vw51rag Samba Member
Posted: Fri May 16, 2025 9:30 am Post subject: Solex 30 pict 2 on 40hp |
| Any good or bad reason why I should or shouldn’t use a 30pict2 carb for my 40hp engine, wanted to do a big bore conversion in future along with Aircooled vintage Sebring style exhaust, Bosch 4r5 distributor? |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7578 Location: Houston, Texas
Posted: Fri May 16, 2025 12:38 pm Post subject: Re: Solex 30 pict 2 on 40hp |
The distributor will not work with that carburetor. Starting with the 30 PICT the vacuum signal got stronger than what you need. I assume you have a 28 on there now. That one has the correct vacuum signal for your distributor vacuum canister. _________________ www.vwnos.com [email protected]
Posted: Fri May 16, 2025 11:52 pm Post subject: Re: Solex 30 pict 2 on 40hp |
| Ok, thanks il stick with my 28 any other upgrades or mods you can recommend? |
Joined: April 27, 2002 Posts: 6869 Location: Pentwater, Michigan
Posted: Sat May 17, 2025 1:47 am Post subject: Re: Solex 30 pict 2 on 40hp |
If/when you do the big bore and change to the 30 PICT 2 you will want to find either a 113 M or T distributor or go with a mechanical advance only distributor. The 113 M or T are vacuum advance only aluminum bodied. _________________ Roads Scholar
Member# 2059 |
