BFB Samba Member
Posted: Wed May 07, 2025 8:20 pm Post subject: Trailer tires on front? |
anyone ever used trailer tires on the front of their buggy?
I’d figure with how their tread usually goes around the tire that theyd make a good steer tire and not having large gaps between tread wouldnt pick up large rocks either. Typically 10 ply so theyd be stout. But maybe a harder compound? Maybe built different than a normal tire? I dunno? _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
oprn Samba Member
Joined: November 13, 2016 Posts: 14809 Location: Western Canada
Posted: Thu May 08, 2025 4:33 am Post subject: Re: Trailer tires on front? |
I had that same question 3 years ago. I asked my local tire dealer and he said that as far as he knew the only difference was the load rating. They are rated for more weight.
At the time I was looking for a pair of 14" tires to put on my Bay window just to sell it. That was all he had in stock and they were cheaper than passenger car tires. The interesting thing is that in this part of the world it is not legal to run them on the street on a car but they are legal on a trailer.
You figure it out...
As for an advantage off road, maybe but I have 2 ply implement tires on the front of my sand rail that I run at 6 psi and have never felt the need for something heavier duty. _________________ Our cars get old, we get old but driving an old VW never gets old! |
BFB Samba Member
Posted: Thu May 08, 2025 5:53 am Post subject: Re: Trailer tires on front? |
2 ply? you sure? I could be wrong but I thought I saw the 3 rib implement tires on the front of yours and all of those ive seen are 6 ply?
and no, I wasn't looking to find something more heavy duty, just something that wasn't a street tire but also wasn't a " mud tire" with a lot of open lugs. I was looking for something similar to the old MT desert tires which seem harder to find now and what I could find were nearly $300 ea.
nothing wrong with the implements unless you plan to drive on road muchness highway speeds.
that law doesn't surprise me, id would be surprised if many cops would know the difference in the tires at first glance though _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
indianpeaksjoe Samba Member
Posted: Thu May 08, 2025 7:55 am Post subject: Re: Trailer tires on front? |
My general grabers throw rocks like it is their job. I can see why you'd want to avoid them.
-Joe _________________ Adventures in owning a 66 beetle |
DesertSasquatchXploration Samba Member
Posted: Thu May 08, 2025 1:31 pm Post subject: Re: Trailer tires on front? |
That's interesting I guess because they have a million medium sized grooves? I guess with the tractor style tread i have for fronts its not that bad for little rocks but i've thrown some big ones and chunks of the front fenders have been removed. _________________ Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out) |
U&I Samba Member
Posted: Thu May 08, 2025 2:00 pm Post subject: Re: Trailer tires on front? |
Around these parts they are frowned on for passenger vehicles, most that I have ever seen come with an ST prefix making it an easy identifier to the casual observer and upon closer inspection have wording that states "for trailer use only" or something to that effect.
Guessing that off road use only wouldn't be an issue, depending on the specific area. |
71StandardReduction Samba Member
Joined: December 04, 2012 Posts: 786 Location: Louisiana
oprn Samba Member
Posted: Thu May 08, 2025 8:13 pm Post subject: Re: Trailer tires on front? |
BFB wrote: |
2 ply? you sure? I could be wrong but I thought I saw the 3 rib implement tires on the front of yours and all of those ive seen are 6 ply? |
I just checked and they are actually 5 rib implement tires, 4 ply with a 6 ply rating.
The reason they are on there is like you say, to reduce crap thrown in my face when driving. Sand and fine gravel still do at higher speeds but way less than any car tire for sure. _________________ Our cars get old, we get old but driving an old VW never gets old! |
oprn Samba Member
Posted: Thu May 08, 2025 8:20 pm Post subject: Re: Trailer tires on front? |
U&I wrote: |
Around these parts they are frowned on for passenger vehicles, most that I have ever seen come with an ST prefix making it an easy identifier to the casual observer and upon closer inspection have wording that states "for trailer use only" or something to that effect. |
Yes and no one to date has been able to explain the difference to me. A trailer tire rotates at the same speed as any other tire on the road, has weight on it, is expected to brake and corner just like any other tire on any other vehicle. So they are rated for a heavier load? How does that make them unsafe under a lighter load?
