Handling: How to Make My Bug Take Turns
meet
meet is offline
PostPosted: Mon Apr 07, 2025 8:17 pm    Post subject: Handling: How to Make My Bug Take Turns Reply with quote
This is my garage find 1969 beetle. It had some significant frame head rust issues and now I am doing a full body off restoration.
Goal:
The goal of this project is to make it handle well. I am looking for any setups or tips to make it stick to the turns as well as possible while still maintaining it as a daily driver. I do not mind a stiff ride and really enjoy riding in my friends little hot-hatches (golf gti, ford fiesta, audi tt).
I understand that the stock 1500sp is no powerhouse, but I can always change that later although I doubt it will happen soon.
Basically, I am looking to make this car keep momentum through the turns to help make up for the lack of horsepower; just to have a fun driving experience.
Ideas:
I really like the look of an adjustable beam in the front to just lower it about an inch or so just to level out the front end. I considered lowering spindles, but I think that they are too low for my area, and I don't want to tear up the bottom of my pan. Again, this is still going to be my daily.
Currently I am looking at an upgraded front sway bar and adding a rear sway bar, and will adjust as needed when I get the car together.
Stiffer shocks are definitely in the picture (side note- it came with red napa shocks so I will be testing them before changing them). So, any suggestions on shock setups are welcome.
I want to put wider wheels and tires on it, but I don't want to ruin the playfulness of the thinner ones. I also absolutely hate when tires rub the body, so I need to make sure that doesn't happen.
Camber and toe are definitely an important piece of the puzzle, but that changes for every setup, so numbers are welcome, but I am not focused on that right now. Some negative camber and slight toe-in will be a good starting point.
Kamei front lips also look incredible, and I have seen the data on them, so I will probably add one later to reduce front end float at speed.
Misc.
I have done ALOT of research on this site among other sites regarding this topic. I am happy to look through old forums and pursue other suggestions. This is my first post on here so I am hoping that you guys can help me out.
ANY pictures, suggestions, setups, etc. are welcome!
Thank you!![/b][/u]
rndnoramericaina72poptop
rndnoramericaina72poptop is offline
PostPosted: Mon Apr 07, 2025 8:25 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
Really nice looking stock sunroof 69! It would make a great sleeper with a dual port engine with more displacement. Maybe some 195-65 or 205-70 tires with some KYB gas shocks would do wonders for the handling and on a budget.
65 Porsche 912 project
65 1500S notchback Velvet Green
80 Ford Courier 2.3 5spd LB
17 E-Golf
07 Dodge Sprinter 2500
P.O. of 61,65,66,68,69,70,74 Type I
P.O. of 68,70,72,89,90 Type II
P.O. of 63,64,64,66,68 Type III
P.O. of 70,73,75 914s
P.O. 68 Ghia, 74 Thing
P.O. Renault R8, R10s,R16s
P.O. 78 Fiat 128 4dr, 1200 Cabriolet
P.O. Triumphs 64 TR4 Sebring ed. & 76 TR6
European car enthusiast aka Nutjob
View user's profile Send private message Send e-mail Instagram YouTube Gallery Classifieds Feedback
airschooled
Air-Schooled
airschooled is offline
PostPosted: Mon Apr 07, 2025 9:16 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
If I'm going for some longer drives in the mountains, I'll adjust tire pressure to get a bit more oversteer from my '69 convertible. A larger front sway bar would be the opposite of what you want for spirited driving, while a rear sway bar would help induce oversteer nicely. I have no experience with the shocks you mentioned.
The front seats eventually become the weak link once you've got grip where you want it from suspension mods. It's hard to keep control of a hard corner when your body slides six inches in both directions. Laughing
Robbie
www.airschooled.com
meet
meet is offline
PostPosted: Mon Apr 07, 2025 9:53 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
It is a very nice car... or at least will be once I finish it! Being a college student makes it a weekend only project Rolling Eyes . I will l look into those tire sizes, I know there are a lot of forums here regarding that. I have heard conflicting opinions with those gas kyb shocks, but they do seem to add stiffness so that is good.
