Ant.Tor135 Samba Member
Joined: February 07, 2025 Posts: 14 Location: Arizona
Posted: Mon Feb 17, 2025 9:09 am Post subject: Need advise on rear suspension (Sandrail) |
| I'm looking to get some advise on my rear suspension. I purchased a sandrail a couple months ago. It has the 26-9/16 torsion bars, and I'm looking convert it to the 21-3/4. The endcap sticks out in front of the tire so I want to remove it so I can run bigger tires. The question I have is, what size torsion bar should I use? It's a 4 seater frame with a Ford 2.3 lima and an IRS transmission. It's heavier that a VW engine so I assume I need ticker torsion bars. It likes to bottom out on medium size bumps. I'm not sure if it's the struts that are the issue. It has sway-a-way struts the he said were redone not to long before I purchased it. I'd appreciate any advise. |
DHale_510 Samba Member
Joined: August 27, 2010 Posts: 418 Location: Nampa Idaho
Posted: Mon Feb 17, 2025 10:05 am Post subject: Re: Need advise on rear suspension (Sandrail) |
The long torsion bars and caps are for the IRS suspension. The short torsion bars and caps [the caps are the whole spring plate] are for the swing arm suspension. Parts do not easily cross over, the spring plates are different lengths. Special spring plates are available to make the conversion.
Torsion bars are made in mm diameter increments. You likely have the stock 22mm ones. Each mm adds about 20% spring stiffness.
I suppose your "struts" are really shocks and they are not springs, They slow the travel and absorb rebounds. Stiffer springs [torsion bars] need stiffer shocks to match.
Changing tire diameter changes gearing quickly, a 10% larger tire diameter slows the engine 10%. This may be a problem, it usually is.
Changing the trailing arms is common, they are longer and wider and will change the tire clearance but will also change the leverage. Common 3x3 arms need a 3 or 4 mm torsion but will clear most any tire and wheel choice.
Nothing is as easy as we wish,
Dennis |
Posted: Mon Feb 17, 2025 1:35 pm Post subject: Re: Need advise on rear suspension (Sandrail) |
| DHale_510 wrote: |
Dennis |
I was able to find a spring plate to make the conversion. I was looking through the forums here for suggestions and found one on Apple Tree. I haven't had a chance to take off the spring plate to see what size the torsion bar thickness is. I'm doing more research and looking at getting the "chickens foot" (I think is what they call it) so I don't lose any fingers. I'm only going up an inch on tires so I hope it doesn't affect it much. It seemed easier (mainly cheaper) to do the spring plate conversion. I will have to look into what it takes to do the trailing arms. I haven't seen anything about that on the forum, probably because I wasn't looking for it. Thanks for the info! |
DesertSasquatchXploration Samba Member
Posted: Mon Feb 17, 2025 3:23 pm Post subject: Re: Need advise on rear suspension (Sandrail) |
You can run 31inch tires with the long IRS torsion bars. I don't think a N/A pinto engine will turn any bigger or need to. What is the issue your suspension is to soft and you want bigger Tires? Or is it a turbo and you trying to pop wheelies with a four seater buggy. or your not happy with the gearing?
Ive seen 4 seat buggy's tear it up with skinny 31inch paddles no problem.
The BILSTEIN 24006347 is a great shock
Or on a budget KYB KG5529 is not bad.
Both are a Monotube design will stiffen the suspension. Over the cheap (twin tube shocks) |
Posted: Mon Feb 17, 2025 4:17 pm Post subject: Re: Need advise on rear suspension (Sandrail) |
| DesertSasquatchXploration wrote: |
Ive seen 4 seat buggy's tear it up with skinny 31inch paddles no problem. |
I purchased these 32" CST paddles that was too good to pass. I was hoping to run those but the torsion bar gets in the way. If I can't make them work, I'll just resell them and get 31" paddles. Also, I tend to bottom out on some bumps. I don't know if the torsion bars are too weak or if the shocks are too weak. I figured I'd stiffen the suspension while I'm changing stuff out. But I don't want to go to stiff and end up bouncing around like a pogo stick. I do eventually want to upgrade my carb to an EFI down the road. The EFI kit will let me add a turbo which was my plan from the start. But that's for later when I save up enough. I was looking for info on what size torsion bar would be a good size to go with. I'm looking at converting to the shorter torsion bars but don't know what size to go with. I was reading that most go for a 24-26 mm with a 4 seater sandrail. I was thinking to start there. |
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4627 Location: Fair Oaks/Orangevale, CA
Posted: Mon Feb 17, 2025 5:16 pm Post subject: Re: Need advise on rear suspension (Sandrail) |
Knowing what the buggy weighs is ideal to being to suggest correct torsion bar size.
with the extra engine weight like the suggestion of 24-26mm, me I 2ould go with the 26mm being it is a 4 seater.
