SGKent  Samba Member
Joined: October 30, 2007 Posts: 42955 Location: at the beach in Northern Wokistan
Posted: Sat May 10, 2025 9:40 am Post subject: Oil Filter Mount Gasket 021-115-359A |
Wanted to throw this out there for those who have built type IV engines.
There is a gasket that has been discussed lightly within threads a few times, but I could not find a definitive thread on it so here goes.
First a background. In 2011 I built the first T4 engine for this 1977bus. While on the engine stand, I installed the filter mount using the gasket in the VR kit, and some Gasgacinch. I was standing in the garage 20 minutes or so later and I heard a strange loud snap come from the area of the engine. An investigation yielded that the filter mount was in two pieces, snapped about a 1/4 of the way between the two nuts. Both had been tightened to spec. Looking further, the gasket had blown out on the thin side, and the mount had snapped along that line where the gasket had blown out. I replaced the mount with another I had, made sure the surface was flat, and as I slowly tightened down the thin area of the gasket began to deform and push out. I bought a package of just that gasket and tried different sealers on it, each time the result was the same. Dry the gasket did not migrate, but any sealer I had forced it to migrate outwards - where continued tightening would have ruptured it. Finally I put it on dry and it held.
Lately I have been thinking about this gasket because I have an oil weep in that area. There have been other threads here where that gasket has failed on people. What I have been thinking about was making that part of the gasket wider so that the extra strength was on the outside of the mount. My thought is that would give lateral strength to the thin area, and perhaps keep it from moving outwards when tightened. Has anyone tried this, or come up with another solution? Loctite 518 might work but I am a bit leary of trying that due to the stresses on the oil mount. I am thinking the sealing has to be non-hardening. Below in first the photo is the area I am thinking of widening by making a gasket from standard gasket paper and a trace. The second photo is what the width would be with the mod. Opinions please. The red line is where it blows out when tightened, and the blue line is where it snapped in 2011.
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1797 Location: New Brunswick,Canada
SGKent  Samba Member
Posted: Sat May 10, 2025 2:29 pm Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
| lil-jinx wrote: |
| maybe use gasket glue to stick the gasket to the filter mount. |
what is gasket glue? The issue is if the sealer acts as a lubricant in any way the gasket blows out in the area of the arrow. _________________
George Carlin:
Posted: Sat May 10, 2025 2:40 pm Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
we used 3m spray adhesive at my former work place ,you spray it on one surface and let it dry to tacky then place the gasket on it,once it's stuck it won,t move,
I use it on my valve covers to stick the gasket to the cover,so the gasket don.t get squeezed out, _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy sold dec 2024
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
SGKent  Samba Member
Posted: Sat May 10, 2025 3:22 pm Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
are we talking like the upholstery spray used on headliners etc? What I was hoping to find is a way to use a sealer on both sided and not have it blow out. Because there is oil pressure and thin oil present, just a paper gasket is not the perfect solution, but that is what I have been using due to the seals blowing out if sealer is put on them. I was thinking if they were wider in that area they would not be as prone to deform. _________________
George Carlin:
Posted: Sat May 10, 2025 3:42 pm Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
yes i thats is what we used multi purpose spray adhesive,used it on paper type oil pan gaskets on older cummins ,and any where there was a paper gasket,
when using just silicone on a gasket i would put it on as thin as possible and let it skin over before installing,when using silicone all the old silicone must be removed,silicone won't stick to cured silicone very well. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1974 parts bus
SGKent  Samba Member
Posted: Sat May 10, 2025 3:55 pm Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
same stuff used in upholstery. Similar to the old formula of Gasgacinch before CARB got to the formula but stickier _________________
George Carlin:
SGKent  Samba Member
Posted: Sat May 10, 2025 5:52 pm Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
good news is that the gasket does not appear to have leaked in use so maybe dry is the solution. _________________
George Carlin:
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23521 Location: Oklahoma City
Posted: Sat May 10, 2025 6:09 pm Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
Yes, the gasket squirms. If you try to stop it from squirming with pressure you will break the mount. Two things.
