aereo-van Samba Member
Posted: Sat Apr 12, 2025 10:17 pm Post subject: Aftermarket ATF dipstick? |
Is there any reason an aftermarket, machined, flexible trans dipstick could not work on the Eurovan trans?
The male aluminum piece could be machined to fit in the trans fill hole and I’m assuming you could calibrate the correct length dipstick to coincide with proper fill level.
Not necessarily this exact one, but something like it:
https://www.summitracing.com/parts/lok-ed-5014?rrec=true
Anybody know the diameter of the fill hole? _________________ 2003 Eurovan MV |
VanGeek Samba Member
Joined: September 25, 2022 Posts: 354 Location: New England
Posted: Tue Apr 15, 2025 9:42 am Post subject: Re: Aftermarket ATF dipstick? |
Great question -- curious if something like this is possible.
If not --there's probably not a ton of demand but a machine shop might be able to fabricate a mount, bend the tubing, etc or modify/repurpose another dipstick.
But would need all the specs on one that fits.
(and I don't have one). |
vwplenty Samba Member
Joined: September 02, 2020 Posts: 13 Location: SF Bay
Posted: Tue Apr 15, 2025 10:44 am Post subject: Re: Aftermarket ATF dipstick? |
I made a eurovan transmission ATF dipstick with the transmission fill-plug, a PVC fitting from home depot and a dipstick from a local auto parts store. A bit of automotive grade silicone glue in the PVC fitting holds it together. Drill a hole in the fill plug for the dipstick.
/Robert
Endopotential Samba Member
Joined: February 13, 2012 Posts: 297 Location: Just outside SF, CA
Posted: Tue Apr 15, 2025 12:38 pm Post subject: Re: Aftermarket ATF dipstick? |
That's brilliant! Now on my short list of upcoming projects.
So much easier than jacking up the car, then running back and forth to check transmission temps and do the fluid top offs. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11114 Location: Oregon
Posted: Tue Apr 15, 2025 1:44 pm Post subject: Re: Aftermarket ATF dipstick? |
Robert (vwplenty), What year EV did you perform the dipstick modification on? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Tue Apr 15, 2025 6:51 pm Post subject: Re: Aftermarket ATF dipstick? |
This ATF dipstick was made for a 2002 AXK 24v. The length is 14.5 inches. You still need to acquire a dipstick tube for this to work.
I made it many years ago and it was probably this one:
"Spectre Performance SPE-4255 Chrome Oil Dipstick"
You need to calibrate and mark the dipstick after the normal refill procedure. At 110 Degrees you can can still hold you hand on the transmission pan. You can also make a mark for operating temp (hot) like the old American cars had.
/Robert |
Posted: Wed Apr 16, 2025 9:27 am Post subject: Re: Aftermarket ATF dipstick? |
Thanks. $12.99 at AutoZone is cheap!
I might do this dipstick upgrade. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Tue May 20, 2025 11:19 pm Post subject: Re: Aftermarket ATF dipstick? |
If anyone else has worked on this, I'm wondering about the suggested length of 14 inches for the dipstick. I've also got a 2002 EV.
On mine, it's only 7 inches to the bottom of the transmission pan.
Re-reading VWPlenty's message above, looks like you also need a metal extension tube to bring it within reach, and not directly attached to the OEM black cap as pictured.
Otherwise the top pull ring seems to bang up against the starter. But if I cut off the ring, it would be harder to pull out the dipstick.
Also realized that the utility of this project is marginal. Unless it's lengthened, the dipstick is so far down there's no way you can access it from the top of the engine. Which means you still have to drop the bottom pan to get to it. So it's not exactly easy to check a frequent intervals, as you would with the oil dipstick.
But it does give you a means of checking the transmission fluid level, short of warming up the engine and doing the whole overflow routine.
Last edited by Endopotential on Wed May 21, 2025 9:57 am; edited 1 time in total |
kourt Samba Member
Joined: August 13, 2013 Posts: 2322 Location: Austin, TX
Posted: Wed May 21, 2025 4:18 am Post subject: Re: Aftermarket ATF dipstick? |
Just as a consolation, the genuine dipstick is not easy to use. It does have a tube that puts it higher in the engine bay, but it's still a chore to get to it. Have fat forearms or large hands? Forget it.
kourt |
HeyCrutch Samba Member
Joined: August 12, 2022 Posts: 431 Location: Asheville, North Carolina
Posted: Wed May 21, 2025 6:21 am Post subject: Re: Aftermarket ATF dipstick? |
From a listing in the classifieds, if you're still interested in what the true A/T fluid dipstick looks like:
https://www.thesamba.com/vw/classifieds/detail.php?id=2579104 _________________ -2003 EV MV Wk - Forest - 51k
-2002 EV Camper - Ghost - 82k
-2003 EV GLS - Fluffhead - 176k
-1997 EVC - 12vVR6 (SOLD 5/2025) |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2721 Location: Ocean Beach - San Diego
Posted: Wed May 21, 2025 9:12 am Post subject: Re: Aftermarket ATF dipstick? |
I bought that kit years ago.
GoWesty used to sell them but the supplier (supposedly) ceased making them.
I found a shop in San Luis Obispo that brought out all the remaining stock and I got one from them. A local shop installed it -- ~2 hours shop labor as I remember. It is so far down and hard to reach that it is of little use to me. The current shop I use was quite happy to see the dipstick the last time they serviced the A/T fluid and filter. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for. |
Posted: Fri May 23, 2025 8:23 pm Post subject: Re: Aftermarket ATF dipstick? |
Chalk this up as some wasted money on a failed science project.
The black fill tube just sits too high, such that anything attached to the top just hits the starter. I tried bending the dipstick tube to accommodate, but the tight turns made it too hard to get the dipstick down. And as others have pointed out, it's just too deep down to be accessible from the top of the engine bay.
So if I ever drop the transmission pan again, maybe I'll play around with shortening down that fill tube. But for now I'll just be happy with a working transmission. |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 844 Location: Tucson, AZ
Posted: Thu May 29, 2025 5:46 pm Post subject: Re: Aftermarket ATF dipstick? |
How about installing a sight glass on the side of the pan with a peek-a-boo hole in the skid plate? _________________ 1991 tin top GL
Some BMWs. |
Posted: Sat May 31, 2025 12:34 pm Post subject: Re: Aftermarket ATF dipstick? |
That would be cool but likely completely infeasible.
The transmission pan is nowhere thick enough to drill/ tap through securely. And no way I'd trust a glue to secure a sight glass with all that heat.
It would just take a leak or the sight glass to pop off, for all your transmission fluid to disappear and destroy things in the middle of nowhere. |