Also know that the aftermarket spring plates are a 1.2in wider across the face so you end up with less travel between the stock spring plate stops. Either grind the stock spring plate stops top and pbottom or notch the spring plates to clear the stops. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Mon Feb 17, 2025 6:24 pm Post subject: Re: Need advise on rear suspension (Sandrail) |
| jsturtlebuggy wrote: |
Also know that the aftermarket spring plates are a 1.2in wider across the face so you end up with less travel between the stock spring plate stops. Either grind the stock spring plate stops top and pbottom or notch the spring plates to clear the stops. |
That's good to know. I wasn't aware of the width difference on the other plates. It only gave measurements for the length. Thanks for the info! I think I'll try going for the 26mm since we always have 2 or 3 people riding at a time. I'd try the 24mm but I rarely ride alone |
BFB Samba Member
Posted: Mon Feb 17, 2025 7:24 pm Post subject: Re: Need advise on rear suspension (Sandrail) |
Upfront cost would be more but considering the time & effort in jacking with the torsion bars i think id just convert to coilovers. Be easier to change spring pressure and set a ride height you’re happy with. Since its stock IRS you wouldnt even have to go long travel , speedway motors sells coilovers that arent that expensive.
I’ve jacked with trying to keep torsion bars and using 3x3’s and it was a pain in the ass. Too soft, ride height still to low, now the ride height is too high, oh this is good… until the torsion bars set and you wish youd have left them at the too high point. And each time to have to take the torsion set up apart to adjust everything and sometimes the torsion bar comes out of the spring plate other times it come out of the inner collar.
And youd loose the torsion bar so you could run those 32’s.
I think that Lima will have plenty enough torque for them. What trans is in your buggy OP? _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
Posted: Mon Feb 17, 2025 8:46 pm Post subject: Re: Need advise on rear suspension (Sandrail) |
| BFB wrote: |
I think that Lima will have plenty enough torque for them. What trans is in your buggy OP? |
I'll have to keep that into consideration. I did like the idea of coilovers. I saw a conversion plate the covers the torsion bar opening and lets you bolt/weld a spring plate to it to eliminate the torsion bar. Only thing is that the previous owner installed taller shocks on the sandrail. The upper mount lands about 3/4 of the bar that leads to the roof, about 36" extended. I wish I could figure out how to add photos to show how the sandrail looks. I couldn't find any coilovers that tall at Speedway. I'm still looking at other sources but seems King is the only one I found with coilovers that tall. As far as the transmission, he told me it was a VW Type 1 transmission with Weddle internals. |
Posted: Thu Apr 10, 2025 9:36 am Post subject: Re: Need advise on rear suspension (Sandrail) |
| Alright, so I decided to go for the coilover conversion. I ran into a little problem while putting everything together. Sorry, I'm new to this so I'm learning as I go. The coil spring rubs on the tire with the coilovers. I want to run a wider stance on my rear trailing arms like someone suggested before. I found some 2x2 rear trailing arms for sale nearby. I was thinking of going 3x3 but I don't think it will fit in my trailer with the 3x3 and offroad tires it has on. I was just wondering what axles I would have to run for the 2x2? Someone posted a picture on a separate conversation of axle sizes for different size trailing arms by DuneBuggyWarehouse. Unfortunately the 2x2 is not listed. Someone else was asking if the can use the type 2 cv axles from a bus with a 2x2, but it wasn't a clear answer. Can I use the type 2 axles on my type 1 transmission? Will that be long enough or do I have to look at getting custom axles from sway-a-way? |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 3720 Location: West Coast (Michigan's)
Posted: Thu Apr 10, 2025 11:15 am Post subject: Re: Need advise on rear suspension (Sandrail) |
Changing to a rim with more offset might be an easier solution to the rubbing.
