1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave.
Page: Previous  1, 2, 3 ... , 23, 24, 25  Next
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sun Mar 16, 2025 10:17 pm    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Looking sweet! Lines look good!
Shaka!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
MACJELLY58
MACJELLY58 is offline
PostPosted: Sat Mar 22, 2025 9:56 pm    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Thanks my Braddah's, JIMBO and BUGGEEE! It's awesome when the little things just work out. My little things don't seem to work out all that often. Well, I think it's because of my inexperience. I think it will be a little thing and then, reality Smacks me down!!
For instance, I thought I'd just fit the Swan Neck mirrors and perhaps have to drill an extra hole. I went with these mirrors so I could move them far away from the Suicide Doors and keep the mirrors from interfering with egress.
Also, I think they are cool looking. Wink
I wanted to go with the Fat Moulding too, since I deleted the extra Moulding on the front Quarter Panel.
Anyway, not as easy as just switching them out as I naively thought.
First problem I didn't think about...different size Moulding...different size clips and holes. I did a test hole on some scrap. The drilled hole wasn't pretty. I switched out to my Stepped bits and they made a nice clean hole.
Awwright!! Drilled out the old holes and got the new Moulding to test. The end of the Moulding is open towards the door. Not cool. I finally figured out, that's where they would usually butt up against the door Hinge, which is not there anymore. I did some bending and tweaking. It'll pass I guess.
Then, there's this. Apparently, I'm a bit short on the Moulding. I mean It looks okay, but the Mirror only has one bolt to secure it. The Muolding helps out by going in the channel under the Mirror base.
I moved the Mirror up a couple of inches and drilled a new hole. But, now I got the the original hole up front. I was thinking, maybe put an auxiliary Marker/Blinker light there? Nah, there I go again...trying to make more work for myself. I'll just fill it.
Here's a view from inside the car. Not very practical. I got some convex stick on mirrors that I'll try and see if that makes a difference in usage.
The rear Quarter and Doors were not so bad.
Last up was the Hood. The length was pretty good, but the Super's curvature is much more steep vs. the earlier, longer sloping Hoods. I didn't want to kink that Bastard, so I put in a bunch of relief cuts to just try to relax it a bit.
I had thought of putting the WolfsBurg Crest at the bottom, where the Trunk Handle was. But, the Trunk Latch is under there. I'll have to think about how to address that space. So, up to the Top the Crest went.
That was another, "Not so easy", thing. While trying to fit it and figure the plan, the two prongs that secure the Badge to the mounting plate broke off. Long, aggravating story later...I Epoxied the Badge to the Mounting Plate with a large head Carriage bolt sandwiched inbetween.
Then, bolted it down nice and snug! I'll see you guys at my next "Simple Thing"
K-DEN, Braddahs!!
[size=18]
DUNGBTL Premium Member
DUNGBTL is offline
PostPosted: Sun Mar 23, 2025 8:03 am    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
I feel you!
Restomods can be much harder than by book restorations for those very reasons!
I think your custom solutions turn out great! Looks like something the factory would do.
J.
Oh and good call on the step drill bit for thin sheet metal holes. I never use a standard bits for final hole size. Thumbs Up Thumbs Up
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Mar 23, 2025 8:23 am    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Don't know how I missed this topic for so many years.
Damn impressive.... i'll be following.
You get 2 Thumbs Up Thumbs Up
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
VW_Jimbo is offline
PostPosted: Sun Mar 23, 2025 8:24 am    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Very nice update Bruddah! Dude, the moldings came out wicked! Loving the early peek at the finished product!
You are getting there!
Jimbo
Epilog79
Epilog79 is offline
PostPosted: Sun Mar 23, 2025 10:08 am    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Always inspiring with the creativity out of necessity. Keep thinking out of the box and follow your “vision” for your masterpiece. Glad to see you getting time to play in the garage again. I really like the wide molding. I have always been curious with the swan neck mirrors if they were actually useful. Reminds me of the fender mounted mirrors on the early 240Z cars.
