Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1872 Location: S>E>Alabama
Posted: Wed May 14, 2025 10:54 am Post subject: rebuilt brake booster doesnt work |
Brake booster rebuilt by top VW brake outfit..all lines master wheel cyls and calipers new or rebuilt(71 Bus) Working with a vacume pump with pressure switch(didnt want to tap my then NEW Raby bus motor intake! Sooo a booster pump which functioned flawlessly for yesrs and in fact fine and dandy with the org booster..which did in fact work quite well...Prev. maint brain said" its 50 years old you did RVERYTHING ELSE Sooo off she went(booster) and came back 3 weeks later all shiny and ready to go....NOT!! Cannot get any boost and straong vacule at the line into the pump new ck valve..what am I doing wrong?? _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13504 Location: West Coast, USA
Posted: Wed May 14, 2025 11:03 am Post subject: Re: rebuilt brake booster doesnt work |
Come back with numbers. If you're seeing 18+ inches Hg, and getting no boost, something is wrong. But with aftermarket parts, you are the one responsible for confirming compatibility with measurements.
That, or your check valve is backwards. Arrow towards pump.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42642 Location: at the beach
Posted: Wed May 14, 2025 4:11 pm Post subject: Re: rebuilt brake booster doesnt work |
airschooled wrote: |
Robbie |
I would consider that Robbie is right on this one. Any top rebuilder would test their work before sending it out.
booster - airflow -> check valve -> vacuum source _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Wed May 14, 2025 7:58 pm Post subject: Re: rebuilt brake booster doesnt work |
Yes Spoke with the rebuilder the booster is an ATE stock to the vehicle. I will test if I have 18 Hg and the rebuilder suggested I disconnect the booster and drive it to see if there is any change in the braking. I do have good brakes..however I want my booster!! How would I test for a vacume number? _________________ 71 westfalia
aeromech Samba Member
Joined: January 24, 2006 Posts: 17653 Location: San Diego, California
Posted: Wed May 14, 2025 8:54 pm Post subject: Re: rebuilt brake booster doesnt work |
Boosters are simple devices. If you got it from a reliable source it’s probably good. Have you replaced your vacuum hoses using gates power brake vacuum hose 27231? 15/32 internal diameter _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Thu May 15, 2025 12:28 am Post subject: Re: rebuilt brake booster doesnt work |
It's more likely there's a hose disconnected, or some masking tape left blocking off the booster port… That's why we measure: 50% to get the results, and the other 50% to get our eyes on the simple solutions we overlook when working tired/hungry/frustrated.
Every chain auto parts store will rent a vacuum gauge. They look like this gallery picture I just found:
To the left, is vacuum, negative pressure, measured in inches of mercury (Hg.) On the right is low-pressure fuel pump testing, for carburetors and feeder pumps up to 10psi. You need to plumb this gauge into the vacuum line from vacuum source (vacuum pump in your case, engine usually,) to the servo. A stock bus will produce between 10 and 18 "Hg at idle, so it's best to be on the higher side so you get multiple pedals presses before depleting the system.
*A good booster/check valve will give you at least 3-4 pushes of the pedal after shutting down the engine. Any aftermarket system should be able to match that, at least.
Most auto parts stores will also have something like this, a universal T. You can chop it to the exact sizes if you like, but leaving it assembled works too, but just takes longer for the guage to respond.
https://www.autozone.com/fittings-and-hose-line-co...373175_0_0
I'd also like to know your vacuum pump make/model once you get this sorted. I'm always on the hunt for a quiet one; every pump I've heard is a bummer.
