Derickpete Samba Member
Joined: October 01, 2013 Posts: 22 Location: Gardnerville Nv
Posted: Tue May 13, 2025 2:01 pm Post subject: Shock length |
What length shock, extended length and collapsed length is used for a Warrior beam with 8” towers and stock arms. I’m measuring 19” extended and 14” collapsed. Is this correct? |
Schepp Samba Member
Posted: Tue May 13, 2025 2:16 pm Post subject: Re: Shock length |
You answered your own question. |
Posted: Tue May 13, 2025 2:27 pm Post subject: Re: Shock length |
From what I understand the 8” beam means 8” shock stroke. I’m getting 5” of stroke. So what is the correct shock. |
BFB Samba Member
Posted: Tue May 13, 2025 5:24 pm Post subject: Re: Shock length |
8" beam typically means 8" wider.
but even if we go with your theory and its 8" towers, the tower doesn't matter. you could have 8 foot towers and you'd still have the same amount of travel out of stock arms. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4594 Location: Fair Oaks/Orangevale, CA
Posted: Tue May 13, 2025 8:24 pm Post subject: Re: Shock length |
8in tall shock tower on either a stock or widen beam, the most common shock that has been used is the rear shock from a 1968-1979 VW Bus
The KYB 5530 was a commonly used shock although the valving may be stronger then you need _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Tue May 13, 2025 8:53 pm Post subject: Re: Shock length |
Thank you. I will look into them. |
Posted: Sat May 17, 2025 2:45 pm Post subject: Re: Shock length |
Update: The bus shocks worked perfectly for my beam. Thank you for the input. |