Buggeee
Buggeee is offline
PostPosted: Sun Mar 23, 2025 4:36 pm    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
MACJELLY58 wrote:
...Swan Neck mirrors... are cool looking... the Fat Moulding.. cool looking...
Correct on all points. Well worth the effort.
p.s. in the sandbox you play in, there are no simple things. Cool
Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out)
MACJELLY58
PostPosted: Mon Mar 24, 2025 1:09 am    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Wow, DUNGBTL!!
I couldn't even imagine a build like yours in my wildest dreams. Thank goodness you take a lot pictures or I'd be totally lost following along. Looking at threads like yours and other Masters help to push me forward with my small problems. So, thanks for that!
I can always count on your encouragement, JIMBO. You are a real VW enthusiasts. Every inch of every car, Crazy! You're the neighbor that every guys wants next door. Well, except your actual neighbors. But, SCREW them!!
Shame on you Hahahaha
MACJELLY58
PostPosted: Mon Mar 24, 2025 1:21 am    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Howzit EPI !!
Good to hear from you. Yah, I like them wide Mouldings too. I always thought it was weird that they made the Supers a lot wider and Fatter up front, but went and put on skinny spaghetti Mouldings. Think
Oh, and love those old "Z's". They are crazy expensive now, if you can even find one nowadays. Even straight from Japan! Although, I doubt those Mirrors were any help on that car either. JeffsThing mentioned on a post about the Mirrors that he has a '79 Super with Suicide doors AND the Mirrors. He's not with the car right now, but he said he would be glad to send some pics in April. That would be cool to see! Meanwhile, I'll just keep stumbling along.
MACJELLY58
PostPosted: Mon Mar 24, 2025 1:29 am    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Pray I am honored, GLENN Pray
Thanks for all you do on the site. TheSamba is invaluable!!
And Don't feel bad about missing this folly. I'm in Hawaii and Post on random days, usually between the hours of 11 p.m. and 3 a.m. By the time "Normal" people are up and about, it's usually buried under real threads.
Keep up the Good work, my Good Fellow!!
MACJELLY58
PostPosted: Mon Mar 24, 2025 1:33 am    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Sorry, My Braddah. I beg to differ.
There is at least one "Simple Minded" person on hand at all times. Shocked
vwuberalles
vwuberalles is offline
PostPosted: Mon Mar 24, 2025 7:35 am    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Love the mirrors! I actually put fender mirrors on my Z31, they work surprisingly well and eliminate blind spots! Getting them adjusted right is kind of annoying but once they're set they're fantastic. You get used to them pretty quickly.
MACJELLY58
PostPosted: Thu Mar 27, 2025 6:58 pm    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Thanks for the info, vwuberalles. I've seen good and bad experiences with these type of mirrors. I'm thinking it probably has a lot to do with how good your eyesight is functioning. Hopefully, mine will still be good enough to see that far.
I didn't really have a lot of time. But, I had to close those extra holes after the mirrors. My mind kept drifting to doing something with them, like those Marker lights. Then, I was thinking maybe T-Handle Hood Latches. Silly stuff like that.
I thought, just bang them out and get myself over it!!
MACJELLY58
PostPosted: Mon May 05, 2025 7:34 pm    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Hi there. I haven't had any time to work in the garage this past month. But JEFFSTHING, that I had mentioned earlier has sent me several pics of his "79 Super with his mirrors installed. Not, the same mirrors that I got, but
Very COOL !! He also mentioned that he will selling it soon.
Enjoy
MACJELLY58
PostPosted: Sat May 31, 2025 7:34 pm    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Hi All,
I FINALLY got an afternoon in the garage! Not a lot of time, but I'll take it.
Awhile back I was looking at some of plastikman187"s photos of his smoothed out Bug. His Engine Deck Lid was nice and clean, I... LIKED IT!
