Engine Pops/Backfires at Higher Speeds After Major Tune-Up
sjmcbride
sjmcbride is offline
PostPosted: Thu May 01, 2025 1:23 pm    Post subject: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
Hey guys,
I’ve been working on restoring my 1973 VW Type 2 Automatic (Bay Window) Microbus with the 2.0L Type 4 engine (engine appears to be an 1976) and 003 automatic transmission. I’ve made some solid progress, but I’m hitting a wall and would love your insight.
Original Setup:
• Old Dual carbs (previous owner had them installed)
• Old vacuum modulator for the transmission
• Speedometer and wiring had issues
• Engine idled poorly, died within seconds, shifted rough, and struggled on hills, lots of engine and transmission leaks.
Recent Changes/Upgrades:
• Installed new Redline Weber 40 IDF dual carburetor kit
• Replaced the alternator (upgraded to 75A)
• Replaced the transmission vacuum modulator
• Cleaned and reinstalled vacuum lines (including transmission line)
• Redid all engine and transmission seals and gaskets
• Installed brand new battery and verified voltage
• Speedometer was stripped — I fixed it with epoxy and it works great now
Current Symptoms:
• Idles much better than before — now lasts ~10 minutes before dying (used to die in seconds)
• Shifting is smoother but still a bit hard
• The big issue:
When accelerating past ~30mph, the engine starts popping (like a backfire), and really struggles to climb speed.
The faster I try to go, the worse it gets — sounds almost like it’s misfiring or running lean under load.
Here’s a video of what’s happening (acceleration sound):
[youtube]
https://youtube.com/shorts/PsoT0R2IfRA?si=FFNapGyXpHu72jO_
[/youtube]
sjmcbride
PostPosted: Thu May 01, 2025 1:23 pm    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
My guesses so far:
• Timing might be off? I tuned the new carbs per the manual but might be doing it wrong.
• Possibly running too lean?
• Carbs need syncing or jetting tweaks?
• Weak spark or coil breakdown under load?
Would love to hear what you guys think. Appreciate any advice or things to check next! You guys have helped me a ton so far with this thing
sjmcbride
PostPosted: Thu May 01, 2025 1:24 pm    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
Forgot to add, when I put it in Drive or Reverse it still dies in seconds. When in Park or Neutral it lasts 10minutes or so
67rustavenger
67rustavenger is offline
PostPosted: Thu May 01, 2025 1:49 pm    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
Popping out of the carbs would be a lean condition.
Popping out the exhaust would be a rich condition.
The carbs sound like they are fairly well synced. But may need a little syncing after you get the jetting sorted, IMO.
What is the carb jetting?
What is the engine timed at?
An auto trans likely needs a little higher idle speed to keep it from dying when shifting into forward or reverse gears.
I have no experience with an auto trans in a bus. I'm just thinking out loud.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
SGKent Premium Member
SGKent is offline
PostPosted: Thu May 01, 2025 3:17 pm    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
if the popping is under sustained load and not when shifting, I would vote for too lean, but if it is excess fuel hitting the air and burning then yes it could also be too rich. Your pump may not be keeping up with the flow needed, the floats may be too low, or the jetting may be wrong.
Last - make sure that you do not have a rev limiting rotor on it and that the ignition system is in good condition. It can also be valve float from weak valve springs if it is only happening at the higher RPMs.
With the low cost of air to fuel gauges, I would put one on and see what the mixture looks like. you can put a port in each bank and move the sender from side to side if you want to see what each side is doing.
sjmcbride
PostPosted: Thu May 01, 2025 6:47 pm    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
Thanks guys!
I decided to check the spark plugs and realized I installed NGK BR5ES instead of B6ES spark plugs as seems to be recommended. So I ordered those and will pop those in and report back!
Wildthings
Wildthings is offline
PostPosted: Thu May 01, 2025 6:55 pm    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
What timing spec are you using? With a blown out retard canister and/or aftermarket carbs you can NOT use the book timing specs, instead time your engine at 28° BTDC @3800+ rpms, with the hose(s) removed from the vacuum can. You probably do not want to reinstall the retard hose if you have one since your carbs are likely not set up to use the retard function.
SGKent is offline
PostPosted: Thu May 01, 2025 10:08 pm    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
one heat range difference might not make that much of a difference, but if you combined a resistance plug, with resistance wire, with a resistance rotor, you could lose spark. Generally a 4 cyl VW engine does not produce enough RPM to get coil saturation.
Wildthings
PostPosted: Fri May 02, 2025 3:58 am    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
Make sure you have the wires on the cap in the correct order.
mikedjames
mikedjames is offline
PostPosted: Fri May 02, 2025 4:22 am    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
If it has a condenser or coil issue it might show similar rpm related issues.
Interesting also that the underlying dying problem persists even when changing the carburettors.. what remained common ?
Ignition system ?
How good is the compression?
Is the cam good?
Ancient vehicles and vessels
W1K1
W1K1 is offline
PostPosted: Fri May 02, 2025 6:56 am    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
I can tell you one thing, you need to fix the linkage install first and foremost.
