Primer color
bnam
bnam is offline
PostPosted: Mon Aug 26, 2024 1:30 am    Post subject: Primer color Reply with quote
I’m going to repaint my 65 KG the original L560 Manila Yellow. I’ve got two conflicting inputs on the color of the primer I should use. One paint guy said use white. Another said that gray or black would make the color come out more in its proper tone than white.
Any advice on which path I should follow?
Thanks
Byas
Click to view image
1952 Citroen TA 11BL
RLFD213
RLFD213 is offline
PostPosted: Mon Aug 26, 2024 5:25 am    Post subject: Re: Primer color Reply with quote
Primer color shouldn’t matter. It’s the sealer you use just under the paint. Yellow takes a lot more paint than other paints do, so I’ve been told. And yes what the painter told you about light and dark is correct.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Mon Aug 26, 2024 8:18 am    Post subject: Re: Primer color Reply with quote
Get the white tinted yellow. They can only add a tiny amount to the base, but it makes for an easier paint job. When I sprayed my yellow 70, 7 years ago, it took about 6 coats, to get the depth of color correct. That was on gray primer. Had I tinted some white, it might have been 4, maybe 5!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
67ctbug
67ctbug is offline
PostPosted: Tue Aug 27, 2024 6:23 pm    Post subject: Re: Primer color Reply with quote
BASF has a recommended grey shade for the undercoat color. Yellow is going to cover poorly, so you'll want to use whatever the paint manufacturer recommends. The Ruby car I just did is different colors even with 5 coats depending on which undercoat I used. For L560, Glasurit recommends a very light grey sealer/primer, L06.
'67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
shanered
shanered is offline
PostPosted: Sun Feb 16, 2025 11:10 am    Post subject: Re: Primer color Reply with quote
Everyone will tell you something different. Painter has last say, lol you painter no? I use brown under yella, yellow sometimes vw used gray i think All pigments different can o worms
2type2
2type2 is offline
PostPosted: Sat Feb 22, 2025 8:30 am    Post subject: Re: Primer color Reply with quote
I have painted both a 78 and 66 westy in Daytona Yellow. The first was painted with a Grey bond- seal primer- one gallon of yellow did not cover the darker grey primer well. Second was primed in white and 1 gallon did complete coverage on the wholebus.So go with white or yellow-tinted primer for sure
"A life of peace and happiness depends on your own gratefulness"
