Engine CSV fire, even after everything is done right
Page: Previous  1, 2, 3 ... 16, 17, 18
frankvw
frankvw is offline
PostPosted: Fri Nov 17, 2023 4:57 am    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
this topic was very helpful and learned alot.
Question to the CSV-group here: I am in the middle of new injection wireloom and rebuilding teh injoectors and new fuellines. (
1978 Ljet T2b 2.0 USA Injection)
Afer I took out the old wireloom, I not
iced that the wire to the CSV was broken, so it did never work like that.I had some issues with cold start, it takes a while to start, so that symptom is now problably explained too.
I tested the CSV in car by attaching power to the CSV, but no click like on the noral injectors. This makes me believe that the CSV does not work.
A new one is hrd to find and/or very expensive, so I did carefully read the posts on pro-active detach teh CSV, but in that case, it looks important to find open if it is stuck open or shut before I will reattach the new wiring. Is there a way to do that ? I guess take it out of the plenum and then start the car cold and see what it does ? What are your opinions ?
Wildthings
Wildthings is offline
PostPosted: Fri Nov 17, 2023 6:43 am    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
The CSV is grounded through the TTS (thermal time sensor) so if the TTS sensor is bad the CSV will not work.
frankvw
frankvw is offline
PostPosted: Tue Nov 21, 2023 4:04 am    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
Hi, thanks for the reply:
"The CSV is grounded through the TTS (thermal time sensor) so if the TTS sensor is bad the CSV will not work."
but maybe my question was not clear enough.
If the CSV does NOT click when putting power and ground on it from external source, that would mean it is stuck. How do I know (in-car) if is stuck-open or stuck-closed ? Or is that only possible to check out of the plenum ?
Abscate
Abscate is offline
PostPosted: Tue Nov 21, 2023 1:59 pm    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
You would have to remove it but stuck closed is far more likely
raygreenwood
raygreenwood is offline
PostPosted: Tue Nov 21, 2023 5:36 pm    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
This is an interesting thread.
As others have noted a page back and a year or so ago....an injector is an injector.
So from back in 2019 from Furgo:
PostPosted: Thu Aug 08, 2019 2:15 pm Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote Report this post to Moderator/Admin.
I've only come to read the updates on this thread now. Thanks so much for taking the time to test, document and share your setup.
Vee Dub Nut wrote:
-Flow specs are unknown. I would expect it to be a higher volume flow than the original CSV based solely on the fact that the OEM application for this part was a larger displacement engine (~2.8L BMW). [...]
From the old Bosch datasheet (*):
Original CSV:
- Bosch part no: 0 280 170 026
- Initial application: VW 411E
- Flow: 85 cmยณ/min (test pressure not specified)
- https://www.bosch-automotive-catalog.com/en/product-detail/-/product/0280170026
- Discontinued 04/2014
85 cubic/cm per minute. That is 5100 cubic centimeters per hour. That is 5.1 liters per hour "capability on the original CSV.
Ok, the stock 2.0L injectors from the chart in this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?p=9932607
....are listed at 191 cc/min. 1 cc = 1ML. Thats 11.46 liters per hour at 3 bars.
So we have an idea of the difference between the CSV output and the main injector output. Its a little less than half.
So divide that by feeding four cylinders during cold start....and the CSV is giving roughly 1/16th volume of fuel for each cylinder during its enrichment cycle.
I'm going somewhere with this... Wink
So....what if we could just get rid of the CSV and do the enrichment with the four main injectors?
How would we do that?
So.....let me tell you about some strange Bosch systems just to get your mental juices flowing. In the Saab cars in the 80's...mainly with CIS injection....they played around with two seperate enrichment systems but I am only going to describe 1 of them here.
The first was tied into the Lambda system that triggered off of the 02 sensor. When engine temperature and intake temperature were "X"...they had a fifth injector....just a real fuel injector....not a CSV valve.
It sprayed all the time....but it sprayed into a socket it was screwed into in the fuel injection RETURN line.
