JayWat Samba Member
Joined: February 19, 2024 Posts: 54 Location: Missouri
Posted: Mon May 12, 2025 8:59 am Post subject: Spring plate lowering |
Lowered a 76 1 inner spline.
What bottoms out first ?
The spring plate ?
The place that used to hold the bump stop ?
Or the stock length shock ?
Bottoming out on something solid and I can't see where. |
Starbucket Samba Member
Posted: Mon May 12, 2025 2:17 pm Post subject: Re: Spring plate lowering |
Have someone jump up and down on the rear bumper while you watch under the car and see what is hitting. My money is on the shock. |
JayWat Samba Member
Posted: Tue May 13, 2025 4:45 am Post subject: Re: Spring plate lowering |
The car is too low to see what's going on.
I may remove the shocks temporarily and take it for a drive.
Anyone know a shorter shock part number that has been used successfully ? |
Posted: Tue May 13, 2025 7:04 am Post subject: Re: Spring plate lowering |
All the vw suppliers sell them, cip1 jbugs, wolfsburg west, etc.. |
clockworkbox Samba Member
Joined: July 12, 2020 Posts: 472 Location: Williamsport, PA
Posted: Tue May 13, 2025 9:06 am Post subject: Re: Spring plate lowering |
If it is hitting the bump stop stub (assuming you removed the rubber bump stops), you should be able to see if the trailing arm made contact. There should be some kind of scrape or paint missing from the stub and/or the stop on the chassis. _________________ '69 Beetle (pieces)
Learning the hard way is still learning... |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11161 Location: Huntington Beach, CA
Posted: Tue May 13, 2025 3:14 pm Post subject: Re: Spring plate lowering |
Get your phone in there and pointed in the direction. Then, if you can see the screen, see what is happening. If not, take a video of it, then watch that. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4934 Location: Stuck in Ohio
JayWat Samba Member
Posted: Thu May 15, 2025 5:30 am Post subject: Re: Spring plate lowering |
So, spring plate will hit the stop before the naked bump stop correct ? |
