Emergency flasher switch
dubbified
dubbified is offline
PostPosted: Thu Mar 13, 2025 9:32 pm    Post subject: Emergency flasher switch Reply with quote
Well, I'm in need of a new emergency flasher switch that goes on the odometer cowling of my 90 vanagon.
I was tidying up my dash work after tracking down the bad ground on my steering wheel, I'd reziptied the leads and put the dash on.. went to pop this sucker into the bezel..
But.. the damned switch came apart in my hands! omg!
Lookin at Busdepot, Vancafe and GW.. I cannot find this damned thing with standard word searches..
Emergency
Hazard
Flasher
switch
button
Looking by category, electrical and or Lighting sections I'd think have it.. since it is electrical (switch) and is by nature apart of the lighting system.. I'd think for sure its in the lighting section.. nooooo logic does not prevail.
uh..
Really.. nothing. Is it called somethinng else?
will have to try to find the part # on it
markswagen
markswagen is offline
PostPosted: Thu Mar 13, 2025 9:36 pm    Post subject: Re: Emergency flasher switch Reply with quote
part number #175-953-235
no longer available.
there's a bunch in the classifieds.
619 201 0310
dubbified
PostPosted: Thu Mar 13, 2025 10:14 pm    Post subject: Re: Emergency flasher switch Reply with quote
Thanks Markswagen!
I did search, and no results.
500 mile search, 175-953-235. Vanagon forum..
Hmm... NLA huh.. damn.
Oddly.. I just had connected it confirmed it works just fine.. it is only damaged because I forced it, and the case came apart spilled its guts on the floorboard.
Any confidence if I might be able to pop it together, and plastic weld the case back together.
I just welded a Audi bumper.. and have a plastic welder...
I've done crazier things.. like modding a 1.9 to a 2.0 ALH into my van..
This will not stand in my way.. damnit.. I'm like seconds away from driving a 3 yr project in my driveway..
67rustavenger
67rustavenger is offline
PostPosted: Thu Mar 13, 2025 10:46 pm    Post subject: Re: Emergency flasher switch Reply with quote
Are these the correct switches?
https://www.thesamba.com/vw/classifieds/detail.php?id=1995406
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
dubbified
PostPosted: Thu Mar 13, 2025 11:37 pm    Post subject: Re: Emergency flasher switch Reply with quote
It looks to be!
Thanks!
kamzcab86
kamzcab86 is offline
PostPosted: Fri Mar 14, 2025 12:13 am    Post subject: Re: Emergency flasher switch Reply with quote
And here I am trying to get mine apart to clean the contacts and fix a dim bulb and am having a trying time.
BTW, there's a dirty used switch on eBay for the cheap sum of $3,375... + $12 shipping. No, that's not a typo. Surprised
~Kamz Anxious
2016 Golf GTI S
4Gears4Tires
4Gears4Tires is offline
PostPosted: Fri Mar 14, 2025 6:16 am    Post subject: Re: Emergency flasher switch Reply with quote
Usually when you see a price that high, the seller does not have the item or is away and wants to keep their listings "active" for ebay algorithms. At least, that's how I've understood it.
PostPosted: Fri Mar 14, 2025 8:20 am    Post subject: Re: Emergency flasher switch Reply with quote
dubbified wrote:
Thanks Markswagen!
Don't select years or models for parts searches - Those things are primarily for people posting vehicles and almost no one enters that data for parts sales so no ads will be found even if one exists.
I wouldn't enter a zip code or distance either, unless you want to drive to go get it
zerotofifty
zerotofifty is offline
PostPosted: Fri Mar 14, 2025 10:35 am    Post subject: Re: Emergency flasher switch Reply with quote
Sometimes switches that fall apart at the seams can be glued together or even zip tied back together. I have zip tied headlamp switches for old bugs when the board was worn away where the metal tabs hold it.
a photo of your damaged switch will be helpful in obtaining repair ideas
dubbified
PostPosted: Fri Mar 14, 2025 11:50 am    Post subject: Re: Emergency flasher switch Reply with quote
Thanks guys!
@EverettB, Thanks for the guidance! Doesn't that kinda defeat the purpose of using those attributes to search "Parts Vanagon"? Odd.
0-50, thanks for the vote of confidence here.. Self repair is the game we're all here for!
I am glad that I learned to repair things at a very very young age.. It makes me a hacker of things.. a modder, but certainly.. not a cheapskate!
A photo of your damaged switch will be helpful in obtaining repair ideas
The issue seems to be where the backing plate/casing clicks into the main switch body housing where those little rectangular notches click/lock into the housing, the guts went flying onto the floor.
The casing is not broken, its popped apart. On inspection of the wear points on the backing plate, which has a resistor on it, and the spade terminal connectors.. I've never seen the inside of this switch, but apparently I'm missing a metal piece..
I do have a very nice Plastic welding kit.. so no zipties.. but melting that case plastic together would be a permanent fix!
Its a nice day out, so hopefully I'm back in action, without having to buy anything.