Just a warning; while it is easy to get caught up in modifying things, be careful not to changeso much that you lose sight of your intial goal and start to create new problems. Having said that, I don't practice what I preach so have at it! lol _________________ Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes |
Posted: Thu Apr 10, 2025 12:29 pm Post subject: Re: Need advise on rear suspension (Sandrail) |
| ORANGECRUSHer wrote: |
Just a warning; while it is easy to get caught up in modifying things, be careful not to changeso much that you lose sight of your intial goal and start to create new problems. Having said that, I don't practice what I preach so have at it! lol |
I did not even think about that. Thanks for the input. That would be an easier solution than upgrading the trailing arms. My rims already have some offset, but I don't know the exact offset (There's about 3in between the hub and front of the rim). I'll see what I can find as far as more offset. Oh, and fair warning. I do tend to go overboard sometimes, lol |
Posted: Thu Apr 10, 2025 12:46 pm Post subject: Re: Need advise on rear suspension (Sandrail) |
These are the wheels I'm running right now. I bought it with these so I'm not sure of the offset. Anybody have any problems running a bigger offset? I feel like this is as much as they would go. |
Posted: Thu Apr 10, 2025 1:19 pm Post subject: Re: Need advise on rear suspension (Sandrail) |
Have to look at the backside. If the back is shaped like the front then you have about three more inches to play with. Back in the day real men would cut the star out and weld it in where they wanted it. You need to measure your exact back space or offset and then start shopping and comparing. The aluminum rims I just got with my paddles seem like the offset is right up to the edge.
A larger offset can cause there to be more 'stress' on the hub bearings. Instead of the weight being supported directly under the hub, it gets moved outward and you can imagine the sideways forces trying to rip that rim away from the hub. That being said, I've seen a lot of really nice rigs with max offset doing just fine. You can see the brakebacking plate poking out the backside of the rim. If you've got swingaxle then it will exaccerbate tire wear on the outsides and probably flex the sidewall even more. You will gain a little more stability with the wider track and the steering may be less touchy depending on the width of the front end.
That is all hypothetical and your results may vary. There are guys a lot more experienced with this stuff than me. _________________ Brian H.
BFB Samba Member
Posted: Thu Apr 10, 2025 4:57 pm Post subject: Re: Need advise on rear suspension (Sandrail) |
As far as your question on cv’s , yes you could use T2’s, you COULD use T1’s if you wanted… your limited to 17 degrees of travel with T2’s vs 25 degrees from 930’s. All depends on what you want out of it. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Posted: Fri Apr 11, 2025 7:17 am Post subject: Re: Need advise on rear suspension (Sandrail) |
| BFB wrote: |
| As far as your question on cv’s , yes you could use T2’s, you COULD use T1’s if you wanted… your limited to 17 degrees of travel with T2’s vs 25 degrees from 930’s. All depends on what you want out of it. |
That is good to know, thanks for the info. I don't think I'll need the extra travel as of right now. I plan to run stock height at the moment, at least for now until I save up to upgrade the front suspension. The extra travel and height will help out later on in the future. I want to be able to take it on trails as well as the dunes |
Schepp Samba Member
Posted: Fri Apr 11, 2025 7:24 am Post subject: Re: Need advise on rear suspension (Sandrail) |
All this to run 1” larger paddles?
I’d sell them and get 31” paddles. Faster, cheaper, easier.
Get some new stiffer shocks and call it a day.
You’re going to be down on power with the larger paddles. Which you don’t want in the sand.
I’d focus on the engine first. Build it to run bigger tires.
