OG Style Samba Member
Posted: Tue May 06, 2025 11:34 am Post subject: 79 Beetle won't start |
The car was running fine then won't start. All we did was tighten the belt. We are getting 12v + to the injector but we're not getting a ground signal. The car was running fine until we adjusted the belt. Now it just cranks. We have good fuel. We tried using starter fluid and it wont fire. We have good spark. Does anyone have any ideas on what the problem might be or what we should check?
Thank you
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4577 Location: viroqua wi.
Posted: Tue May 06, 2025 11:49 am Post subject: Re: 69 Beetle won't start |
| OG Style wrote: |
Thank you |
A 69 with an injector? |
Posted: Tue May 06, 2025 11:51 am Post subject: Re: 79 Beetle won't start |
| 79. Sorry |
Posted: Mon May 12, 2025 6:44 am Post subject: Re: 79 Beetle won't start |
| We got it. For some reason it flooded. We think there's something wrong with the cold start. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53256 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon May 12, 2025 8:23 am Post subject: Re: 79 Beetle won't start |
| OG Style wrote: |
Since this all began after messing with the belt the place to look is the thermo time switch (TTS) just above the lower pulley, broken wires? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed May 14, 2025 5:23 am Post subject: Re: 79 Beetle won't start |
| The wires are fine. |
Posted: Wed May 14, 2025 7:00 am Post subject: Re: 79 Beetle won't start |
Then try taking the CSV out of the loop, disconnect the fuel lines and connect them to each other with a temporary barb fitting, leave the CSV in place to fill the hole in the plenum.
The CSV only comes into play when it's really cold, if you don't drive in winter you won't really miss it. If it's sticking and dribbling it could be behind the flooding. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu May 15, 2025 9:49 am Post subject: Re: 79 Beetle won't start |
| I'll try that. Thanks. |