1. Make sure the mounting face is flat. Then make sure the two surfaces where the nuts tighten to are flat and square lf the studs are slanted or the faces where the nuts contact or the sealing face are out of square....these are the only things than can cause that mount to warp and crack.
2. They make stuff just for this.
Adhere the gasket to the mount...flat....with just enough pressure to contact. Use a drying gasket shellac. Solvent based.
Indian head works well enough. Motoseal or Yamabond even better because they are a solvent based silicone. Think like an air curing RTV.
Motoseal is essentially very much like Permatex Ultra Gray when dry. But....because its ~60% solvent, when you apply a thin smooth layer, once it drys it is 60% thinner.
It's both an adhesive and a sealant. I also roll or brush on a layer on the case side as thin as possible. It dries to a 40 durometer layer less than 0.001" thick to both seal the gasket face so oil does not wick laterally and it gives a very thin compression sealing layer.
And/or.....if you make sure the sealing face of the mount is flat and the sealing face on the case is flat, roll on a layer of motoseal or yamabond. Let dry. Repeat. Let dry. Repeat.
Get about three layers on and you will have a perfectly smooth gasket layer that is about 0.003" to 0.005" thick. Just bolt it up.
Ray |
SGKent  Samba Member
Posted: Sat May 10, 2025 6:16 pm Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
| Quote: |
| If you try to stop it from squirming with pressure you will break the mount. |
not sure what you mean Ray. The nuts go to a certain torque. I take each one up a few pounds at a time to keep the stress even between sides.
I checked the case last time and it is flat. I sanded the mount on a piece of thick glass with like 800 grit in a figure 8, rotating it every few turns, until it was shiny evenly. _________________
George Carlin:
Posted: Sat May 10, 2025 9:47 pm Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
| SGKent wrote: |
| Quote: |
I checked the case last time and it is flat. I sanded the mount on a piece of thick glass with like 800 grit in a figure 8, rotating it every few turns, until it was shiny evenly. |
If everything is flat as you say (and I have no doubt that it is)....then there is no way...ever...that the mount could break. Right?
Its because the gasket paper used....is too thick. It starts compressing in the areas under the nuts. It gets thinner there and stays thicker in the middle. That creates a CURVE.
Once the compression hits a certain level....that paper compresses enough to begin acting like a solid. No more compression possible. But yet...its already a curve.
A solid curved surface against a flat one and something is going to break.
I have had lots of issues with several gaskets over the years on my cars where the gasket paper used is simply too thick. Theother problem the gasket paper causes is that once you tighten up the two parts sandwiching it....over times that gasket will flatten out and get a little thinner. It has no spring or elasticity. This mean the joint getsloose...the nuts can get loose...and it leaks.
If both surfaces are indeed flat, you do not need all of that gaket paper thickness. You just need a few thousandths of something flexible to fill the milling machine marks in both surfaces.
Ray |
SGKent  Samba Member
Posted: Sat May 10, 2025 10:34 pm Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
ok _________________
George Carlin:
wagen19 Samba Member
Joined: November 16, 2007 Posts: 883 Location: germany
Posted: Sat May 10, 2025 10:43 pm Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
Very good explanation!
Remembering disassembling type 4 engines: just that gasket allways made problems to remove from surfaces. It ever felt, it was glued on. So I think, that material is a special kind for sealing against oil under pressure. Further, I never have seen a leak there. (when affixed dry by factory)
What says VW handbook?
Imo, in most cases any kind of chemical or liquid sealant makes no problem, or even helps, but in just that case, with that kind of gasket around the pessurized oil gallery, it should better be affixed dry and not overtorqued. |
SGKent  Samba Member
Posted: Sun May 11, 2025 12:27 am Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
wagen19 I read your post and I thank you. In the process you just led me to something that I never noticed. Maybe Ray, or Scott, Robbie, Busdaddy someone will have an answer.
