Diesel van connector identification help
IronBenderII
IronBenderII is offline
PostPosted: Sat Apr 19, 2025 7:29 pm    Post subject: Diesel van connector identification help Reply with quote
Hi guys. I’m trying to identify this connector from my 82 diesel. It’s in the engine bay, probably on the passenger side. One wire is blue/yellow and the other is brown.
FIRST Robotics Coach - #3859 (Wolfpack Robotics) http://www.twitter.com/wprobotics
'82 Diesel Westfalia with an 1Z TDI, Peloquin, GW 1.5" lift springs, 27" BFG ATs
'75 Bronco with 408 stroker, 40" MTRs, ARB/Dana 60 front/rear, all home built.
And my kid has a really cool baja bug Smile
Jeffrey Lee
Jeffrey Lee is offline
PostPosted: Sat Apr 19, 2025 7:48 pm    Post subject: Re: Diesel van connector identification help Reply with quote
[Edited to add: for 1983 diesel Vanagons only!]
That would seem to be the plug which connects to the coolant temp sensor in the coolant expansion tank.
The tank is indeed located on the passenger side of the engine compartment, just forward of the starting battery.
If not connected, the red warning light on the dash should flash continuously.
Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat Apr 19, 2025 8:13 pm    Post subject: Re: Diesel van connector identification help Reply with quote
That connector isn't used for anything in 82 diesel Vanagons.
VW was clearly planning on having a coolant tank level sensor setup but it wasn't ready yet.
The 82 coolant tank has a blank spot where the sensor was planned to go.
That connector isn't wired in properly to make use of the 83+ tank level sensor and won't work right as it is.
Mark
IronBenderII
PostPosted: Sat Apr 19, 2025 8:52 pm    Post subject: Re: Diesel van connector identification help Reply with quote
Thanks all!!
IronBenderII
PostPosted: Sun May 18, 2025 4:12 pm    Post subject: Re: Diesel van connector identification help Reply with quote
Follow up question. Where does it go? I’ve been searching where the main bundle comes out in the dash and I can’t seem to find it.
crazyvwvanman
PostPosted: Sun May 18, 2025 6:30 pm    Post subject: Re: Diesel van connector identification help Reply with quote
The 82 diesel has 2 identical temp senders screwed into coolant hose flanges on the cylinder head.
One of them has a single wire to it, feeding the glow plug relay.
The other sensor has 2 wires to it.
One wire goes to the dash temp gauge and the other of the same color goes to that coolant tank sensor connector that was never used in 82.
The 83+ coolant tank level sensors won't work connected to that 82 sensor wire as it is.
There is a coolant level relay that must be added to the circuit in order for the 83+ level sensor to work.
Mark
IronBenderII
PostPosted: Mon May 19, 2025 7:21 am    Post subject: Re: Diesel van connector identification help Reply with quote
Thanks Mark. So that wire is in series with another sensor? I’ve been running continuity tests on the wires under the dash and can’t find the other end of the wire.
crazyvwvanman
PostPosted: Mon May 19, 2025 7:30 am    Post subject: Re: Diesel van connector identification help Reply with quote
Did you look at the 2 temp senders to see if your van still has 2 wires of that color going to one of them?
Mark
IronBenderII
PostPosted: Mon May 19, 2025 9:32 am    Post subject: Re: Diesel van connector identification help Reply with quote
Yeah, has two wires. Brown and blue/yellow.
Kdj
Kdj is offline
PostPosted: Mon May 19, 2025 10:17 am    Post subject: Re: Diesel van connector identification help Reply with quote
I just learned something, Hate that! Always wondered why my van had two sensors in the water outlet in head Embarassed . It was a Diesel originally then swapped to a 1.8L 8V some time before I got it. This info explains that now. Guess I didn't need to to drill the water out-let on my almost complete 07K swap. But the level sensor wiring is present and functioning, with a sensor in the original expansion tank.
With the 07k swap I plan on using a 2010 jetta expansion tank.
IronBenderII
PostPosted: Tue May 20, 2025 9:42 am    Post subject: Re: Diesel van connector identification help Reply with quote
Anybody know where the other end of the wire goes?
crazyvwvanman
PostPosted: Tue May 20, 2025 11:55 am    Post subject: Re: Diesel van connector identification help Reply with quote
I explained that already and asked a question you didn't really answer.
Mark
