tommehl Samba Member
Posted: Sat May 10, 2025 12:03 pm Post subject: 69 convertible door issues |
I inherited this project and I am to the point of fitting the doors.... and they hit all along the bottom on the new heater channel. I don't want to cut the heater channel out so if you have ideas, thoughts or fixes please help.
busman78 Samba Member
Joined: August 17, 2004 Posts: 4659 Location: Oklahoma City, OK
Posted: Sun May 11, 2025 6:07 am Post subject: Re: 69 convertible door issues |
Could be an illusion but looks like that door got swung open without the stop attached, outer skin is bent in at the hinge top and bottom. |
Posted: Mon May 12, 2025 11:43 am Post subject: Re: 69 convertible door issues |
I don't believe it is bent.... I just went and checked. But I am wondering if the way I have the body supported on jack stands could lead to the problem. I have it on stands under the crossmember that's under the seats and from the bottom of the trunk in the front.. Any thoughts?? |
Posted: Wed May 14, 2025 5:09 am Post subject: Re: 69 convertible door issues |
Is the body bolted to the floor pan or is it loose? |
Posted: Wed May 14, 2025 7:04 am Post subject: Re: 69 convertible door issues |
It isn't bolted to the floor yet... and I put a floor jack under the heater channel/stiffener rail just little behind the hinges and it does shut now. The rear gap is a little wonky but I think I can fix that Ince it gets mated to the floor with shims. |
Posted: Wed May 14, 2025 8:21 am Post subject: Re: 69 convertible door issues |
Get it bolted to the floor pan and then set the door gap, there really are no shims, there two rubber washers (of a sort) for the rear body to shock tower mating. Don't forget the pan gasket. |
