Unused German as41 case
Jim68toad
Jim68toad is offline
PostPosted: Sun May 11, 2025 7:25 pm    Post subject: Unused German as41 case Reply with quote
Ok you engine guys tell me what I got
Picked up two never used but old as41 cases one say Germany
And the other is Brazil
There are no numbers under the generator mount
rugblaster
rugblaster is offline
PostPosted: Sun May 11, 2025 7:41 pm    Post subject: Re: Unused German as41 case Reply with quote
What you have there is a couple of Unicorns.
'69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!!
Jim68toad
PostPosted: Sun May 11, 2025 8:00 pm    Post subject: Re: Unused German as41 case Reply with quote
Are unicorns good or bad
Should I build the Brazil case and save the German
Or dose it matter
tucson vw
tucson vw is offline
PostPosted: Sun May 11, 2025 8:25 pm    Post subject: Re: Unused German as41 case Reply with quote
It looks like the German case is already bored for 90.5/92mm.
SBD
SBD is offline
PostPosted: Sun May 11, 2025 9:15 pm    Post subject: Re: Unused German as41 case Reply with quote
I think Unicorns are good. Shocked
"Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote:
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it.
Rome
Rome is offline
PostPosted: Mon May 12, 2025 6:01 am    Post subject: Re: Unused German as41 case Reply with quote
And that the upper right case saver inserts on both cylinders are standing proud of the cylinder base edge...
Jim68toad
PostPosted: Mon May 12, 2025 7:11 am    Post subject: Re: Unused German as41 case Reply with quote
I’ll measure the cylinder bores to see if there 92mm
I also got a 69mm counter weighted crank so maybe there were going for a 1835 the guys was very old and could remember
They had been in his garage for many years
