1970 Fastback "sympathetic restoration"
Page: Previous  1, 2, 3 ... , 14, 15, 16  Next
Tram
Samba Socialist
Tram is offline
PostPosted: Mon Sep 02, 2024 4:01 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
Also check this adjustment- this is periodic maintenance:
Then pump the front beam full of fresh grease.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
akokarski
akokarski is offline
PostPosted: Mon Sep 02, 2024 9:06 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
ok so back to 20 in the front and 29 in the back, that's an easy one.
The torsion arm check adjustment is something I haven't done before. I need to look into this.
Beam is pumped with fresh grease. I typically "replace" by pumping new stuff until it comes out and displaces the old. I want to say that I've done this in the past 6 months...
Thanks!
Anton
Bobnotch
Bobnotch is offline
PostPosted: Tue Sep 03, 2024 3:14 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
I call this the upper arm adjustment, as it'll take away some of the front end shake too. Note; you might have to do it a couple of times (adjust it, then drive, then adjust it) if it hasn't been done in a few years.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
akokarski
PostPosted: Sat Sep 14, 2024 5:12 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
Today I've gone through distributor to make sure there is nothing funny going on. Overall was very clean inside and other than a small mark under the ball it's in good shape.
My injector breaker does have a bit of difference in resistance. 0.1 ohm on one side and .5 on the other
I ended up just cleaning and replacing grease
Vacuum canister lever does drop down under the vacuum but it looks very clean
I was able to give 5 degrees of advance but rpm seems to be wondering. Timing is still spot on though.
Now I am back to getting the stumble out off idle. Right now I am running sealed MPS. Was able to go get gas (20 mile round trip) and it drove pretty well. Although with few backfires when off idle, which sounds like a cracking whip.
akokarski
PostPosted: Fri Sep 20, 2024 8:54 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
Today my new timing light came in, it’s a innova 3568a. I used it to compare the timing and rpm. Sure enough all my multimeters were way off, hence why I splurged on a new tool.
Here are the readings side by side.
And multimeters are wondering by hundreds not a few rpm while the light is steady just moving a few rpm’s here and there.
My timing was at 10 degrees not 5! I was having trust issues since non of the three multimeters were even close, but this is just ridiculous.
Does anyone know why this is happening? The millimeters are all the same model but different brands and non of them are even close.
akokarski
PostPosted: Mon Nov 04, 2024 6:31 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
Hi,
Small update, nothing major happening here other than occasional drive here and there.
a few weeks back I was able to get my AFR gauge replaced with MTX-Pro, turns out the predecessor to this model did have an issue with heater circuit which caused o2 sensors to burn up the heater element. I haven't put on enough miles to rule that out just yet.
Today I did my test drive to work, and we are running 14 on freeway. Down to 11 on full throttle. I think I want to try going back to stock injectors and see how it will behave. There is still a bit of a rich spot on take off.
Funny thing is when I got home, found my coil completely unbolted from the bracket and just sitting on top of exaust. Both bolts holding the clamp to the bracket were gone! Surprised May be I need to take it easy, but it rips in 1st lane even uphill!
Cheers!
Anton
akokarski
PostPosted: Fri Feb 28, 2025 7:44 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
Hi,
Not much has been happening in terms of updates to the fastback. I took a bit of a detour and figured I can get my kitcar in a better shape, it needs quite a bit of work, but I wanted to get it at least fully functional and been spending most of the time on that project...
I recently changed jobs and my office is way out in San Mateo, about 40/45 miles one way commute so I've been staying off driving fastback plus winter. This week however my trucks brakes quickly wore off (never again EBC)... so I had to take fastback. It did not disappoint, my commute is either skyline boulevard (highway 35) which runs along the top of ridge between bay area and coast so even though it's over an hour drive it's over a scenic highway.
