Engine/Transmission removed where and how would you start?
Page: Previous  1, 2, 3, 4 ... 12, 13, 14  Next
SGKent Premium Member
SGKent is offline
PostPosted: Tue May 20, 2025 12:53 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
poundman wrote:
Ordering part for my transmisson refresh and I have a few questions. I have 002 trans.
Transmission side
Rear final drive seals (I have the caps already)
https://www.busdepot.com/002301189c
Do I need Nosecone Bushing & Seal Kit
https://www.busdepot.com/001301200
Manual Transmission Main Input Shaft Seal
https://www.busdepot.com/113311113a
Throwout bearing
https://www.busdepot.com/113141165b
Clutch kit - I had to cut the old one out
https://www.busdepot.com/211798335x
Engine Side
Pilot shaft bearing (needle bearing) Does this go behind the seal?
https://www.busdepot.com/002311125a
Rear Crankshaft seal
https://www.busdepot.com/029105245
Front crankshaft seal
https://www.busdepot.com/021105247a
What am I missing?
You be careful removing the 002 side seals. Do not damage what is behind it. You do not need to remove the adjusters to pull the seal but use the right tool. Last year we had someone on this forum damage the bearings behind it replacing those seals. Use the correct seal puller.
The nosecone will be worn into by the main bearing. This allows the alignment of the gears to change. You will want to sand it or mill it and put in a steel plate that will hold the main bearing where it should be. Also replace the donut inside the nosecone, and check the selector lever for cracks. They do break.
in a type 1 engine the pilot bearing is in the gland nut. In a type 4 engine it sits in the crankshaft. You will need a pilot bearing puller to remove it. Weddle will have any parts you need.
plate
George Carlin:
Skills@EuroCarsPlus:
Wildthings
Wildthings is offline
PostPosted: Tue May 20, 2025 12:57 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
If the flywheel and clutch cover aren't badly scored, I just take a Dremel with a ball stone on it and quickly go over the surface with a back and forth motion. This idea is to lightly roughen the surface taking hardly any material off, just a couple of minute on each the flywheel and clutch cover will do.
poundman
poundman is offline
PostPosted: Tue May 20, 2025 1:26 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
plate
Thanks, I did read about the person damaging the bearings. I was very careful and have removed 1 side with a seal puller. No damage. The cap and the ring were harder than removing the seal.
I will need to search some videos for the nosecone kit. Besides making sure the main bearing doesn't come out, is there any other risks. Is it worth doing? I am not sure how the plate be used while replacing.
On needle bearing, yes I will order a puller.
Restoring a 1972 Bay Window Bus that has not be registered for the road since 1981.
Sugar Land, Texas
SGKent is offline
PostPosted: Tue May 20, 2025 2:49 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
I've never heard of the main bearing falling out. Later bays with the 091 have a half moon retainer that minimizes the bearing from spinning, but 002 lack that. Just go slow and careful.
If you get up the nerve, you can pull the bellhousing and inspect the ring gear and lock nut to make sure the ring and pinion are not spalling and that the lock nut is not coming loose. That is a subject all on its own.
George Carlin:
lil-jinx
lil-jinx is offline
PostPosted: Tue May 20, 2025 2:58 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
i think you also need a o- ring that goes on the engine side of the flywheel.
1968 Dune Buggy sold dec 2024
1974 parts bus
SGKent is offline
PostPosted: Tue May 20, 2025 3:24 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
get the good one that has the silver colored dust on it and not a cheap repop.
George Carlin:
poundman
poundman is offline
PostPosted: Tue May 20, 2025 7:25 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
Is this the o-ring you are referring to? This says up to 1971.
https://www.busdepot.com/311105295a
Maybe those are in one of these kits
https://www.bughaus.com/type252.htm
https://www.busdepot.com/021198009b
Sugar Land, Texas
poundman
poundman is offline
PostPosted: Tue May 20, 2025 7:43 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
I tested the end play. It was .005 inch, which is within tolerance. It felt very tight. Now the dumb question, are the bolts holding onto the flywheel reverse thread or regular. I could not move them but I stopped because I didn't want to make a mistake. I might need to clean the oil off the bolts and get more leverage, or borrow a impact driver.