So...they were feeding about 10-15 psi too much volume/pressure all the time. The constantly open injector was bleeding that pressure off into the return line to keep fuel pressure "normal", When the ambient temp sensor and 02 sensor said...."we need more enrichment for cold start"....it either CLOSED that injector all the way or pulsed it....raising fuel pressure...increasing fuel dosage. Wink
So.....why could we not find a way to trigger the four main fuel injectors...double time them....outside of the normal triggering cycle from the ECU?
A similar example...D-jet does this with its throttle valve switch. The injectors are firing in pairs triggered every 180* of distributor rotation...but when you stroke the throttle there are 10 contact points for each pair of injectors....and as the throttle opens from say 0 to WOT...each pair of injectors gets "triggered" 10 times per throttle plate stroke....in addition to any triggering being done by the trigger points and ECU...giving extra enrichment only as the throttle plate is in motion.
Its an analog to the accelerator pump of a carburettor.
Just for "imagineering" sake....what would happen if we ran four extra wires to the system. One for each injector on the positive side. So each injector positive has two wires crimped into its female connector.
These extra wires go to a relay....that relay is turned on by the thermo time switch....but its supply of the positive to the four injectors is broken by a magnetic switch that allows all four to pulse only at engine rpm speed....90* out from where the coil signal comes from for the ECU.
The positive to the relay comes from the positive that fed the original CSV.
So when its cold enough and you start the engine.....you get normal running along with an extra pulse in between until the original CSV voltage is curtailed by the ECU....and then you are just running on normal injections.
For that matter though....I think I posted this here or in another thread a while back...you can buy motorcycle fuel injectors that put out about the right amount that are smaller than the original CSV. Just make a mounting for them and plug them in.
Ray
Abscate
Abscate is offline
PostPosted: Tue Nov 21, 2023 5:41 pm    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
Iโ€™ve measured cold start injection on Volvo 5 cylinders And found cold start time is about 5 msec whereas warm idle is 2 msec , GOT
On edit for Raysโ€™ question below ...system uses. No CSV , just the stock injectors
raygreenwood
PostPosted: Tue Nov 21, 2023 10:13 pm    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
Interesting!
Just so I am clear, this is just cold starting with pulsewidth on normal injectors with no CSV right?
So just for a volumetric calculation...not getting into 5 vs 4 cylinders...2 is 40% of 5. So cold start is 60% greater fuel volume than normal running.
Ok...lets run with that for a minute.
With a bus you get 29 psi at idle with throttle closed. If for some reason you have throttle open or vacuum is lost...you get 36 psi.
Thats ~19.45% greater fuel volume at any pulsewidth when throttle is open....or vacuum is lost.
Lets say we connected a simple vacuum breaker solenoid like what they used in the 70's in Canada and other markets to cut vacuum advance on and off during warmup....tee'd into the vacuum line to the fuel pressure regulator.....turned on and off by the thermo time switch and the timing function in the ECU through the positive wire that feeds the original CSV.
Now you have ~20% extra enrichment. Add to that, a cutout controlled by the same TTS...to add say....500-700 ohms into the TS-2 as ballast...only during the cold start cycle. You could do the same at the same time with TS-1
I bet we could get an easy 60% greater fuel enrichment this way during that cycle....with no CSV.
Once could also do this with a solenoid that chokes off the fuel regulator return line giving you almost any fuel pressure rise you want for a short period of time. Fuel dosage = pressure x time. Ray
SGKent Premium Member
SGKent is offline
PostPosted: Wed Nov 22, 2023 2:40 pm    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
50 year old car almost. Don't expect anything to be inexpensive or available. Parts for a 1938 Packard are probably more available than Bus parts these days.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
mr matt
mr matt is offline
PostPosted: Sun Feb 02, 2025 5:53 pm    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
will be looking into this developed unit
from injector rehab...
Upgraded CSV โ€“ Injector โ€“ Cold Start Valve โ€“ EV1 Dual Barb
https://injector-rehab.com/product/upgraded-csv-in...965ZMfyc50
Contacted them, they replied for buses, they prob have hundred out there with no complaints.