Itll look cool but won’t perform like you want it to. |
Posted: Fri Apr 11, 2025 10:28 am Post subject: Re: Need advise on rear suspension (Sandrail) |
| Schepp wrote: |
That would of been easier honestly. I did decide that I'm changing the engine soon. I wasn't too happy with the carbureted lima engine it had when I bought it. It bogs out on some bumps so I was going to convert it to EFI, but I might of pushed it too hard on my last trip. I might of wore out a piston ring (hopefully no damage to to cylinder wall), It's smokes from the oil fill and dipstick. It's just sitting now so I'm just gonna rebuild it until I can afford the ecotec swap or it blows up (I put a lot of money on the MSD ignition system and distributor so Imma get my money's worth out of that engine). I figured I'd get the suspension figured out while it sat since it also bottomed out a lot, which is why I wanted the coilovers. I wanted more adjustability and for a more comfortable ride. I know I could of bought a sandrail with all of these to avoid the extra work, but I wanted something I could work on, and I didn't have 10-15k for the nice ones being sold here at the time. I got the paddles for cheap and I didn't want to spend a lot of money on paddles that I won't use too often, so I'll see how the ecotec handles the 32s, if not I'll swap them for the 31s. I'm building it so I can take it on the trails here mostly and occasionally the dunes. It's a 4 hour trip to the nearest dunes so I can't go too often. Sorry, I should of probably stated that from the beginning, but I feel like I ramble too much sometimes. I'm just building and learning as I go. |
Schepp Samba Member
Posted: Fri Apr 11, 2025 11:08 am Post subject: Re: Need advise on rear suspension (Sandrail) |
I recommend writing on paper everything that you want to do the car and decide on what is priority.
It sounds like you don’t really have a plan. This is how people’s projects don’t get finished.
Blowing a bunch of money on the suspension first without having a solid reliable power plant is not advisable.
Swaps aren’t as straight forward as they seem and have a lot of underlying costs. When was the last time you read a fully detailed write up on a T1 to anything swap with a list of all components and true cost?
Swapping trailing arms opens up the worm can even further.
Shock mounts, axles, cv’s, bearings, limit straps, coil-overs, fabrication, welding, etc.
Depending on your coilovers you could easily be in $2k+ just for the rear suspension and driveline.
What about the front?
Where does it end?
Then you still have to sort out your engine woes.
Make a plan. Seriously.
My Baja took 6 years and $10k to complete with a plan. Stock to now. Still not fully finished. |
Posted: Fri Apr 11, 2025 3:41 pm Post subject: Re: Need advise on rear suspension (Sandrail) |
| Schepp wrote: |
Where does it end?
True, I really should write down the stuff I need to do. I'm still doing my research on the trailing arms, but I'm still looking for wheels with more offset like orangecrusher suggested. As far as the engine, I found the ecotec swap to be the easiest. There's a couple youtube videos on it, even one where the guy goes in depth of the costs. If theirs something that I'm doing wrong or that I missed, if you could point it out I'd greatly appreciate it. This was originally my thought process.
I found a local junkyard selling a 2.2 ecotec for $400 (80k miles so luckily low miles), Kennedy makes the adapter plate for around $600 depending on the source (I might special order from them since they ask for vehicle specs for more accuaracy), I found a company that makes a standalone harness with a tuned pcm for around $800 that will let me wire my electric fans to it's fuse box (mine are on a switch at the moment), I found a company that makes a ecotec exhaust for sandrails for $700 and a fuel pump for the ecotec for $180. Imma reuse my radiator, I'll just have to redo the plumbing. Theirs a couple misc. parts that I'll need so I'm assuming around $3000. Now, I wish I had 3k to drop on this car but I don't right now. Luckily I'm single and have no kids at the moment (not that that's a bad thing), so I have some spending money after my bills and savings every month and plenty of time to waste. That's why I figured I'd start on my suspension first (maybe not the brightest idea). I figured I could change out the spring rate to make up the difference in the weight of the ecotec engine. I ended up getting coilovers and springs for $1200 last month to start off, I did have to had a buddy weld a new mount for the coilover (cleaner look and a better angle) and got the torsion delete plates for $200. I found a guy selling 2x2 for $200, I'll just need to replace bearings and seals that I found at appletree for around $100. Theirs a store nearby that makes custom brake lines but I haven't looked into them yet, mostly because I don't know if I'm going for the 2x2s yet. So, I'd say you're right about the 2k for the suspension. I haven't found any wheels that I can run and I don't think I'll get them for cheaper than $300. I was going to buy 1 component each month and start building it little by little when everything starts piling up (technically don't need the exhaust or coolant to fire up the engine to make sure it runs, but it will be loud). But I'll save that for later when my engine no longer runs. It might be old, but it's still kicking surprisingly, the transmission too. The front I'm still debating. I don't know if I only want to make it wider and keep the torsion or if I want to do coilovers in the front as well. They have both conversion options on appletree. The front wasn't giving me any issues that I was able to notice, but that might change with the modified rear. I'm still new to this so I don't know if I'm just getting ahead of myself, but this is where I decided to start. Sorry, this has completely sidetracked from my rear suspension. |
