paul_round Samba Member
Posted: Thu May 15, 2025 3:52 am Post subject: Deck lid latch release |
I've been having huge problems with my decklid release, as other people have said, sometimes it takes both hands to open it, yet sometimes it just will pop open whilst driving. I was wondering if anyone has used a solenoid / actuator to open the latch? |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 4113 Location: In Molinya Orbit
Posted: Fri May 16, 2025 3:28 am Post subject: Re: Deck lid latch release |
Hi Nicholas, yes, all greased up. Upon further investigation, I've found that the nylon tube, just behind where the knob is, has become distorted, possibly from heat? I think it's a repo tube, I'm thinking of replacing with some 8 or 10mm copper microbore tubing. Still doesn't explain it popping during a drive though. |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6091 Location: 37.5N 77.1W
Posted: Fri May 16, 2025 8:01 am Post subject: Re: Deck lid latch release |
Quote: |
replacing with some 8 or 10mm copper microbore tubing. Still doesn't explain it popping during a drive though |
I replaced mine with a tractor choke cable. Has a spring coil wrap. No 'slop'. The popping open is from a feature of the latch. If/when the cable breaks the rear hood unlatches. Yours must be too loose.  _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Posted: Fri May 16, 2025 9:23 am Post subject: Re: Deck lid latch release |
I've tried tightening / loosening it, goes between being impossible to open, to popping open.
The tractor cable sounds interesting, I guess the spring coil wrap is similar to that on a bicycle. |
Posted: Fri May 16, 2025 11:56 am Post subject: Re: Deck lid latch release |
you can see what I used....painted black of course.
Steelz21 Samba Member
Joined: January 09, 2017 Posts: 157 Location: Ontario canada
Posted: Sat May 17, 2025 4:59 pm Post subject: Re: Deck lid latch release |
Great idea with the tractor cable. When I lube mine, I get a build up of lube at the end then force it further in with a shot of compressed air. Works really well for me.
I use fluid film for lube. |
Posted: Sat May 17, 2025 5:04 pm Post subject: Re: Deck lid latch release |
I got some of that but I was going to use it as undercoating. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
ghiaueberalles67 Samba Member
Posted: Thu May 22, 2025 12:25 pm Post subject: Re: Deck lid latch release |
Can you elaborate on the tractor tube you used? Mine has been inoperable since 2003, but the deck lid is heavy enough that it never pops open, nor does it close and lock.
My cable is broken and I am looking for the best idea to fix it, to include doing nothing if that seems legit. |
Posted: Thu May 22, 2025 1:48 pm Post subject: Re: Deck lid latch release |
Quote: |
tractor tube you used |
Go to a Tractor Supple place and get a choke cable for a tractor. 6 to 7 foot will be enough. The stuffs easy to trim to fit. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