Few things for sure, I do need plan on going through bushings and steering and then see how I can get a bit more power squeezed out.
here is my "dreaded" commute
akokarski
PostPosted: Sun Mar 30, 2025 10:51 am    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
Guys,
Need a bit of an input... I am gearing up to do replacement on all body and rear bushings as I can see that torsion bar bushings have failed and same is likely to be true for the rest. I am hoping to improve some ride quality, steering and cornering. I've acquired body bushings set and torsion bar bushings and wondering while I have it all apart, should I swap rear torsion bars and front stabilizer to a thicker ones from a squareback?
I also have a new set of oil shocks all around which replaced gas shocks as the ride was fairly jarring on a rough road, which I think I maybe better off replacing with gas on the rear and koni's on the front?
I want to attain comfy but better handling ride as I have 6 to 10 miles of fairly twisty road with a 2 mile part on really bumpy surface... hence why I am thinking of deviating from stock torsion, stabilizer bars and shocks.
Thanks!
Anton
Scotty D
Scotty D is offline
PostPosted: Sun Mar 30, 2025 8:08 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
akokarski wrote:
Hi,
A beautiful drive for sure. I'm guessing it's a bit more eventful behind the wheel of the Fasty.
Interested to see what type of advice you receive about your suspension upgrades. Staying tuned to this comment section.
Bobnotch
Bobnotch is offline
PostPosted: Mon Mar 31, 2025 10:53 am    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
akokarski wrote:
Guys,
Thanks!
Anton
I don't know if ISP has all of the rear body bushings to rebuild the rear sub, but that's what you'd need.
Yes, I'd go with KYB gas shocks in the rear, and oil Koni's up front. I've found the rear is really the only place for gas shocks on our cars. And definitely oil up front, since our cars are so light there. If you have the time and money, replace the torsion bars on all 4 corners with torsion bars from a Squareback, as they are larger in diameter, along with being stiffer. My wife's 70 Fastback has Squareback torsion bars on it, along with KYB gas shocks on the rear and some Cofap lowered oil shocks up front. With the AT and FI it's like driving a go kart.
Tram wrote:
Tram wrote:
akokarski
PostPosted: Mon Mar 31, 2025 11:21 am    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
Are there thicker torsion bars in the front? I thought it was just the stabilizer that was different on the square
I got full set of rubbers from isp
Bobnotch
Bobnotch is offline
PostPosted: Tue Apr 01, 2025 12:06 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
Yes, the upper bar is thicker. When you tighten the right side, make sure you're not pulling the bar out of the left side, as that can happen IF the grub screw isn't tight.
I don't know if the torsion bars are thicker or not, as I just used an entire Squareback beam on the car (left lower bushing was shot, and it was easier to source an entire beam than the bushings needed to fix it).
Tram wrote:
Tram wrote:
akokarski
PostPosted: Fri Apr 04, 2025 9:42 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
finding squareback bars is proving to be more difficult than it needs to be. Looks like I need to buy a complete front beam and rear subframe. Rolling Eyes
Tram
Samba Socialist
Tram is offline
PostPosted: Sat Apr 05, 2025 12:37 am    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
Hey Gang-
Sorry I have not been on here lately- I have been over my eyeballs in work.
I wanted to pipe in on this as I saw it as I was here trying to source a few missing parts for a Variant engine and auto trans I am balls deep into.
Anton, I probably have everything you need but I would try a different approach first. The reason I say this is because if you removed gas shocks due to a harsh ride- what do you think bigger/ stiffer suspension components are going to do? Smile
Variants/ Squarebacks have the heavier suspension to boost load carrying capacity that Fastbacks, Notchbacks, and Typ 34s do not have the room for.
First- YES, replace all your suspension bushes. Then, do a poor man's corner balance. With the car on level ground measure the distance to the ground at the lower shock mounts. LF + RR should equal LR + RF. If you are a big guy add your weight to the driver's side or have someone else measure while you sit in the car.
