shiggi10 Samba Member
Posted: Mon Jan 27, 2025 1:25 pm Post subject: Help identifying suspension set up please |
Hi,
I bought a 1960 bus last year and finally getting some time to look at it.
It runs and drives but needs some sorting out as it looks to have been modified way back when…
Reason for the post- I assume it is running an early bay front beam and early bay IRS rear but would be good to hear confirmation and any observations/ thoughts on challenges with this set up.
It sits quite well but haven’t had the opportunity to drive very far. Ideally I would like to go through it and make it safe- some things alarm me like the steering box being held on by coach bolts!
Then I need to work out a longer term plan!
Front
Assume early bay beam, can’t believe its on dropped spindles as that and the brake adapter would make it quite wide (happy to be wrong on that). Has a strange bar that revolves welded to the beam- not connected to anything and no idea what it does
Rear- welding doesn’t look great so I suspect poorly aligned.
Running a 130*5 adaptor to 205*5. So assume this is all early bay?
Any advice or confirmation appreciated
Thanks
Front
Rear
karl h Samba Member
Joined: October 10, 2005 Posts: 656 Location: austria
Posted: Tue Jan 28, 2025 12:02 am Post subject: Re: Help identifying suspension set up please |
the front is a porsche 911/944 hub, it fits the spindles
the beam seems to be early bay, you can see the balljoints
the bar seems to be there to hold a rollbar?
the rear arms are definitely early bay due to the angle of the inner bolts
a pic from further away would help (like on a hoist)
for fitting these arms you normally have to modify the chassis rails, but these seem to be suspended out wards. i have the same setup in my panel, there are pics in my buildthread.
these are custom shouckmounts in the rear split/bay shouckmounts are not compatible, the empty one is the stock split upper mount _________________ 61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
arctic alice (63 ragtop on irs): http://cal-look.no/lounge/index.php/topic,27456.0.html
86 Caravelle
04 new beetle vert |
karl h Samba Member
Posted: Tue Jan 28, 2025 12:04 am Post subject: Re: Help identifying suspension set up please |
there seems to be an unused brake booster adapter welded to the beam.
for improoved braking, mount one
it seems the center beam has been cut/turned/welded to lower it, the bumpstops are cut off. is there an adjuster on the rear side of the beam? _________________ 61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
86 Caravelle
Posted: Tue Jan 28, 2025 12:17 pm Post subject: Re: Help identifying suspension set up please |
Hi Karl,
Great build thread! Have read a bit, will read some more
Great info thanks!
Front-
Yes will look to use the booster, once it is welded on properly!
Further pics of the rotating bar ( in a different position) its not a roll bar / ARB but looks more like a cable actuator
No beam adjusters on the rear, but look to have been cut and rotated.
Maybe these are dropped spindles? No idea how to spot them
Rear
I can’t see any cuts to the motor mount but the cradle has been trimmed
karl h Samba Member
Posted: Wed Jan 29, 2025 12:24 am Post subject: Re: Help identifying suspension set up please |
i cant see an adjuster or welds for a cut-and-turn on the front beam, so if it is lowered it seems to have dropped spindles
the welded on front bracket is a mistery. i meant that the actual rollbar is missing and just the brackets are still there (hope thaqt makes sense) _________________ 61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
86 Caravelle
karl h Samba Member
karl h Samba Member
Posted: Wed Jan 29, 2025 12:30 am Post subject: Re: Help identifying suspension set up please |
for the rear brackets to fit outside of the chassis rails the rear IRS arms have to be modified, or they would push out the brake drums a good 2"
no rim would fit without cutting the wheelarches (and you would need 2" longer irs axels)
sorry for the multiple posts _________________ 61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
86 Caravelle
velvetgreen Samba Member
Posted: Wed Jan 29, 2025 7:45 am Post subject: Re: Help identifying suspension set up please |
where are all the missing washers on the beam bolts and in their proper orientation? |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2385 Location: Millwood, Wa
Posted: Wed Jan 29, 2025 9:18 am Post subject: Re: Help identifying suspension set up please |
When I look at the beam center retainer bolt, it sure looks clocked in a lower position (moved up). You can break centers free, make a slot, turn or clock centers and weld them in place, no adjusters needed. Saves a little money.... I believe that is what they did. Could have drop spindles too?
Beam is '68-'69. _________________ ---
Trying to keep poor cool
People are talking, the greatness is coming, going to be greater than great, so great, greater than anything ever.
Posted: Wed Jan 29, 2025 3:13 pm Post subject: Re: Help identifying suspension set up please |
| karl h wrote: |
sorry for the multiple posts |
Hey- no need to apologise! Very useful information, particularly about the hubs and brakes thank you |
Posted: Wed Jan 29, 2025 3:17 pm Post subject: Re: Help identifying suspension set up please |
| velvetgreen wrote: |
Sorry you might have to explain that one- never owned a split but I am an engineer so receptive to putting it right |
Posted: Wed Jan 29, 2025 3:20 pm Post subject: Re: Help identifying suspension set up please |
| Long-roofs wrote: |
Beam is '68-'69. |
I suspect you are right and that it is a 20 year old conversion- I lowered my bay window 30 years ago and had to change the tyres as they had tread but were old!
The upper one seems untouched |
Posted: Wed Jan 29, 2025 3:35 pm Post subject: Re: Help identifying suspension set up please |
I drove it for the first time today- truley terrible. I know they wander but this was heading significantly left or right with the steering straight ahead and no wind etc
I was aware the previous owner was concerned and had stopped driving it.
Bear in mind I bought it knowing it needed work and undriven
Rear toe looks significantly positive and tyres hot on inside edge
Front made a mess of a gravel drive and tyre edges are gone.
Steering very notchy and drag link has a huge amount of play as does the steering box
So plan is to
Front
Pull and probably replace front beam as its a mess- double adjuster, brake booster std width
Rebuild and replace all moving parts
Rebuild steering box
Rear
Replace all wearing parts and cvs
Change spring plates for dropped / adjustable plates and get the toe in spec
Open to further ideas and thanks for the advice |
karl h Samba Member
Posted: Thu Jan 30, 2025 10:47 am Post subject: Re: Help identifying suspension set up please |
| Great info - thanks |
Posted: Thu Jan 30, 2025 10:48 am Post subject: Re: Help identifying suspension set up please |
Cool |
Posted: Tue Feb 04, 2025 9:24 am Post subject: Re: Help identifying suspension set up please |
Its just dawned on me what the weird rotating bar welded to the front beam is…. Connects the brake pedal to the, now removed, brake booster/ servo
Posted: Tue Feb 04, 2025 9:25 am Post subject: Re: Help identifying suspension set up please |
karl h Samba Member