I think we have been screwed over on this gasket and anyone who has had a leak on it is owed an apology by VW. The orange factory manual shows a case with two holes. The Bentley shows two oil holes. The 914 manual shows two holes. My case has two oil holes. The mount has two oil holes. DID THE ORIGINAL GASKET NOT HAVE THE HOLE FOR A THIRD PASSAGE?
The gasket being sold has that long thin area. Why? I am really puzzled now. When and why was this passage added? The fiche calls for 021-115-359A. Every photo of one has the third unused passage. The orange factory manual calls for both 14 ft lbs the 18ft lbs in another spot, but neither Bentley or the 914 factory manual have a torque for those nuts.
Every one has this gasket below but the case doesn't need the third passage that causes all the problems. Why is it there? Did the factory experience broken oil filter mounts and weaken the middle of the gasket so it could crush easier? Was there an engine that had this passage? The factory photo (second photo) shows a gasket WITHOUT the passage. Anyone know the history on this passage and change?
I also found these old threads re the mount
| Quote: |
dwill49965 Mon Aug 28, 2006 6:18 pm
I looked for that same information a couple of months ago when I was putting my oil filter mount back on. Never found it. No mention in Wilson, and in Jake Raby's Vol 8. Type 4 rebuild dvd, all he said was to "snug them up", but not too tight. (or words to that effect).
I used permatex No. 3H, aviation gasket sealer, on both sides of the paper gasket, and torqued it to 9 ft-lbs. It has held leak free with no problems since. |
| Quote: |
dwill49965 Tue Aug 29, 2006 2:41 pm
germansupplyscott wrote: the orange VW manual shows 18 ft-lb.
Now how did I miss that? Of course, I checked Wilson, Bently, and the Raby video, but not my orange manual. (Oops - I didn't check Muir, either!!)
On page 13.7 of the orange manual (2nd ed.), it shows a diagram of the engine under "Engine - Crankshaft Assembly" where it indicates 18 ft-lbs for the oil filter mount.
However, same manual, page 17.2 "Engine - Lubrication System", the diagram shows 14 ft-lbs for the oil filter mount.
Yeah - its minor, but still a discrepancy. Given that I don't think I even tightened mine up that much, I'm with Hippie - love that permatex 3H.  |
| Quote: |
keifernet Tue Aug 29, 2006 3:10 pm
dwill49965 wrote: germansupplyscott wrote: the orange VW manual shows 18 ft-lb.
That's why I said 14- 18 in my first post... the general range for an 8mm stud on a VW engine  |
Elring 021-115-359A
Factory photo. Look closely at the gasket. It has no third passage, the long narrow one.
George Carlin:
Posted: Sun May 11, 2025 1:29 am Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
| SGKent wrote: |
I think we have been screwed over. The orange factory manual shows a case with two holes. The Bentley shows two oil holes. The 914 manual shows two holes. My case has two oil holes. The mount has two oil holes. DID THE ORIGINAL GASKET NOT HAVE THE HOLE FOR A THIRD PASSAGE?
The gasket being sold has that long thin area. Why? I am really puzzled now. When and why was this passage added? The fiche calls for 021-115-359A. Every photo of one has the third unused passage. The orange factory manual calls for 14 ft lbs but neither Bentley or the 914 factory manual have a torque for those nuts.
Every one has this gasket below but the case doesn't need the third passage that causes all the problems. Why is it there? Did the factory experience broken oil filter mounts and weaken the middle of the gasket so it could crush easier? Was there an engine that had this passage? The factory photo (second photo) shows a gasket WITHOUT the passage that causes the blow out. Anyone know the history on this passage and change?
Thank you for that pics!
Imo, the factory pic shows more the case, (and evtl. a scematic drawing of gasket area) than accuratly the gasket itself.
But:
Type 411, 412 spare book says, there is gasket 021 115 359 for V-engines till V 033 302 and 021 115 359 A for engines V 033 303 onwards. (not knowing about the difference)
Remembering, when affixing new factory gaskets, I was wondering about about the sense of that third passage, but I was not sure about.