1955 3-fold semaphore Oval beetle
1971 Convertible beetle
1977 Westfalia, FI, Berlin interior
Bnanwel
Bnanwel is offline
PostPosted: Sun Feb 02, 2025 6:51 pm    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
Youโ€™ll like the injector rehab csv. Itโ€™s an excellent product.
โ€˜72 Karmann Ghia Conv.
โ€˜73 Karmann Ghia Coupe
โ€˜74 Karmann Ghia Coupe
โ€˜70 Deluxe
โ€˜72 Deluxe
mikedjames
mikedjames is offline
PostPosted: Mon Feb 03, 2025 10:14 am    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
Just thinking.. you could inject a current into the output of the AFM when the engine is cold to cause it to increase the injector pulsewidth. A few transistors could replace the thermotime switch.
From my studies of the CIS as used on the VW Golf GTI and the hybrid VW/Ford system I own that came from a Baja Beetle - The other CIS cold enrichment system was a valve that controlled the pressure regulator installed in a die cast box bolted to the engine block with a bimetallic strip controlling the valve and a 12V heater element wrapped round the strip.
If the bimetallic strip was cold it caused the pressure regulator in the fuel metering valve assembly to boost the pressure.
Ancient vehicles and vessels
raygreenwood
PostPosted: Mon Feb 03, 2025 10:49 am    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
Yes. Similar to what I was pointing out earlier in this thread! Fuel dosage = pressure X time. If it's too complex to dial in more time (meaning pulsewidth)....raise the pressure. One could also just momentarily choke off return flow in the fuel loop.
I bet if I looked hard enough I could find a hydraulic inline valve that with a pull of the lever....cuts off liquid flow through it. Put an orifice in the block off plate so it's not a total blockage so it moderates pressure at a set level. You could almost connect this to a defroster knob on the dash with a cable. Like....manual choke....but manual cold start enrichment at the main injectors with no cold start injector. Ray
airschooled
Air-Schooled
airschooled is offline
PostPosted: Mon Feb 03, 2025 11:16 am    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
L-Jet already has injector enrichment during cold start. Pin 4 on the ECU triggers it.
Robbie
WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
mr matt
mr matt is offline
PostPosted: Mon Feb 03, 2025 3:17 pm    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
Thanks for the pic Bnan, was wondering about the fit. Looks good!
tommu Premium Member
tommu is offline
PostPosted: Mon Feb 03, 2025 5:40 pm    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
Functionally it is excellent - but it's 50/50 whether it will interfere with your vacuum can. It does protrude..
Green Bay Bus Yellow Ghia
Bnanwel
Bnanwel is offline
PostPosted: Mon Feb 03, 2025 7:20 pm    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
Thatโ€™s a good point, but it looks closer than it is. There is a solid 3/4โ€ between the vac can and the rehab csv. It allows about 35 degrees of rotation for the distributor; I checked when I retimed the engine. I donโ€™t foresee any problems.
โ€˜70 Deluxe
โ€˜72 Deluxe
airschooled
Air-Schooled
PostPosted: Mon Feb 03, 2025 10:53 pm    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
Maybe he means 50% of the cars out there that have DVDAs and larger vacuum canisters? Wink
Robbie
www.airschooled.com
Bnanwel
Bnanwel is offline
PostPosted: Tue Feb 04, 2025 4:04 am    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
Thatโ€™s an excellent point. Perhaps the t-barb could be shortened? Thereโ€™s an extra 1/2โ€ of stemโ€ฆ
โ€˜70 Deluxe
โ€˜72 Deluxe
Globedog12 Premium Member
Globedog12 is offline
PostPosted: Thu Feb 06, 2025 6:26 pm    Post subject: Re: Engine CSV fire, even after everything is done right Reply with quote
I have an injector rehab csv installed on my 76 bus. It is a tight fit but it works. The only thing I donโ€™t like is that it makes getting to the distributor clamp nut a pain in the ass. Doable but with a lot of wrench flipping and repositioning. Still worth it to get rid of the original.
1976 VW Type 2 Original fuel injection
Page 18 of 18