Thanks,
Alex
dubbified
PostPosted: Fri Mar 14, 2025 12:54 pm    Post subject: Re: Emergency flasher switch Reply with quote
I see that light in mine.. went to pull it, and it appears to be a twist/lock..
There are rectangular port holes into the housing/ primary switch casing, (shown in my pic), seem to be where to separate the backing plate.
I'd suggest a very sharp pick, even warming up the plastic.
kamzcab86
PostPosted: Fri Mar 14, 2025 2:11 pm    Post subject: Re: Emergency flasher switch Reply with quote
Yes, twist-lock; that much I already knew. Laughing
I've given up on opening the thing; don't want to risk destroying it (still works, so...). I've checked the switch connections with my meter and put 12V directly to the bulb. There's 12V at all appropriate connections on the switch and the bulb lights up brightly uninstalled (it now doesn't light at all when installed). I've concluded the bulb holder is possibly where the issue is. New holder, which allows for easy bulb replacement, is on order.
~Kamz Anxious
2016 Golf GTI S
dabaron
dabaron is offline
PostPosted: Fri Mar 14, 2025 2:23 pm    Post subject: Re: Emergency flasher switch Reply with quote
just trade with dubbified Very Happy
1991 Vanagon GL Camper
crazyvwvanman
crazyvwvanman is offline
PostPosted: Fri Mar 14, 2025 6:09 pm    Post subject: Re: Emergency flasher switch Reply with quote
VW Parts gives a different number for the emergency/hazard flashers switch.
171 953 235A listed for 84-91 Vanagon.
That is also the number on all 5 of my spare switches pulled from Vanagons.
https://parts.vw.com/p/volkswagen__/Hazard-switch/54411203/171953235A.html
Mark
zerotofifty
PostPosted: Fri Mar 14, 2025 6:52 pm    Post subject: Re: Emergency flasher switch Reply with quote
Add a dab of silicone dielectric grease on the sliding contact when you reassemble. This reduces wear. not sure if a zip tie can be used here seeing as how it needs to be installed. Glue or weld, if you can find the missing part that flew away.
Weld can be done perhaps with a hot solder iron
Good luck, keep us posted
dubbified
PostPosted: Fri Mar 14, 2025 8:34 pm    Post subject: Re: Emergency flasher switch Reply with quote
thanks guys!
No love on that part.. I dont even know what I'm looking for..
It seems it would have a couple dimples in it like the other.. it looks kinda like a staple, and a spring sits under it..
So they say Patience... and like so many other things.. the second I stop looking.. BAM.
So, moving to the repairing my fiberglass basket, cracked the edge while cleaning.. it fell, cracking this edge.
I grew up making hot tubs.. I manicured the edge, pounded out some 3/4" wide aluminum strap compared to the other uncracked side.. then, fitting it, and really making sure it wont wobble, bam.
and just like cracking a bone.. you gotta set it, and
and let it gel.
The angles of blue tape are to force it down, forward, and into the primary basket fiberglass, restraining it.. gentle force.
Onward.
Presently having a campfire, , and cleaning interior windows.. all points driveable.. the second I fix that flasher, and align the shifter.
Happy weekend ya'all!
dubbified
PostPosted: Fri Mar 14, 2025 8:49 pm    Post subject: Re: Emergency flasher switch Reply with quote
I HAVE.. seen those bulbs melt, and it likely is a call to replace it, and avoid the (shhhh) fire department thread.. egads.
Amazon does have a push button design that I could go to.. it looks just like the flip switches on a MK2 golf..
And.. it fits into my (about to be) dash mounted 8 gang switch panel.. I replaced one with a momentary for the freight train horn..
The hazard is a nice update in functionality, visibly, they also have a ton of function specific switches which I'm glad to see they released.
Nilight is a good manufacturer.. got 4 of their 6"x 1" floods under the vehicle, a 52 and 22" led bar. zero issues some 8 yrs later.
dubbified
PostPosted: Fri Mar 14, 2025 9:05 pm    Post subject: Re: Emergency flasher switch Reply with quote
Mark
Well, it surely seems there are some options
https://www.carparts.com/details/Volkswagen/Vanago...lsrc=3p.ds
URO parts are Okaaaay.. but.. hmm..
dubbified
PostPosted: Sun Mar 16, 2025 1:38 am    Post subject: Re: Emergency flasher switch Reply with quote
Thanks.. cant find the all the guts, seem to be missing a second contactor piece.
It looks like I'm going to be ordering..
I'm cheap. if that switch is like 8$... I'd snap that up if it would fit the 90 guage cluster spot.
mmm, Might you or anyone you know of put that in, and have any feedback?
Atleast my buddy had some time to help me get my 4 speed shifter aligned, so i can finally get into R, 1/2, 3/4... yay.
Almost road worthy.
kamzcab86
PostPosted: Sun Mar 16, 2025 10:52 am    Post subject: Re: Emergency flasher switch Reply with quote
Part number for the early vans: 175-953-235
Part number for the later vans: 171-953-235A
Either will work and both are NLA new. Just bought a used, (alleged) tested and working 175-953-235 on eBay as a backup... just in case.
~Kamz Anxious
2016 Golf GTI S