Then, adjust the suspension as necessary to get it right or as close as possible. The trickiest trick in your arsenal here might just be to install adjustable spring plates on the rear. This will allow fine adjustments to be made. Remember that bringing the right rear UP brings the left front DOWN, and vice versa for both sides in an X pattern.
Then- check and adjust your alignment as necessary. ANY play in tie rods or ball joints means replace them. Same with your steering gear, rag joint, etc.
You can play with lowering the car slightly and going negative a degree or so on camber for better stability but if your linkage and suspension are both tight with new bushes, all questionable components replaced, and correct alignment/ tire pressure (Remember PSI or bar are constant values no matter the size of tire), and it's balanced, you should notice a HUGE improvement in overall handling and responsiveness.
After that, if you really want it stiffer- then do your Variant parts swap.
Just my two pfennigs.
And now... back to the Gulag for me.
Bryan67 wrote:
Those who can- do.
akokarski
PostPosted: Tue Apr 08, 2025 7:19 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
I want to be clear on the gas shocks, they made ride really unbearable when going over bumps and deeps. The rebound on those KYBs is unholy, you get bump in the road and rebound felt like it was another punch but even stronger. I don't know how wtf that is possible but that's the impression that had from those shocks.
What I want to achieve is a better handling ride and I think thicker sway bar in the front will do that. I also don't want to have to take everything apart twice hence why I am thinking of going with thicker sways. also adjustable konies should give me some adjustability in the front.
Another thing that is really becoming apparent is how weird the steering on the car is. I think because bushes are shot, the whole thing is moving around enough to have toe out etc change as I go through the turns.
Thanks!
Anton
Bloog
Bloog is offline
PostPosted: Wed May 28, 2025 5:35 am    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
Tram wrote:
Hey Gang-
I want it stiffer... Very Happy
Bob Hoover wrote:
Listen to what the ENGINE has to say. It won't take your money and it's incapable of lying. All you have to do is learn to speak its language.
-Bob Hoover
chabanais wrote:
Ah... you buy from Sum Ting Wong Distribution Company.
akokarski
PostPosted: Mon Dec 01, 2025 10:14 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
yes, I am back to looking for the torsion bars and front sway bar. Commute is 1hr+ on mountain roads, need to get this dialed in so I can take full advantage of commute Smile
akokarski
PostPosted: Tue Dec 02, 2025 5:58 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
so looks like I got a set of bars and front stabilizer bar! Now I need to plan how I am going to tackle all of this:
1) all body bushings, front and rear
2) subframe bushings
3) rear torsion bars and bushings
4) front beam bushing
5) front sway bar
6) steering box.
I think engine will have to come out. Which will also be the time to sort out why it is sweating oil and replace some straight fittings with 45s.
I am not sure If I do need to pull the trans, I think I can leave it in as long as I have clutch and shifter disconnected, probably parking brake cables too and maybe brake hoses? I should be able to get new bushings in for the subframe/body.
for tortion bars, IRS arms and plates, I maybe able to pull them out without having to disassemble the axle ends?
Front is a whole another story, I am guessing the beam will need to come out or at least get unbolted to the point where it can be pulled away from the pan to slip in new bushings.. so that means probably getting steering column disconnected maybe even disassembling each side down to spindles?
Cheers!
Anton
Bobnotch
Bobnotch is offline
PostPosted: Wed Dec 03, 2025 12:37 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
Cheers!
Anton
You should be able to do most of the front beam work with it in the car. If you do remove it, look over the "rag joint" over carefully for rips and such, as it is close to 50 years old.
Tram wrote:
Tram wrote:
akokarski
PostPosted: Wed Dec 03, 2025 6:09 pm    Post subject: Re: 1970 Fastback "sympathetic restoration" Reply with quote
Bobnotch wrote:
Cheers!
Anton
Awesome. Rag joint is on the menu as well. I’ve also wondered if, while I have the beam off, if it would be a good idea to fab a spacers for the bottom to increase caster a little bit.
Page 15 of 16
