ICON VW pistons
VWporscheGT3
VWporscheGT3 is offline
PostPosted: Thu Jan 16, 2025 9:54 am    Post subject: Re: ICON VW pistons Reply with quote
And the person who took the early photos with spirolocs was promptly kicked in the nuts Laughing
personally i loathe spiro's ... but everyone has a preference right?
clockworkbox
clockworkbox is offline
PostPosted: Thu Jan 16, 2025 9:56 am    Post subject: Re: ICON VW pistons Reply with quote
This is why I asked Laughing
'69 Beetle (pieces)
Learning the hard way is still learning...
Brian_e Premium Member
Brian_e is offline
PostPosted: Thu Jan 16, 2025 10:18 am    Post subject: Re: ICON VW pistons Reply with quote
We could probably start a spiro haters support group for those of us with fat, stiff fingers, and bad eyesight.
Brian
So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts
modok
modok is offline
PostPosted: Thu Jan 16, 2025 9:16 pm    Post subject: Re: ICON VW pistons Reply with quote
I did a 350 last week with double spirolocks on the old pistons and the new Evil or Very Mad
I am going to put a charge on the bill for the time and suffering to remove and replace 32 of these evil inventions.
Brian_e is offline
PostPosted: Mon Jan 27, 2025 12:21 pm    Post subject: Re: ICON VW pistons Reply with quote
The new forged 94mm C height pistons are here!!
431 grams with the pin
26.8mm compression height
Nice thin 1.2, 1.2, 3.0 rings included
4032 Alloy
Coated tops
I did a mock up a while back with these. I used a new STD deck CB aluminum case, CB 86mm crank, STD AA 94mm cylinders, and CB 5.7 H-beam rods, and everything went together perfectly, and it had a near perfect deck height.
These will be the new easy way to build a stock width, long rod 2387cc. I have 3 sets left, and 3 more on the way, then Trevor's first batch will be about gone. He said he is planning another batch as well.
-Modok
b-man
b-man is offline
PostPosted: Mon Jan 27, 2025 1:32 pm    Post subject: Re: ICON VW pistons Reply with quote
Sign me up….. Thumbs Up
1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle
VWporscheGT3
PostPosted: Mon Jan 27, 2025 2:27 pm    Post subject: Re: ICON VW pistons Reply with quote
Brian is correct got another run already planned, but it will likely be April or late march before available.
85.5's are also in , same thing they are going quickly. so i have another run planned to be finished around the same time.
Thank you all for your support!
chrisflstf
chrisflstf is offline
PostPosted: Mon Jan 27, 2025 3:28 pm    Post subject: Re: ICON VW pistons Reply with quote
What is the purpose of the small round hole, near where the wrist pins clips go?
Nice looking stuff! Very Happy
VWporscheGT3
PostPosted: Mon Jan 27, 2025 3:46 pm    Post subject: Re: ICON VW pistons Reply with quote
On sidemill? thats a lockring digout , so when its time to pull it apart its not a big pain in the buttocks
dubman67
dubman67 is offline
PostPosted: Mon Jan 27, 2025 4:55 pm    Post subject: Re: ICON VW pistons Reply with quote
Where can we get a set?
Internet search comes up with nothing
67 Bug
62 Double Cab
[url=https://www.vw-mplate.com/mplate2-54829.png]Click to view image[/URL]
"At 17 got my first Volkswagen...and mastered the life long art of dragin...." Ice Cube
RickS
RickS is offline
PostPosted: Mon Jan 27, 2025 5:21 pm    Post subject: Re: ICON VW pistons Reply with quote
Comes right out in Google:
https://type-emotorsports.com/collections/pistons-...rcooled-vw
https://www.cbperformance.com/product-p/1015.htm?s...7CRpi6ZrCx
b-man
b-man is offline
PostPosted: Mon Jan 27, 2025 5:24 pm    Post subject: Re: ICON VW pistons Reply with quote
Just bought a set myself. Cool
Brian_e is offline
PostPosted: Mon Jan 27, 2025 11:13 pm    Post subject: Re: ICON VW pistons Reply with quote
Here are some quick pics of the adorable little 85.5 forged Icon's. These are going to be the hot ticket for the 1600cc Baja classes.
They have 1.5, 1.5, and 4.0 rings.
-Modok
efi67vw
efi67vw is offline
PostPosted: Tue Jan 28, 2025 6:41 pm    Post subject: Re: ICON VW pistons Reply with quote
OK OK take more of my money!
http://www.thesamba.com/vw/classifieds/search.php?username=efi67vw
txoval
txoval is offline
PostPosted: Tue Jan 28, 2025 8:01 pm    Post subject: Re: ICON VW pistons Reply with quote
Damn good price, especially compared the CSP version of a similar piston.
CSP version is lighter but also $1000
2stroke
2stroke is offline
PostPosted: Mon Feb 03, 2025 2:50 pm    Post subject: Re: ICON VW pistons Reply with quote
Is a steel top ring available for the 94mm that isn't plasma moly?
VWporscheGT3
PostPosted: Mon Feb 03, 2025 3:53 pm    Post subject: Re: ICON VW pistons Reply with quote
you are probably not going to like this answer.... but i would give my buddy Kevin Studaker a call at total seal. i know for a fact that have options for all current bores in a Steel top ring. and yes , you dont have to buy a kit , you can buy 4 individual top rings in steel
chrisflstf
PostPosted: Mon Feb 03, 2025 6:37 pm    Post subject: Re: ICON VW pistons Reply with quote
How long on a mill does it take to carve out one of these?
VWporscheGT3
PostPosted: Tue Feb 04, 2025 9:02 am    Post subject: Re: ICON VW pistons Reply with quote
Laughing I wish it were that simple.
since we own our own forging presses it starts off with cutting the bars to length for the right sized puck. they get heated to the pliable state and then stuck in the forging presses.... puck gets squeezed into shape and comes out the the press, and excess flashing is cut off .
from there it goes to its first machining process , skirt ream , where it gets the locating ring machined into the bottom of the forging so it can be held firmly off of one firm datum. then it gets rough pinbored, after that than it gets all its drills , oil drainbacks, pin oiler intersects etc.
from there it finally goes to the lathe and gets its rough shape and rings grooves. after that the underside gets milled to the correct thickness and shape. (there are going to be a lot of after thats here) side mills get put in after the internal milling, after that the pin bore gets its final bore and finish to within .0001" , annular oilers, broach and lockring grooves (as well as the digout ) all get done on about 3 machines.
after this it goes to skirt mill , to give the skirt base its final shape (slipper tip , etc) from there it then goes to the annodizing department, where the crown and top ring groove is given a military grade type 3 annodizing. after that it goes to the skirt finish machine , which puts the carefully selected barrel shape and ellipse to the skirt that works optimally on boxer style engines. from there is gets the skirt coating (M42) that you see on the skirts and finally to the laser etching machine to put all the markings on the pistons.
after all of that each piston is weighed to one another and boxed.
since we run many different types of pistons , whether it is a standard cast , hyper-eutectic cast , 4032 or 2618 forgings, it takes a while to run through the plant. Silvo-lite, KB, and ICONS are all run through the same factory. start to finish, i would say there is roughly 45 minutes of highly specialed work that goes into each piston.
I hope that answers your question Laughing
clockworkbox
PostPosted: Tue Feb 04, 2025 9:29 am    Post subject: Re: ICON VW pistons Reply with quote
Wow, that post makes me glad I have a set ready for my next build! Thanks for the detailed breakdown.
'69 Beetle (pieces)
Page 6 of 8