I only can repeat, up to now, I never had a single one, dry affixed, leaking factory gasket just right there!
Oil leakings in that area, on rear left side of engine case are much more often caused by:
> oil pressure switch (often)
> gasket on distributer shaft (often)
> gaskets for oil cooler (sometimes)
> oil filter rubber gasket (not tightend enough)
> oilcooler (rather seldom)
> oil pressure relief
> crank seal
> oil gallery plugs
> along some studs for fan shroud
> gasket for crankcase ventilation cover
Oil allways comes down (to earth)!
Torque: for M8 studs, 20 Nm should be a good level, but feeling is needed, because the lower nut is hardly reachable with a torque wrench. |
SGKent  Samba Member
Posted: Sun May 11, 2025 2:14 am Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
take a look again. I put an arrow right to it. That said, you probably found the answer in the engine numbers. I am guessing that without the A it had no third passage but with the A it does. Why I don't know. The engine is out and the cooler off so I should be able to get to both nuts. Worst case is a good wobble head extension. Maybe put sealant just around the holes that flow oil, like paint it on with a model brush. Thinking yamabond or something like that. Aviation gasket sealer maybe. Have to think it over in the morning. A crows foot at 90 degrees would work too.
George Carlin:
Posted: Sun May 11, 2025 6:32 am Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
I can tell you for sure that the 411 and 412 gaskets that I have seen.....on the vehicles....not in gasket kits, that are KNOWN to have come from the factory at least on 411 and 412 cars....did NOT have the 3rd hole.
The first time I remember seeing them is in gasket sets.....starting around 1980.
There are a couple of things to keep in mind here. The better gaskets are the stiffer gaskets. The stiffer gaskets are stiffer because they are coated both sides. Through the years there was a lot of variation in gaskets in the afterkarket kits like Victor Reinz, Cofap and Elring. Some were coated both sides, some were coated one side and some were not coated at all. Those that are not coated also had issues with shelf life span if stored improperly or if there were air leaks in the package. The uncoated gaskets absorb moisture and the gaskets curl and sometimes swell or shrink.
If you understand that last point....you can understand the purpose of the surface coating on gaskets. It makes the gasket harder, smoother and flatter and seals the surface.
The coating they put on these gaskets also helps to stabilize and strengthen thinner gasket material.
The purpose of "gasket" dressing is exactly this....to seal the surface. Most old school "gasket dressing" was designed to be applied and then dried....BEFORE...installing the gasket.
Yes, using the gaskets dry on gaskets this small is the best way to go because as I mentioned, wet sealer makes the gasket squirm under pressure.
Treat the gasket with a sealer or dressing (especially if it does not have coated surfaces) ....and let it DRY before install. That is how I have found these to be the most leak free. Ray |
Posted: Sun May 11, 2025 7:30 am Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
| For myself I don't think I have ever used sealant on this gasket, but if the gasket is the problem then maybe eliminate the gasket and just use a judicious amount of sealant by itself. |
SGKent  Samba Member
Posted: Sun May 11, 2025 11:50 am Post subject: Re: Oil Filter Mount Gasket 021-115-359A |
| Wildthings wrote: |
Thanks Mike, Ray
Wagen19 wrote:
| Quote: |
| Type 411, 412 spare book says, there is gasket 021 115 359 for V-engines till V 033 302 and 021 115 359 A for engines V 033 303 onwards. (not knowing about the difference) |
Looking up the engine, it looks like that was the 1969 Type IV 1700. From the number of engines, it would appear that somewhere around 33300 engines made, VW changed that gasket. The 914 came out in 1970, the 912E only 1976. Hans, who designed the change probably died 15 - 20 years ago in which case who knows why he did it. I wonder if there are any 411 technical supplements out there that might cover the change. The 1969 vehicles were not imported so the dealers here might not have even had an opportunity to have a service manual. This could be a South African or German known documented change only. _________________
George Carlin:
