krusovice Samba Member
Joined: October 12, 2008 Posts: 267 Location: Duluth, MN
Posted: Thu May 01, 2025 6:17 pm Post subject: EVC rear seat hard to slide |
Hi again,
Still picking away at things. Current struggle is a rear seat that’s hard to slide. The pins are releasing but there seems to be too much friction. Add to this, one of the bushing strips doesn’t stay put (in spite of my re-glueing attempts).
Any suggestions to make it move more easily? Or just to reattach that strip (I’m thinking to drill/tap/countersink a few screws or perhaps rivets).
Thanks _________________ 1984 Vanagon 1.9/4 speed
2001 Eurovan Camper |
kourt Samba Member
Joined: August 13, 2013 Posts: 2292 Location: Austin, TX
Posted: Fri May 02, 2025 12:44 am Post subject: Re: EVC rear seat hard to slide |
Know that the sliding seat has rollers on its leading edge. These roller wheels are adjustable, and they are often putting too much or too little support in the whole system, and therefore often applying too much friction to the movement of the seat. Start there.
kourt |
Posted: Sat May 03, 2025 5:14 am Post subject: Re: EVC rear seat hard to slide |
Thanks. I had no idea.
Between that and making the pins pull up a bit more I’m shocked at how much better it is. It’s still hanging up where the top transitions from metal to poly (?) and back, but it’s astonishingly better.
I’ll fiddle some more today. _________________ 1984 Vanagon 1.9/4 speed