1969 Sunroof Beetle "Ivory"
1970 Baja Beetle "Greenbean" (sold)
Check out my progress on Instagram @meetsbeetles
meet
meet is offline
PostPosted: Mon Apr 07, 2025 9:59 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
Robbie
Noted, this is great advice. I have heard that sway bars add traction to the opposite side that they are put on (ex. front sway bar adds rear traction thus taking some away from the front). I do much prefer a little oversteer rather than understeer. Do you have any performance mods on your 69" or is it a stock car? & oh nooo, bucket seats wouldnt be fun at all to install Wink
rosevillain
rosevillain is offline
PostPosted: Tue Apr 08, 2025 8:53 am    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
There are a few companies making and selling coil over a-arm suspensions for the front of beetles.
KTPhil Premium Member
KTPhil is offline
PostPosted: Tue Apr 08, 2025 9:19 am    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
I think all your ideas are good ones, especially for a street car. Better handling will always be more fun than more power.
As posted, be sure to add a rear bar if you also increase front roll stiffness.
A slight lowering of both front and rear can make it stick better. An inch or so is enough for a daily street driver.
Eliminate steering play through the entire path from steering wheel to tires. Adjusting the box can be done badly and wear it out. Check for centering of the BOX, not just the steering wheel, and go from there. THere are several good threads on how to do it right.
Tire pressures make a big difference, too.
You have a great basis with the IRS rear end.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Buggeee
Buggeee is offline
PostPosted: Tue Apr 08, 2025 12:01 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
I have a Super Beetle, with different suspension, but for your standard beetle the adjustable beam plus indexing the rear spring plates will let you drop a little bit in height, lowering the center of gravity.
I have the thicker sway bars front and back. I also have a set of monroe air shocks in the back that I use to tune the rear for the activity. I indexed it down to about 1" away from the bump-stops, then use the air shocks to stiffen from there. About 30 psi for street driving and 60 psi for aggressive driving at the drag strip is what works for me.
The wheels and tires make a big improvement. The stock wheels on beetles are 4.5 or 5.0 inches wide, depending. Most of the aftermarket mags are 5.5 and you can get 5.5 steel stock-looking wheels as well. With the 5.5 wheels and lower height, you go to a lower profile tire so it doesn't rub on the edge of the front fender.
Glenn is a moderator on this site and his red late-model bug will have the tire sizes you are looking for so save some research time, track him down and hit him up for the info. Or just type his name three times and he might appear.
Suhweet Bug!
Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out)
meet
meet is offline
PostPosted: Tue Apr 08, 2025 12:41 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
Eliminate steering play through the entire path from steering wheel to tires. Adjusting the box can be done badly and wear it out. Check for centering of the BOX, not just the steering wheel, and go from there. There are several good threads on how to do it right.
I was able to find this car here on thesamba, and I really like the stance. I will probably go with wider wheels and tires if I find the stock skinnies inadequate. I am really happy with the IRS rear end as well as the no rear quarter vents. IMO the 69' and 70' are the absolute best years minus the cruddy H block engine cases.
[/quote]
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Apr 08, 2025 12:58 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
My car handles like it's on rails, so here's what I did.
Front: dropped 3" with AVIS adjusters, 19mm sway bar, KYB GR2 low pressure gas shocks (2' shorter Opal GT), 15x5.5 alloys with BF Goodrich gForce 195/55-15 tires
Rear: dropped 1", 25mm sway bar, KYB GR2 low pressure gas shocks, 15x5.5 alloys with BF Goodrich gForce 205/60-15 tires
Mounts: Type 2 transaxle mounts, Berg rear engine support, Berg front transaxle mount
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
meet
meet is offline
PostPosted: Tue Apr 08, 2025 2:29 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
Ah, the elusive Glenn, perfect timing. This is exactly what I was looking for, a tried-and-true setup on the same platform I have. I do have a few questions for you though, thank you for taking the time to respond to my thread.
1. Do you have any caster or otherwise negative suspension effects (like bump steer) with the Avis style adjusters? Are you running caster shims?
2. Do you rub at all with that ride height and wheel/tire setup?
3. Are the additional transaxle supports necessary for a stock engine? I will be installing CB rhino mounts but can add some more additional mounts like you did to strengthen it up.
Those pictures are super helpful, you have a really slick ride!
Mr. 010
Glenn is offline
PostPosted: Tue Apr 08, 2025 2:57 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
Single shim under the lower torsion tube. Steering is like stock.
