storage. Pretty happy with it.
Mike T
BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue.
woodscavenger
woodscavenger is offline
PostPosted: Thu Jan 30, 2025 8:54 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
Found some local bumpers with override bars. Doing a rehab project and will retrofit them to my slammed bug.
1973 Beetle
55k miles.....sitting since 1988.
Complete re-do is in process.
Long-roofs
Long-roofs is offline
PostPosted: Tue Feb 04, 2025 4:03 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
Drove '77 sunroof standard around the yard in fresh snow.
Trying to keep poor cool
People are talking, the greatness is coming, going to be greater than great, so great, greater than anything ever.
vamram Premium Member
vamram is offline
PostPosted: Fri Feb 14, 2025 4:18 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
In my '73 Super, I adjusted and bled the brakes, completely flushing out the old brake fluid. Gotta say, gravity bleeding really works, followed by the motive pressure bleeder for the finish. Didn't even need a pedal pusher to help.
Click to view image
Save the Supers!!
Tridentine
Tridentine is offline
PostPosted: Mon Feb 17, 2025 6:48 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
Nada... waiting on parts. Darn thing will not start.
jinx758
jinx758 is offline
PostPosted: Mon Feb 17, 2025 2:27 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
@ Tridentine ...
Welcome !
Plz start a thread with symptoms & pics.
Lots of knowledge to help in here.
Best to you ...
stay safe
jinx
" It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor
baldessariclan
baldessariclan is offline
PostPosted: Wed Feb 26, 2025 8:05 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
Replaced the battery in my bug yesterday. The old one was beginning to get a bit weak when starting the car, especially during our recent cold snap last week.
That old one, which had come with the car when I first bought it about 10+ years back, had a date sticker with "8/13" on it. So evidently lasted 11+ years -- impressive! Smile
azimech49
azimech49 is offline
PostPosted: Wed Feb 26, 2025 8:12 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
Yesterday I installed bumpers, plate, headlights and foglights with their rock guards and the eyebrow
BCE56
BCE56 is offline
PostPosted: Sat Mar 01, 2025 6:38 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
Over the last few days (with some help from my friends):
Inst cluster to Speedo King for refurb and calibration.
Thanks, Steve!
Oil change, new valve cover gaskets, adjusted clutch and heat cables.
Set timing, new plugs, miscellaneous carb and choke adjustments.
Thanks, Carlos!
Significant improvement all around Cool
On to the next fiasco!
=BCE56=
'86 Syncro Tintop EJ22, OBD II SmallCar adapter plate conversion
'96 Volvo 850 Turbo
'69 Frankenbug now driven daily.
jinx758
jinx758 is offline
PostPosted: Sun Mar 09, 2025 6:52 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
So this really happened...
yesterday
Drove to grocery store (about 12miles) but filled up first.
No headlights afterwards.
Drove a half mile to O'Reilly's with parking ones only. Used flashlight & all fuses good. Used bent coat hanger to unscrew bezel - cassette/radio already removed last week.
The plastic "base" separated. Pushed it back together & lights came on.
Used 28ga bell wire to hold it. Got us home.
I always try & make do with bubble gum & duct tape.
Seems el cheapo switches will be $15 to $35 depending on who I order from.
O'Reilly's system shows oil pressure switch when typed in electrical for '71 bug.
No help whatsoever.
Always an adventure... stay safe
jinx
1971 Standard Bug
1776cc dual port
034 distributor
Cusser
Cusser is offline
PostPosted: Mon Mar 10, 2025 8:06 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
No help whatsoever.
Here:
https://www.oreillyauto.com/detail/c/import-direct...&pos=1
jinx758
jinx758 is offline
PostPosted: Mon Mar 10, 2025 12:56 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
Counter person typed in "1971 VW bug headlight switch" and clicked on "electrical component" ...
All that showed up was an oil pressure switch - nothing else :
no relays, fuses, emergency switch, TS switch, NADA.
No help at all.
That's when I pressed it together & used doorbell wire.
I didn't have my pack of zip ties.
Thanks anyway ... stay safe
jinx
1971 Standard Bug
1776cc dual port
034 distributor
BIGMIKEY
BIGMIKEY is offline
PostPosted: Fri Mar 14, 2025 11:12 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
radstude wrote:
BIGMIKEY wrote:
I installed this air dam. from what I can tell it's a pretty good copy of a real Kamei air dam and mounts the same way as far as I can tell. I mounted it with the flanges inside the bumper. It lined up with two outer holes that were already in the bumper. I drilled 3 more holes and used big washers and bolts to fasten it. The air dam is well made and symmetrical end to end. Lightweight but sturdy after being mounted. Gel coat quality was very good.
Mike T
Let us know if it makes a difference in driving & handling.
I was unable to detect any difference in handling or stability.. Gas mileage was in the same range of high 20's.
Mike T
BIGMIKEY
PiperFixer
PiperFixer is offline
PostPosted: Mon Mar 17, 2025 1:00 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
Installed a Maxi 2 Oil pump and filter. Blasted and painted a few tins.
Orange 72 Super
A&P IA
Page 455 of 458
