ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 3716 Location: West Coast (Michigan's)
Posted: Wed May 14, 2025 6:49 pm Post subject: Show and tell |
I just wanted to show off my new steering wheel.
I wanted a full size one because I figured it'd help the tough steering on my baja and I've never had one. Just had the little one you see on most buggies.
Well I bought an old one off a guy in the classifieds that looked pretty rough. It was cracked all to hell and falling apart. I've been restoring in my freetime at work all winter. Got it done and mounted just today.
Old
Probably a lot older
_________________ Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes |
Posted: Wed May 14, 2025 6:50 pm Post subject: Re: Show and tell |
Posted: Wed May 14, 2025 6:52 pm Post subject: Re: Show and tell |
Posted: Wed May 14, 2025 6:54 pm Post subject: Re: Show and tell |
DesertSasquatchXploration Samba Member
Posted: Wed May 14, 2025 7:00 pm Post subject: Re: Show and tell |
How do you like it? Its a lot different at first but I wont ever go back too the tiny wheels best thing I did was chuck my 13inch grant in the garbage. You can put your arm on the door and cruise. _________________ Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out) |
BFB Samba Member
Posted: Wed May 14, 2025 7:26 pm Post subject: Re: Show and tell |
Nice job, that thing really matches the interior and looks great _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
indianpeaksjoe  Samba Member
Posted: Thu May 15, 2025 7:25 am Post subject: Re: Show and tell |
Looks great, and nice job. Mine came with a tiny, damn near comical 11" wheel. I put a moon eyes on that is larger and it is so much nicer. Dog approved.
_________________ Adventures in owning a 66 beetle |
Posted: Thu May 15, 2025 7:28 am Post subject: Re: Show and tell |
Makes driving so much more enjoyable. Now if I could just get my windows to work reliably.
I'm curious to see how long my repairs on this steering wheel will last. This car has a few more years before I'll be ready to blow it apart and resto it. At this point I'm not even sure I should be talking about it in the off road section anymore. I just enjoy driving it on the road way to much. I'm picking it over the sportbike most days and I got the bike out a month later than usual this year. Still trying to get the carbs just right after the airbox/filter mods I did which is hard when it requires pulling the engine now. Regardless I'm having fun driving it while I can. _________________ Brian H.
U&I Samba Member
Posted: Thu May 15, 2025 7:37 am Post subject: Re: Show and tell |
Thanks for this, both of my bugs have the stock wheel and I'm wanting to keep them.
If I may, what did you use as a filler? |
Posted: Thu May 15, 2025 8:30 am Post subject: Re: Show and tell |
I used a 3m Epoxy potting compound I just happen to have available through my work, but any epoxy is fine.
I was initially going to do it like all the videos show where they guage out all the cracks a ton and then shove something like JBWeld in there and sand it down. Then after realising just how cracked over the entire wheel mine was I thought maybe I'd just pull it all off and reform the wheel with something like the steelweld product. It would take so much of that stuff it was ridiculous. So I remembered I had this epoxy in my toolbox I could use. The only problem with it was it was very viscous. So I cleaned out the big cracks with a very small flat screwdriver tip and partially wrapped masking tape around the big cracks. The tape acted like a dam to hold the epoxy in the crack while it set up. I ended up with some pretty aweful looking spots as you can see in that one closeup. After I got the big cracks covered, I used an acid brush and spread a layer over the entire circumference that was cracked. I didn't realize it but the runny nature of this stuff actually helped because it was able to soak into the old material and become one with it. It took about a day to set up so I would spread some on and throw it in my cabinet and do it again the next day. I had all winter so I just took my time. Then came a lot of sanding. Epoxy is not great for sanding. At least this stuff wasn't. When I got it all roughly back into shape there were still some glaring low spots. Next I used a filler primer and glazing putty just like doing autobody. Wet sand it down with 320. Spray a layer of filler primer (rustoleum). Sand down with 320. Little more filler. rinse and repeat. I normally don't have patience for this kind of work, but I could see it getting nicer and that kept me going. I did lose my patience with the individual knobs/grooves on the back of the wheel. You know the molded spots for your fingers to fit into? Well the originals were half worn off. I tried buidling them up but it was just too meticulous. My hands can't handle that little stuff anymore before they get all crampy and angry. I got them looking OK but I knew the leather would cover up the imperfections anyway.
At first, my red paint went on so smooth and it looked flawless. Then I sprayed a satin clear over that, all rustoleum stuff. On the back of the spokes orange peel suddenly popped up. I don't know if it was the angle I had the can at or if it was one of the other thing I used reacting with the clear. I wet sanded it and it came right back when I sprayed another coat. Fortunately, it has a really fine pattern, almost like the grain you see on steering wheels anyway. So I left it. It's not noticeable, but I know it's there and how I screwed up a perfect paint job. lol Never fails.
There was a point where I thought I had just ruined it for good. Just keep going and trying different things until you get the result you're looking for. I'm not sure how much that potting compound costs. I imagine the dispenser is probably the more expensive part. If you can I'd suggest trying it though. I don't see JB weld soaking into the old plastic like this stuf did. I kept waiting to be sanding and it start crumbling apart, but it was solid. Hopefully it stands up to the sitting in the sun on hot days. _________________ Brian H.
Posted: Thu May 15, 2025 8:36 am Post subject: Re: Show and tell |
| indianpeaksjoe wrote: |
I think mine was either 10 or 11. I knew I'd get more leverage with this 13"er, but it still amazed me.
I have a pretty sloppy steering box I'm trying to find a replacement for and a lot of the effort comes from trying to push that thing. So if I can find a replacement I'll really be happy. _________________ Brian H.
Posted: Thu May 15, 2025 8:37 am Post subject: Re: Show and tell |
BTW you threw me off a little at first with you picture. I was scrolling past it quickly and for a second I thought I was mistakenly on a different thread with one of my pics of my beagle. lol _________________ Brian H.
Posted: Thu May 15, 2025 8:41 am Post subject: Re: Show and tell |
I think I may have put the steering wheel back together upside down. The horn looks like it could go either way but there's just something off about it.
More than likely it's upside down, because that's what I do. _________________ Brian H.
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11149 Location: Black Forest, CO
U&I Samba Member
Posted: Thu May 15, 2025 10:09 am Post subject: Re: Show and tell |
| Perfect, thanks again. |
Posted: Thu May 15, 2025 11:27 am Post subject: Re: Show and tell |
| ORANGECRUSHer wrote: |
| BTW you threw me off a little at first with you picture. I was scrolling past it quickly and for a second I thought I was mistakenly on a different thread with one of my pics of my beagle. lol |
Beagles and bassets basically the same
-Joe _________________ Adventures in owning a 66 beetle |
Posted: Thu May 15, 2025 1:02 pm Post subject: Re: Show and tell |
nothin' but a hound dog... love em. I might go basset next time! This beagle is wearing me out! _________________ Brian H.
oprn Samba Member
Joined: November 13, 2016 Posts: 15289 Location: Western Canada
Posted: Fri May 16, 2025 4:29 am Post subject: Re: Show and tell |
Nice job!
One of the first clues that an old VW is NOT a driver is when it has a 10" steering wheel, huge front tires with deep dished front wheels. You know the guy would have to have arms like a gorilla to drive it! Looks good at the Show and Shine though...
My street Buggy was set up like that when I bought it. I got things changed enough now that the tires are narrow enough and back under the wheel wells where they belong. That helped a HUGE amount but to put a proper sized steering wheel on I would need to go with a removable one or adapt some sort of tilt column. It's an access and regress thing. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Fri May 16, 2025 6:13 pm Post subject: Re: Show and tell |
When I bought this eons ago it was setup for dune duty and had an inch of wet sand rotting out the floorboards to prove it. A geared trans too. I'm still not sure why you'd want a little when the big is so much easier. _________________ Brian H.
oprn Samba Member
Posted: Sat May 17, 2025 5:15 am Post subject: Re: Show and tell |
Just another fad, a look cool thing. Like the broken axle look and ripped blue jeans. _________________ Our cars get old, we get old but driving an old VW never gets old! |
