ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1937 Location: Sidney B.C. Canada
Posted: Sun Feb 23, 2025 6:52 pm Post subject: Re: 2024 available? 100ah+ Lifepo4 UNIT that fits under driver seat |
Hi,
Been working on getting my aolithium to fit drivers side . I printed a new lid, two part as my printer can’t do it in one . There’s a bridging party under to glue together, I’ll probably machine one part version from poly e.
The gland nut things you see, first go round I made them too tall. Bench pics show shorter. I’m tempted to drill side of case and lead cables out that way .
But, it fits under the lid .
Excuse the wiring mess, that’s all being tugged and moved from my previous aux battery set up
_________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10379 Location: Orbiting San Diego
Posted: Sun Feb 23, 2025 8:49 pm Post subject: Re: 2024 available? 100ah+ Lifepo4 UNIT that fits under driver seat |
Impressive job! I would like to do something similar if I can.
I wonder if you could drill the holes for the cables at a 45 degree angle so the cables wouldn't need as sharp of a bend on the outside.
Any photos of the cable connections you made inside?
Mark |
Posted: Sun Feb 23, 2025 9:15 pm Post subject: Re: 2024 available? 100ah+ Lifepo4 UNIT that fits under driver seat |
I’ll get pics of interior wiring posted as I can .
I think instead of 45 from top, side holes in the main case about 1/2-3/4 inch below the top woudl do it .
I replaced the stocks battery bus bars ( laminated copper sheet bound with heat shrink ) with 6 awg. To lead out of box. It’s trivial mod .
I printed the top from petg. I’m not happy with it really, I’d like one piece . I’ll probably machine that . But as is , it works . _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
kevinjakey Samba Member
Joined: October 03, 2003 Posts: 20 Location: Hollister, CA
blyhigh Samba Member
Joined: April 13, 2006 Posts: 175 Location: The Beaver State of Mind
Posted: Wed Aug 06, 2025 4:13 pm Post subject: Re: 2024 available? 100ah+ Lifepo4 UNIT that fits under driver seat |
Just installed today. Yes it fits! Note to GW: Can you make the terminal posts just slightly shorter? Otherwise, great!
_________________ '89 Syncro Westy |
boxer74 Samba Member
Joined: July 03, 2011 Posts: 862 Location: Ontario, Canada
Posted: Thu Aug 07, 2025 6:05 am Post subject: Re: 2024 available? 100ah+ Lifepo4 UNIT that fits under driver seat |
blyhigh wrote: |
[Pics] |
Looking good. Wish this option was available when I bought my Battleborn. _________________ 74 Super
84 Westy |
4Gears4Tires Samba Member
Posted: Thu Aug 07, 2025 6:59 am Post subject: Re: 2024 available? 100ah+ Lifepo4 UNIT that fits under driver seat |
I like the little caps on the terminals. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
Posted: Thu Aug 07, 2025 8:33 am Post subject: Re: 2024 available? 100ah+ Lifepo4 UNIT that fits under driver seat |
4Gears4Tires wrote: |
I like the little caps on the terminals. |
Did not come with the battery. Those are from my old Renogy 50ah. _________________ '89 Syncro Westy |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12318 Location: Santa Cruz, CA
Posted: Thu Aug 07, 2025 9:34 am Post subject: Re: 2024 available? 100ah+ Lifepo4 UNIT that fits under driver seat |
It is weird that the holes for the plastic positive terminal cover that comes on group 41 batteries are missing. Battery shorts are bad.
Picture borrowed from the gallery
