Saggs Samba Member
Joined: December 23, 2003 Posts: 669 Location: Lincolnton, NC
Posted: Sun Mar 16, 2025 1:37 pm Post subject: 67 westy resto. Body work done. Now what? |
Hi all. Been working on my bus for a while. I’ve got all the metal work done 99% of the filler and straightening work is finished. I have used master series primer on the undercarriage and painted that in a dove gray urethane. Wondering what the next step is on the upper part of my bus should I spray the whole thing in a self etching primer or sandable primer like a K 36. I know I still need to prime and sand but didn’t know what I should apply directly over the bare metal spots and body filler. Thanks.
_________________ "One man can make a difference...Jesus did." |
early Samba Member
Joined: January 19, 2012 Posts: 256 Location: Glen Carbon, IL
Posted: Thu Apr 17, 2025 6:55 am Post subject: Re: 67 westy resto. Body work done. Now what? |
Epoxy primer from southern polyurethane. (SPI)
I use SPI epoxy over Sandblasted, sanded w 80 grit bare metal.
You can apply your filler over that it adheres very well.
I have used on several cars and it is very workable.
I have a couple threads here with the process I used.
Noth claiming to be a professional but everything is holding up well
After many years.
When the occasional accidental chip happens it never goes to bare metal.
The epoxy is the bomb.
Cheers. Early _________________ early-
Barnfind westy project
my 73 sports bug project build
http://www.thesamba.com/vw/forum/viewtopic.php?t=497088
Current Projects :
73 Sport Bug - L13M gone now
67 Westfalia
57 oval window ragtop - sold june 2021
61 sedan
68 Corvette Roadster - Small Block, 4 Speed
86 GMC Sierra Classic- 4x4, Shortbed
94 Harley Flstn |
