Replacement automatic TCU without the exact same part number
Zebedee
Zebedee is offline
PostPosted: Tue Apr 15, 2025 7:25 am    Post subject: Replacement automatic TCU without the exact same part number Reply with quote
This has had me wondering for a while now.
I've read that you need the exact same part number on a replacement TCU for it to work properly, but why? I've searched online and not come up with a definitive answer. Hell, even my local vw main dealer have no idea.
What is it that would stop a replacement automatic transmission control unit (TCU) from working properly if one without the exact part number was used?
I assume one from a diesel wouldn't work on a petrol van due to differences in inputs from the engine or different engine characteristics.
So let's say the engine code was the same (AAF 2.5 petrol as an example).
Would it matter if the final drive ratio in the transmission was different as there seems to 3 different ratios available for the same year and engine all with TCUs with different part numbers. I assume it would give change points at different revs. But would it still work?
What about actual different gear ratios, as it looks like the pre 1993 transmissions used a different 2nd and 4th gear ratio?
Also pre 1993 vehicles have the sport mode switch on the dash with later ones having the TCU that controlled the driving modes through adaptive learning.
I assume that would confuse the TCU too.
I'm struggling to work out which TCU will actually work on my van as the original part number 098927731G just doesn't exist.
If you do things right, people won't be sure you've done anything at all.
67rustavenger
67rustavenger is offline
PostPosted: Tue Apr 15, 2025 9:19 am    Post subject: Re: Replacement automatic TCU without the exact same part number Reply with quote
As a suggestion, reach out to German Transaxle of America for TCU replacement information. Ask the receptionist to connect you with Ken.
https://www.germantransaxle.com/
When I had my 2003 EV there for a trans rebuild, one of the services offered, if required was, in house rebuild of the TCU. Luckily mine was ok.
Maybe they can help you with a few examples of compatible TCU's.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
EuroTec
EuroTec is offline
PostPosted: Tue Apr 15, 2025 6:52 pm    Post subject: Re: Replacement automatic TCU without the exact same part number Reply with quote
A different one won't work right. It may allow the car to move but it will be off in many ways and shift erratically.
I've tried it.
What about this unit?
https://www.ebay.com/itm/373788578893
If it ain't broke, don't fix it!
View user's profile Send private message Twitter Instagram Gallery Classifieds Feedback
Zebedee
Zebedee is offline
PostPosted: Wed Apr 16, 2025 3:57 am    Post subject: Re: Replacement automatic TCU without the exact same part number Reply with quote
I've tried it.
Thats for the right year but the part number says its off a 2.4 diesel unfortunately.
After talking to a few ECU repair shops they all reckon my TCU is beyond repair. Sad
Theres so little info online about the automatic boxes. Managed to find bits and bobs off a number of different sites.
It appears before chassis number/VIN 70-P-069 567, which is the end of 12/1992 the gearbox was an 096 code which is the same type as the golf and passat uses, and they had the sport button on the dash.
After 01/1993 the 2nd and 4th ratios were changed when the 098 code transmission (i assume its a slightly uprated 096) was used.
01/1995 is when the 01P was used with the 68 pin TCU.
So it looks like i'm searching for a TCU for a transmission made between 01/1993 and 12/1994. A pretty short window.
The only TCU part number i can find for the exact year and engine and gearbox codes is 098927731R.
098927731T is for same year and engine but a different gearbox code (it has a slightly lower final drive ratio).
098927731AC is the right year and gearbox but the later ACU 2.5 petrol. Not sure if theres a difference in the signals the TCU would get from AAF vs ACU.
Zebedee
Zebedee is offline
PostPosted: Tue Apr 29, 2025 4:36 am    Post subject: Re: Replacement automatic TCU without the exact same part number Reply with quote
Looks like i'm back to the stage i was a couple of months ago.
The T suffix TCU i got turned out to be a unit from a 1991 passat with a part number starting 095 and won't work properly. Sad
I found a slightly earlier TCU in the UK (it was new from VW Classic and has only been used for 20 miles).
Comparing the wiring diagrams, the early TCU (in a van with the Sport switch) just has a single wire from terminal 36 that goes to the sport switch, then theres two wires from that switch to the PNP relay's terminals 5 and 7.
Terminal 5 on the PNP relay is also linked into the multifunction switch on the gearbox (and the fuse for reverse lights).
In the later (01/1993>) TCU the wire from 36 just goes to the 10-Pin Connector, somewhere behind instrument panel, with the wire not going to anything from there. Its the same connector the OBD socket and other stuff is wired to.
Shouldn't be too difficult to just add a new terminal to that plug, though I honestly can't see there being any problem with not having the switch as everything else is wired the same.
Zebedee
Zebedee is offline
PostPosted: Tue Apr 29, 2025 12:02 pm    Post subject: Re: Replacement automatic TCU without the exact same part number Reply with quote
Seems the reason the earlier (pre 1993) TCU really doesn't work properly with later (post 1993) gearbox is that VW changed the valve body and solenoids slightly at the same time and the later TCU can't supply the correct signals to the early solenoids. Sad