I just don't get it! _________________ Our cars get old, we get old but driving an old VW never gets old! |
BajaInMyBlood Samba Member
Joined: January 02, 2025 Posts: 24 Location: Gold Country CA
Posted: Thu May 08, 2025 9:11 pm Post subject: Re: Trailer tires on front? |
My mini mags and KR2s aren't road legal but I still love them. I've used trailer tires on a baja as rollers/mock up but never really had any experience using them on steer/drive wheels at speed. |
Posted: Fri May 09, 2025 5:14 pm Post subject: Re: Trailer tires on front? |
oprn wrote: |
U&I wrote: |
I just don't get it! |
Trailer tires will fail when used as drive tires that's why. They take side to side load only. You can use them as fronts. _________________ Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out) |
BFB Samba Member
Posted: Fri May 09, 2025 8:07 pm Post subject: Re: Trailer tires on front? |
Ok, so i have a buddy thats owned a tire shop for a couple decades and I holed at him about this.
He said biggest things are they are not designed for traction and also not designed to shed water so the chances of hydroplaning is fairly high.
He did say that he thought theyd be fine for offroad use as front tires though. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
U&I Samba Member
Posted: Sat May 10, 2025 8:15 am Post subject: Re: Trailer tires on front? |
oprn wrote: |
U&I wrote: |
Me neither, I just know that in my case, with my luck, I'd be the one that gets caught running them and they'd impound my rig, suspend my license, and toss me into the gulag for a year just in case, or some such nonsense. |
oprn Samba Member
Posted: Sun May 11, 2025 9:18 pm Post subject: Re: Trailer tires on front? |
Perhaps there is something to them not being designed to drive but the I am going to call BS on the hydroplaning thing! A hydroplaning trailer would be a total disaster! Just look at the tread design... sheading water is about all that tread is designed to do. _________________ Our cars get old, we get old but driving an old VW never gets old! |
BFB Samba Member
Posted: Mon May 12, 2025 6:11 am Post subject: Re: Trailer tires on front? |
not necessarily , trailer could hydroplane and still be drug in a straight line. just because something hydroplanes doesn't mean its flying off the road. they are obviously designed differently than standard commuter tire and if they were equal to a commuter tire then your people wouldn't have laws against using them. you get an answer about why trailer tires aren't used on commuter vehicles from a guy that's been in the tire business 30+ years and you call bullshit. that's just ignorant on your part, but hey maybe your an expert _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
oprn Samba Member
Posted: Tue May 13, 2025 8:47 pm Post subject: Re: Trailer tires on front? |
I pulled trailers every day for a living for 20 years and I can tell you that when a trailer gets loose back there whether it is ice, snow or water things go bad fast! I can assure you that trailer tires are designed to shed water, your guy behind the counter spent 30 years selling tires not driving with them. There’s a big difference. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Tue May 13, 2025 9:20 pm Post subject: Re: Trailer tires on front? |
You guys are worried about nothing. You can rob kill smuggle anything and get a slap on the wrist. Police don't care about your tires they are young and dumb 99% don't even know what a recap is. _________________ Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out) |
BFB Samba Member
Posted: Wed May 14, 2025 7:37 pm Post subject: Re: Trailer tires on front? |
oprn wrote: |
I pulled trailers every day for a living for 20 years and I can tell you that when a trailer gets loose back there whether it is ice, snow or water things go bad fast! I can assure you that trailer tires are designed to shed water, your guy behind the counter spent 30 years selling tires not driving with them. There’s a big difference. |
Yeh ok…. Guarantee my tire guy knows his shit, you believe whatever you want though, i dont give a shit.
But, I thought you were a body guy for 30 years? So which one is it or are you a vampire thats lived a few hundred years and lived several lives which gave you the ability to do multiple trades for 30 years each? _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
U&I Samba Member
Posted: Thu May 15, 2025 7:26 am Post subject: Re: Trailer tires on front? |
Turned 58 this year,
45+ years wrenching on cars and trucks
30 years as a licensed plumber in three states
20 years as a gun builder
20 years as a hand engraver
There are quite a few of us that do not finish up with the day job and head home to get drunk eh. |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 3504 Location: West Coast (Michigan's)
Posted: Thu May 15, 2025 9:27 am Post subject: Re: Trailer tires on front? |
BFB wrote: |
oprn wrote: |
But, I thought you were a body guy for 30 years? So which one is it or are you a vampire thats lived a few hundred years and lived several lives which gave you the ability to do multiple trades for 30 years each? |
Oh get a room you two! _________________ Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes |
