Accelerator cable does not slide well
luc.tor
luc.tor is offline
PostPosted: Thu May 15, 2025 3:57 am    Post subject: Accelerator cable does not slide well Reply with quote
Hello everyone,
In my 1960 Beetle when I replaced the new accelerator cable, it seems to get stuck when I accelerate.
Under my foot I feel the pedal that does not flow smoothly and tends to get stuck or go jerky. I also hear a squeaking sound of metallic material that perhaps also comes from the other end of the cable.
Can anyone advise me what to check and how to try to solve it?
Thanks
SuperDave63
SuperDave63 is offline
PostPosted: Thu May 15, 2025 7:42 am    Post subject: Re: Accelerator cable does not slide well Reply with quote
Do you have the guide tube for the cable installed? If so I'd put it up on jackstands and crawl underneath while someone steps on the pedal to try to locate the problem.
sportin-wood
sportin-wood is offline
PostPosted: Thu May 15, 2025 7:51 am    Post subject: Re: Accelerator cable does not slide well Reply with quote
It sounds like it's binding up somewhere. The guide tube should be a smooth surface for the cable to pull in and out through. I'd try disconnecting it from the pedal first and see if it's still rubbing by hand - it should be very easy to move by hand. Worse case, pull it back out and reinstall it to see if somewhere in the tube it was catching. Also inspect the cable when you remove it. Make sure it's not frayed somehow. Good luck!
Dave
1966 Bug project
1973 Thing project
VWLady
Crazy VW Lady
VWLady is offline
PostPosted: Thu May 15, 2025 8:40 am    Post subject: Re: Accelerator cable does not slide well Reply with quote
Were the engine compartment seals replaced recently? Have a look where the cable passes back over the front engine seal
Eric&Barb
Eric&Barb is offline
PostPosted: Thu May 15, 2025 9:37 am    Post subject: Re: Accelerator cable does not slide well Reply with quote
1960 was last model year for the type 1s having the throttle cable bracket to keep the cable from cutting into the transaxle nose cone.
More here on that and the later bowden throttle tube that could be installed in pre-1961 VWs.
https://www.thesamba.com/vw/forum/viewtopic.php?t=400171&highlight=accelerator+boden+tube
In Stereo, Where Available!
