Bevan Samba Member
Joined: April 16, 2014 Posts: 16 Location: United Kingdom
Posted: Sun May 18, 2025 11:44 am Post subject: Rear suspension/geometry question |
I have a short shaft swing axle on my 1966 Squareback. At rest and driving forward the car has a bit of rear negative camber. Whenever I reverse the car I get positive camber. I have dialed in more toe in thinking it might be the issue but it still happens. Do I need to dial in some toe out?
Any suggestions are greatly received.
Thanks. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36455 Location: Conejo Valley, CA
Posted: Mon May 19, 2025 8:52 am Post subject: Re: Rear suspension/geometry question |
Swing axle cars like a little toe-out at the rear anyway. It makes them more stable on undulating corners. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23610 Location: Kimball, Mi
Posted: Mon May 19, 2025 10:41 am Post subject: Re: Rear suspension/geometry question |
| Bevan wrote: |
Thanks. |
That's just the way it was designed. It happens on stock height, raised (off road) or lowered. It's also why Ralph Nader killed the Corvair due to the rear of that car doing the same thing. VW ended up going to IRS to help solve this problem, as did Porsche and eventually GM did with the last years of the Corvair. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Bevan Samba Member
Posted: Mon May 19, 2025 12:46 pm Post subject: Re: Rear suspension/geometry question |
| KTPhil wrote: |
| Swing axle cars like a little toe-out at the rear anyway. It makes them more stable on undulating corners. |
I had read that, reading what Bob said, I think I'll dial in some toe out and forget about it. I'll just make sure don't reverse when I park up
| Bobnotch wrote: |
| That's just the way it was designed. It happens on stock height, raised (off road) or lowered. It's also why Ralph Nader killed the Corvair due to the rear of that car doing the same thing. VW ended up going to IRS to help solve this problem, as did Porsche and eventually GM did with the last years of the Corvair. |
Cheers Bob. That makes a lot of sense. |