No rubbing, but the alloys are real Porsche 914 so they have a deep offset.
Not needed for stock.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
johnnyvw164
johnnyvw164 is offline
PostPosted: Wed Apr 09, 2025 2:04 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
This is a good book to learn the basics of vehicle dynamics:
Mr. 010
Glenn is offline
PostPosted: Wed Apr 09, 2025 2:13 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
I don't think a Beetle will ever handle like a Porsche 935 Wink
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
NJ John
NJ John is offline
PostPosted: Wed Apr 09, 2025 5:23 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
True, but they can look as good.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
73stroker
73stroker is offline
PostPosted: Sun May 18, 2025 2:58 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
Awesome, I'm down this evolutionary path myself,
Front
lowered 2 1/2" dropped disc
narrowed 2" beam
single caster shims on lower
KYB 344098 front shocks
3/4" sway bar
185/60R15
Rear
rear dropped 2 1/4
truss bar
195/65R15
The wheels are Rivera's from the 80's that I buzzed off that rise on the spokes and had them powder coated... did that many years ago, really like the 914 2-litre wheels on Glenn's car.
Feels pretty good, I may be a 1/4" too low in the back, no rubbing and handles pretty good, still need to tweak it a bit and think about a rear sway.
Engine wise, pretty stout with a 2276cc, L6 DRD heads, sidewinder, dual 44's, XR-302 cam 1.4 rockers, runs pretty good.
[/img]
1973 standard Type 1
2276cc
DRD L6 heads
A-1 Sidewinder
Zebedee
Zebedee is offline
PostPosted: Mon May 19, 2025 4:28 am    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
My 1970 handles pretty well on mostly stock suspension.
Its got cheap KYB gas adjust shocks on the rear and stock oil shocks on the front.
Lowered a little at the rear to remove positive camber (its a UK bug so we still had swing axle rear suspension until end of production).
Its running factory spec alignment apart from the slight 0.5 degree negative rear camber.
Front lowered an inch or so on a stock width puma beam, stock front sway bar.
I tried loweering it more at the front but had tyre to wing contact with the wider wheels.
5.5" empi 8 spoke replicas with 185/65/15 all round with pressures at 18f/27r.
Its got a Kamei front spoiler which seems to work well at cutting wander in headwinds.
If you do things right, people won't be sure you've done anything at all.
meet
meet is offline
PostPosted: Thu May 22, 2025 8:21 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
73stroker wrote:
narrowed 2" beam
I feel like narrowing the stance would hinder handling a bit, but I guess it is necessary to fit wider tires up front.
I also like the 914 wheels but cannot find a set of decent ones.
chicagovw
chicagovw is offline
PostPosted: Fri May 23, 2025 12:04 am    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
Have you considered going all stock but properly done stock? I agree that your ideas and those from others on here can definitely help improve handing, but most any mod will come at a cost...VW engineers, by the time your car was made, with its ball joint front beam and double jointed rear axles, had developed the Beetle into a car that was pretty well balanced-good handling, good ride, good brakes, decent power with still very good fuel milage, and very long engine life with regular maintenance.
If you add stiffer shocks, you will get a stiffer ride-which I know you said you don't mind. If you get wider tires, you will get heavier steering. And so on. Again, not telling you NOT to make mods-it is your car of course and you should make it fit your wants. But I have seen many folks do mods to try to improve when all the car needed was for things to be done correctly. Just a thought, and again, do as you wish of course ( I own both stock and modified VWs myself).
meet
meet is offline
PostPosted: Mon May 26, 2025 7:06 pm    Post subject: Re: Handling: How to Make My Bug Take Turns Reply with quote
I can definitely appreciate this comment from you as I typically believe the same thing. They absolutely had the car figured out, especially by 69', but this is for the everyday consumer. Because most of the stock parts on my car are in good shape, I am simply restoring my car back to stock specs (other than an adjustable beam and 0.5deg of spring plate indexing to lower slightly aforementioned). This is mostly due to the fact that I want to feel how each mod affects the handling of the car and really dial it in according to my liking. I still want a playful bug that makes a good daily, but part of that is trying new things.
Basically, restoring my car to complete stock, and then adding handling mods that you guys have mentioned here to taste Wink .
