NerdyGunny Samba Member
Joined: August 10, 2005 Posts: 397 Location: Tucson, AZ
Posted: Wed May 07, 2025 11:05 am Post subject: Automatic driving peculiarities - tips for driving an auto |
I recently picked up a 71 Automatic. I searched the forums for any peculiarities for driving an automatic.
About the only thing i was able to find was to let up on the acceleration to get it to shift to 3rd. (I haven't found this as necessary as i drive it mildly.. (slowly))
Is there anything that a driver should know?
Is it ok to put it in Neutral while at a stop light? How about putting it in Neutral as I roll up to a stop light?
Any other tips? |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36462 Location: Conejo Valley, CA
Posted: Wed May 07, 2025 11:11 am Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
Is it still FI?
It is vital to good running of both FI and the auto trans that there are NO (absolutely NO) vacuum leaks anywhere. This includes the MPS, all hoses, the kickdown valve, and all the air intake parts.
ANY leak will confuse both, and make them interact, resulting in stalling, poor acceleration, rich running, poor shifting, etc.
Ignition timing adjustment is also critical (normally TDC for a '71).
Make sure your kickdown switch on the throttle pivot is adjusted and wired correctly. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23611 Location: Kimball, Mi
Posted: Wed May 07, 2025 11:38 am Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
| NerdyGunny wrote: |
Any other tips? |
Not that I know of. I drive my wife's 70 Fastback w/FI like a go cart, full on the gas, then left foot brake. After all you only have 2 pedals. It's more fun to drive a slow car fast, than drive a fast car slow.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Posted: Wed May 07, 2025 12:08 pm Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
| KTPhil wrote: |
Is it still FI?
Make sure your kickdown switch on the throttle pivot is adjusted and wired correctly. |
No FI... was converted to dual ICT's... |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18056 Location: Eugene, OR
Posted: Wed May 07, 2025 1:46 pm Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
Keep the AT filled with ATF & the separate transaxle filled with 80-90 weight gear oil.
17mm plug on the side to fill gear oil.
I love my FI/AT 69 square.
Dual carburetor AT might take a little more fine tuning. _________________ 69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2207 Location: Gardnerville, NV
Posted: Thu May 08, 2025 10:03 am Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
| Bobnotch wrote: |
It's more fun to drive a slow car fast, than drive a fast car slow.  |
Amen! _________________ If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
KTPhil  Samba Member
Posted: Thu May 08, 2025 11:43 am Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
Do you have a kickdown switch on the carb linkage? _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Roadbeater Samba Member
Joined: January 15, 2011 Posts: 67 Location: Central Ohio
Posted: Thu May 08, 2025 1:48 pm Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
Took my drivers test in a 70 squareback automatic. I drove it like I stole it for many years, as kids will do. Hope yours holds up as well _________________ 69 Fastback |
Posted: Thu May 08, 2025 2:13 pm Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
| NerdyGunny wrote: |
It'll need to be fine tuned to get it right. I firmly believe that AT really likes FI. I only say that, as my wife's car had carbs (stock Solex) on it, before I returned it to FI. With the carbs, it shifted okay and drove okay, but the FI seemed to really wake it up. It was like a different car.
It's not really the carbs fault either, as I've ICTs on my 65 Notch before, then converted it to Solex carbs. The only difference I noticed was picking up 1-2 mpg with the Solex carbs. Otherwise the car ran and drove the same. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 6041 Location: Brooklyn
Posted: Thu May 08, 2025 2:14 pm Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
There is no mechanical benefit to putting the transmission in neutral at a light, unless you tire of holding the brake pedal to prevent creep.
The reason to put a manual in neutral at a light is to prevent excess wear of the throwout bearing and to prevent wear of the thrust surface of the crankcase due to the pressure from the clutch pressure plate. Neither of these are concerns with the automatic. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Sat May 17, 2025 5:00 pm Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
| KTPhil wrote: |
| Do you have a kickdown switch on the carb linkage? |
As this car is new to me and the fact I dont know alot, i had to go look. Honestly, i had to look up what a kickdown switch is.
I dont see one based on the pic's i looked up... here are a few pics of the engine bay.... (yes, I'll be removing the plastic filter)
KTPhil  Samba Member
Posted: Mon May 19, 2025 8:55 am Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
Looks like an aftermarket linkage, without a provision for a kickdown switch, so you'll have to get creative.
The stock dual carb carb linkage has this switch mounting:
Look for a micro-switch like these, and fab up a spring/mount.
https://www.google.com/search?q=micro+switch&v...&udm=2 _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Posted: Mon May 19, 2025 10:47 am Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
| NerdyGunny wrote: |
| KTPhil wrote: |
Yeah, I don't see one either. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
KTPhil  Samba Member
Posted: Mon May 19, 2025 11:55 am Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
If you do seek to fab a switch, keep in mid the reason for the spring setup on the stock linkage.
You want to feel resistance in your foot when you fully open the carb throttle plates.
But to kick down, you have to press further, without snapping the cable.
So once the first position is reached (full throttle), you will feel the added resistance of this linkage spring, but can press further (actuating the microswitch).
Once your foot learns this feel, you can up and down-shift with your right foot very precisely. It's worth working this out. Maybe even go back to a stock linkage, though those are hard to find and the switches are NLA (so I posted the link above for those). _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5583 Location: Lefty, CA
Posted: Wed May 21, 2025 5:18 pm Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
Honestly, I have been using some form of non stock kick down switch with out the spring for about 15 years. You just set the switch to where it closes at WOT. I drew up a little diagram of what the OP could put in his car if he wanted kick down capabilities (he really does )
First off here is the type of switch that you would want.
Here is where you would put it.
Here is the drawing of the assembly.
As you can see, it could be made with the most simplest tools. Just a hacksaw, and a drill. Once you experience the advantage of having the kick down switch, you never go back without one. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Posted: Fri May 23, 2025 10:46 am Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
I was thinking maybe something off the right carb to activate the kick down switch. I'm not sure how that center part works, as it looks pretty complicated, compared to even the stock set up, let alone your link bar set up (don't know if there's room to mount a switch).
As for the switch itself, that should be fairly easy to get, as they're used on NOS systems to activate Nitrous, and used for washing machines and dryers to turn the unit on/off if the door is opened (safety switch). I mean if the OP wanted to, he could mount a normally open (closes when pushed) push button switch on the shifter to activate the kick down function too.
Just a couple of random thoughts. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Posted: Fri May 23, 2025 1:25 pm Post subject: Re: Automatic driving peculiarities - tips for driving an auto |
I went out to my shed and look at my original Type 3 engine, with similar linkage, and I believe that the OP should have room. When hooking up something like a kick down switch, you always want the linkage arm that is connected to the throttle cable to make contact with the switch.
Unless you running something like a Berg linkage, most linkages have so much flex that you can get inconsistent results if mounted in other locations _________________ 69 road Bug 2110
My builds