Sugar Land, Texas
timvw7476
timvw7476 is offline
PostPosted: Tue May 20, 2025 9:01 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
flywheel bolts are standard RH thread. Maybe with some loctite for extra insurance.? : l
could be worse. could be the type 1 Gland Nut.
SGKent is offline
PostPosted: Tue May 20, 2025 9:54 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
the o-ring is part number 021-105-279 for a type 4 engine. The good ones will look silver but it is a coating on them.
George Carlin:
lil-jinx
lil-jinx is offline
PostPosted: Wed May 21, 2025 6:19 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
my back yard method,i used a deep socket and a extension to increase leverage,note my fly wheel holding tool.
https://www.thesamba.com/vw/gallery/pix/1587629.jpg
1974 parts bus
poundman
poundman is offline
PostPosted: Wed May 21, 2025 9:04 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
Thanks for the part number. Do you happen to know the part number for the o-ring on the front side?
Sugar Land, Texas
poundman
poundman is offline
PostPosted: Wed May 21, 2025 9:07 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
That is a great picture and ideas. I did purchase the lock, i just need more leverage. I guess 80 lbs is a lot for a regular socket wrench. Plus the whole engine was turning sideways, I need to secure it better to the ATV lift I have it on. My biggest fear is breaking a bolt head at this point.
Another thing I just realized is that I might want to remove the front bolts/stuff before I remove the flywheel because I need that as leverage.
Sugar Land, Texas
SGKent is offline
PostPosted: Wed May 21, 2025 1:23 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
buy a breaker bar and also make sure you have a torque wrench that reads to 80 ft lbs accurately.
flywheel lock https://www.amazon.com/Universal-Flywheel-Holder-Volkswagen-Porsche/dp/B0BZ4H2ZWB
George Carlin:
lil-jinx
lil-jinx is offline
PostPosted: Wed May 21, 2025 2:29 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
80 ft lbs s not very tight ,think of a wheel nut at 100 ft lbs,there may be lock tight on the bolts,they are a fairly stout bolt,i don,t think they will snap off with hand tools.
1974 parts bus
SGKent is offline
PostPosted: Wed May 21, 2025 2:39 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
they use a thin metal plate that needs to be replaced as a locking method.
Poundman - What O-ring are you referring to? The one between the fan mount adapter and the crankshaft?
George Carlin:
lil-jinx
lil-jinx is offline
PostPosted: Wed May 21, 2025 3:06 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
I think you are mistaken on that SGKent,the bolts are self locking,serrations under the head,,yes there is a washer ring that goes under the bolts but it don,t get bent,i beleive it's there partly to give the self locking bolts something to bite into without marring the fly wheel.
1974 parts bus
Wildthings
PostPosted: Wed May 21, 2025 3:13 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
I just put two bolts into the flywheel, and use a longish tire iron between the bolts with its other end on the ground to keep the crank from turning.
I use the larger of these two bars
The bolt the holding the fan hub to the crank has a very low torque, so very little force is normally needed to remove it, even if it has loctite on the threads.
SGKent is offline
PostPosted: Wed May 21, 2025 3:57 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
I am not mistaken. The softer metal ring/plate can't rotate because it is locked by the bolts going thru the holes. The softer metal allows the bolts to bite into it rather than marring the crankshaft. It can be flipped over if a new one is not available at the moment.
VW says to replace the bolts but originals went NLA a couple years ago. For what it is worth, a friend and I were putting a Corvair flywheel back on years ago and the flywheel bolts had crystalized in the six or seven years old that they were. They snapped way below the specified torque. As I recall, about 35 - 40 ft lbs they sheered. For that reason I keep spare flywheel bolts around and never discard them, using the spares for mock up and end play adjusting, and saving the good new ones for final assembly. I am well aware how those bolts bite into the metal plate. Smile
George Carlin:
lil-jinx
lil-jinx is offline
PostPosted: Wed May 21, 2025 5:23 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
my apologies ,i read your post as having to bend the washer to lock the bolt.i agree that the washer is there to give the lock bolts some bite
1974 parts bus
Page 3 of 14