The only thing is Hawaii's Traffic Code is kinda specific about the location and illumination of the rear plate. I went looking for a solution on the Web. I found something pretty cool. It has a LED License plate light, AND a LED third Brake light! I was thinking about how to mount a third light, this should take care of that. On less thing.
So, all that was needed was to smooth out the License Plate light Hood mounting area. There is an indented square under the plate and then an indented lip for the Light Hood. I thought that I would weld the patch in the indentions to help with any warpage and further finaggling later.
I used the last piece of scrap for the Donor Trunk Lid. It has a nice curvature already. so that helped.
After tacking it in, I flipped it over and cut out the old piece.
I cleaned it up a bit and put in more welds. I was not there yet, but it was time for some Adult Beverages!! I think I can get a little more time next weekend. Pray Pray
VW_Jimbo is offline
PostPosted: Sat May 31, 2025 10:47 pm    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Nice!!! Love that plate with the brake light. I have been toying with getting a row of red LED in the louvre vents. I was thinking anything to help people know I intend to STOP! That plate might work!
I am a life long subscriber to the “baby steps” process of working. It has always amazed me at how far one can go simply being in touch with a project everyday! I include researching, ordering and planning as part of the process.
Excellent work my bruddah! BTW your welds are looking way better! You turned up the heat. I can see it! Now you need to move the puddle around during the pull. I like using a back and forth movement, very quickly done, no holding still it helps with the amount of material that builds up, which means LESS GRINDING!
Hang loose!
Jimbo
Buggeee
Buggeee is offline
PostPosted: Sun Jun 01, 2025 5:09 am    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
MacJelly, I may be repurposing some stainless trim from one area to another area on an old Buick, which will involve cutting it to a shorter length, leaving an open end that needs to be closed like this. Did you fill the outer edges in some fashion, or is it just folded down in the middle? It looks good.
MACJELLY58
PostPosted: Sun Jun 01, 2025 6:53 pm    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Hang loose!
Thanks Bruddah JIMBO,
I am getting better. After 10+ years, it appears I'll never be good at it. My learning curve is just too flat! But, I'll try to remember to use that technique. I so despise GINDING. Baby Steps, indeed Wink
MACJELLY58
PostPosted: Sun Jun 01, 2025 7:01 pm    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Hi BUGGEEE. Another Project!! You are an unstoppable force.
I just cut a little wedge out of the sides, about 1/8". Then put some blue tape on the teeth of my standard pliers(in hopes of not marking the Trim up too much). Bent down the end and folded the side Tabs in. It's not as nice as the Blurry pictures make it seem. But, that was the extent of my skill set. Embarassed
I'm sure you will make it a lot nicer.
MACJELLY58
PostPosted: Fri Jun 06, 2025 7:58 pm    Post subject: Re: 1975 Beetle Convertible Resto/Mod Build-Chop,Dash,Suicide,Shave. Reply with quote
Another afternoon in the Garage. I was able to get the pin holes filled and ground down. I did remember to move the puddle a little bit. Thanks JIMBO. It was a little difficult with the thin metal. But, less grinding is always a plus.
It looked pretty good. I went on to make the mounting bracket. I guess I could've just bought one. The ones I looked at, had only two mounting bolts and looked rather flimsy. I cut some strips of 16ga. and made a mental plan.
I welded that together and put it on the Plate Frame to mark the mounting holes.
I drilled out the Wire Feed hole in the indented circle (I don't know what that was for?). The Grommet I used was the ones I ordered for the Windshield Wiper arms, that were too small.
It seems I never learn. Maybe too old?
After nearing the end of this, Only then do I think, "Maybe I should test this thing?" Even if it works, will I like it?
I mean for Goodness sake, I didn't even read the specifics. Come to find out, there is a function for Running light in conjunction with the Brake light. First pic is the Running light, the second is the Brake activated.
I liked it !! So, I primered it all up.
Finished pics. Seeya, Next Time!
Page 24 of 25