Good luck,
www.airschooled.com
Posted: Thu May 15, 2025 7:39 pm Post subject: Re: rebuilt brake booster doesnt work |
This one isnt quiet!! I thought about replacing the entire pump assy as well(its 13 years old may be tired. So new hoses and ck valve tommorrow t in line and then gauge _________________ 71 westfalia
W1K1 Samba Member
Joined: March 04, 2004 Posts: 5303 Location: Southern AB
Posted: Fri May 16, 2025 8:23 pm Post subject: Re: rebuilt brake booster doesnt work |
Good luck,
Robbie |
I was curious about my aftermarket booster and how much vacuum the EJ2.5 was pulling. The vacuum was 20 Hg at idle and dropped by 5 Hg every push of the pedal after shutdown. So it makes sense to have more pressure at idle to give you more pumps after shutdown _________________ 1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap |
Posted: Fri May 16, 2025 10:30 pm Post subject: Re: rebuilt brake booster doesnt work |
I’ve only installed one vacuum pump in a bus. It was a bad idea. I did however use rubber isolators to dampen the noise. You can easily find them on amazon _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2724 Location: Ocean Beach - San Diego
Posted: Sat May 17, 2025 10:26 am Post subject: Re: rebuilt brake booster doesnt work |
Good luck,
Robbie |
Me too! Amazon shows electric vacuum pumps at ~$200 +/- $50. Not cheap but getting the manifold tapped and running a rubber hose front-to-back is not cheap or easy. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for. |
SGKent  Samba Member
Posted: Sat May 17, 2025 12:48 pm Post subject: Re: rebuilt brake booster doesnt work |
OB Bus wrote: |
Good luck,
Robbie |
Me too! Amazon shows electric vacuum pumps at ~$200 +/- $50. Not cheap but getting the manifold tapped and running a rubber hose front-to-back is not cheap or easy. |
as long as you induction system pulls enough vacuum, it would be best to use a hose. If you use thin wall pipe, like VW did on later bays, you can replace much of the hose with that. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5173 Location: California's Hot and Smoggy Central Valley
Posted: Sun May 18, 2025 12:09 am Post subject: Re: rebuilt brake booster doesnt work |
When you reinstalled the booster, did you properly set the pushrod adjustment?
It’s been several years since I did this, and my memory may be playing tricks on me, but I know when I replaced the vacuum booster on my Vanagon, a small adjustment on the rod makes a huge difference in functionality. |
Posted: Sun May 18, 2025 7:38 am Post subject: Re: rebuilt brake booster doesnt work |
I set the rod where it was and possibly could adjust again(more push) and see ho w that works _________________ 71 westfalia
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1608 Location: New Brunswick,Canada
Posted: Sun May 18, 2025 8:22 am Post subject: Re: rebuilt brake booster doesnt work |
is the vacuum pump cutting out as it should when it reachs it set vacuum or does it just keep running ,and not reach the switch shut off vacuum .if it keeps running I would suspect a leak,or a failing pump ,if it shut off then I would suspect a rod adjustment or a faulty booster ,you may need to adjust the rod at the front as well as at the MC . _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy sold dec 2024
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Posted: Sun May 18, 2025 12:22 pm Post subject: Re: rebuilt brake booster doesnt work |
The pump runs and runs..so I purchased a new switch..NOT the exact switch...It still runs on forever....soooo I am installing ALL NEW vacume lines ck valve and pump... _________________ 71 westfalia
Posted: Sun May 18, 2025 12:23 pm Post subject: Re: rebuilt brake booster doesnt work |
I agree the pump may be tired..soo a new on is going in!! _________________ 71 westfalia
SGKent  Samba Member
Posted: Sun May 18, 2025 12:39 pm Post subject: Re: rebuilt brake booster doesnt work |
the Bentley explains how to adjust the brake servo rod for 1971 and later. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Sun May 18, 2025 3:35 pm Post subject: Re: rebuilt brake booster doesnt work |
if you block the intake for the pump ,can you feel suction ,and will the pump then shut off,if yes to both then the pump and switch is working ,although it don,t prove the switch setting, _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1974 parts bus
W1K1 Samba Member
Posted: Sun May 18, 2025 3:49 pm Post subject: Re: rebuilt brake booster doesnt work |
lil-jinx wrote: |
if you block the intake for the pump ,can you feel suction ,and will the pump then shut off,if yes to both then the pump and switch is working ,although it don,t prove the switch setting, |
you could always put the gauge on it to see if it's generating enough vacuum, and/or what pressure it is shutting off at
Posted: Sun May 18, 2025 6:59 pm Post subject: Re: rebuilt brake booster doesnt work |
Jinkx the vacume is present although not very strong feeling(finger tip gaugelol) and the pump does not shut off..henceforth the whole new pump assy and swithch being installed _________________ 71 westfalia