That’s not even close to correct alignment
Post a picture of that…… Shocked
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
timvw7476
timvw7476 is offline
PostPosted: Fri May 02, 2025 11:30 am    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
Check the pockets where the plug wires plug into the towers on the distributor cap. For graphite powder from breaking-down plug wires. It can act as an insulator & mess up spark delivery. Same for a failing condenser, a weak breaker point spring, a worn-out carbon button under the distributor cap.
Put it in a dark garage a rev it, you may see sparks from the wires or a failing condenser.........it acts like this is mis-fire from the high-tension side of the ignition system.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Fri May 02, 2025 11:55 am    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
I haven’t seen any mention of a fuel pump, before or after the carburetor swap. Fine idle/low speed with problems under load/acceleration sounds like classic fuel starvation.
A fuel pressure test would be my next move, ideally it T’s in safely so a helper can watch/videotape the gauge while driving. You want 3psi when running, and it should change much at all with driving.
Another great data point would be a fuel volume test: at either of the carb fuel inlets, running the pump into a catch container should give you. Stock spec is something like 13oz per minute, so if it can’t fill up an empty PBR you could have a weak pump or blockage in the fuel system somewhere. (Filter, tank outlet, vacuum-sealed tank that needs venting, etc.)
www.airschooled.com
W1K1
W1K1 is offline
PostPosted: Fri May 02, 2025 1:28 pm    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
This right here is crazy, pulling upside down, arms aren’t at the same level on the bar, linkage is not vertical………
How would you expect that to pull the carb’s evenly and stay balanced throughout the throttle travel?
1973 super 2110cc
lil-jinx
lil-jinx is offline
PostPosted: Fri May 02, 2025 4:40 pm    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
seems to be running rough and blowing black smoke when it back fires ,check the firing order.looks to be a porsche engine,don,t know if that would make a difference.
1968 Dune Buggy sold dec 2024
1974 parts bus
mikedjames
PostPosted: Mon May 05, 2025 12:06 am    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
Probably worth tweaking the idle speed upwards as automatics like more like 1000 rpm, along with their using a modified distributor curve. - so if the distributor is a generic aftermarket that will not help.
Also its quite likely that the entire "design" of the automatic transmission and its throttle control really needs to be altered with carburettors with different characteristics- maybe need to at least make sure your new linkage matches the original in terms of how far the throttle cable travels for WOT.
You have moved away from a system solution - original carbs, linkages and springs, to a new permutation of parts.
Maybe spending the effort and money in restoring original carburettors that are matched to the transmission and its linkages may be a better way out..
wagen19
wagen19 is offline
PostPosted: Mon May 05, 2025 1:07 am    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
As "wildthings" already has mentioned, have you already really checked the firing order?
Also the spark plug connectors can have a too high resistance.
Should have 1 kOhm or 5 kOhm. Are some single sparks black?
Does the engine run on 4 cylinders?
sjmcbride
PostPosted: Thu May 15, 2025 5:57 am    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
Ok, so I think I’m getting closer. I replaced the NGK BR6ES spark plugs (note, two were black, one was kind of dirty but not bad, and the 4th looked like it wasn’t even used). I replaced them with NGK B6ES (note terminal caps, just the threaded top studs into the cables).
But now it won’t start at all. So I checked the plug order on the distributor cap and it looks correct to me. I took spark plugs out to see what order they were firing in and to make sure each were sparking. All 4 spark BUT each time I start it begins with a different number in the order. For example,
First time I did it, it did 1,4,3,2,1,4,3,2,1,4,3,2 etc
Second time I did it it did 4,3,2,1,4,3,2,1,4,3,2,1 etc
Third time 2,1,4,3,2,1,4,3 etc
And each time thereafter was a different starting point. I did this with a slow motion video recording to make sure I didn’t just. See it wrong with my eyes.
I then checked the rotor each time I cranked and it is always in a different starting position. I then set the engine to TDC on cylinder 1 (verified by puff test and rotor pointing at the notch on the distributor housing), and it started in the correct order, BUT after that every time I crank the engine, the rotor ends up in a completely different position, and the spark sequence starts from a different cylinder. I’ve seen it go 1-4-3-2, then 3-2-1-4, then 2-1-4-3. It seems like the rotor is shifting position randomly on each start attempt.
I’ve verified: The plug wires are routed correctly (1-4-3-2) based on rotor position at TDC #1, Spark plugs are properly gapped and grounded during testing, Rotor appears to fit snugly on the shaft — not obviously stripped.
So I’m wondering:
• Could this be a sheared distributor drive gear pin?
• Or is the distributor not seated correctly?
• Or maybe a loose clamp or stripped rotor even though it doesn’t seem to spin freely by hand?
It is odd because with the wrong spark plugs it at least ran (although very rough with backfires and would die)
Any advice would be appreciated. I’m happy to post photos or a video if needed.
Wildthings
PostPosted: Thu May 15, 2025 7:46 am    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
The engine doesn't stop in the same position each time, so what you are seeing is absolutely normal, so long as you can pick out the 1-4-3-2 snippet you are fine
sjmcbride
PostPosted: Thu May 15, 2025 8:19 am    Post subject: Re: Engine Pops/Backfires at Higher Speeds After Major Tune-Up Reply with quote
Awesome thank you!
