AnnaTee Samba Member
Posted: Wed May 21, 2025 2:40 pm Post subject: Mechanic refused to return old parts |
I reluctantly asked a mechanic for some help with my bus and made sure they knew that if any old parts were taken off that I wanted them returned to me so I could rebuild them later or just keep them as mementos etc. When I picked up my bus the mechanic claimed to have thrown out my parts. What should I do? How should I feel? I can't get my parts back!  |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79282 Location: Sneaking up behind you
Posted: Wed May 21, 2025 2:55 pm Post subject: Re: Mechanic refused to return old parts |
Take them to small claims court. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4903 Location: Stuck in Ohio
Glenn  Mr. 010
Posted: Wed May 21, 2025 3:15 pm Post subject: Re: Mechanic refused to return old parts |
If the mechanic replaced an original Solex carb and Bosch distributor with Chinese crap, those original parts have value can be rebuilt and put back on the engine.
Over the years, mechanical tossed away millions of good rebuildable carbs and distributors because it was easier to just swap in a new part. But at least, 30 years ago, the replacement parts were of decent quality, unlike now.
And don't get me started on all those that tossed the thermostat and flaps... because you don't need them  _________________ Glenn
Member #1009
#BlueSquare
ComfortablyNumb Samba Member
Joined: February 19, 2025 Posts: 25 Location: Washington State
Posted: Wed May 21, 2025 4:26 pm Post subject: Re: Mechanic refused to return old parts |
California, where I was hatched and spent 40 some odd years, has a Bureau of Automotive Repair (https://www.bar.ca.gov/) You might check with them. |
wcfvw69 Samba Purist
Posted: Wed May 21, 2025 5:43 pm Post subject: Re: Mechanic refused to return old parts |
What parts did you request to have back? What did they install? _________________ Contact me at [email protected]
The Samba member since 2004.
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7435 Location: Houston, Texas
Posted: Wed May 21, 2025 5:57 pm Post subject: Re: Mechanic refused to return old parts |
How important are the parts to you? Sometimes life is too precious to trouble yourself. _________________ www.vwnos.com [email protected]
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15104 Location: Casa de Oro, California
Posted: Wed May 21, 2025 6:37 pm Post subject: Re: Mechanic refused to return old parts |
One thing that comes to mind is did they really replace those things? They can't show you the parts because they are still on the bus. |
Lind Samba Member
Joined: November 06, 2000 Posts: 10195 Location: idaho
Posted: Wed May 21, 2025 8:32 pm Post subject: Re: Mechanic refused to return old parts |
At my shop, we keep all the old parts to show the customer when they pick up their car. They are welcome to keep them if they want to, but virtually all just have us throw them away or recycle them. Many don't even want to see the parts, they just pay the bill and drive their car away. _________________ .
Wanted:
Posted: Thu May 22, 2025 1:07 pm Post subject: Re: Mechanic refused to return old parts |
They swapped out my old parts for cheap new parts, some weren't even on the work order. Half of the parts that were replaced were faulty and instantly needed fixing, including a fuel leak from a brand-new fuel tank. I have before and after photos and I know exactly what was swapped out. I'm in shock at what they did. This is a bus that my dad worked on, and his mom drove. |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23643 Location: NYC/Upstate/ROW
Posted: Thu May 22, 2025 5:20 pm Post subject: Re: Mechanic refused to return old pa |
Then you move on, find a new mechanic, or do it yourself.
The value of your old parts is scrap metal, less than the the filing fees in Court
Scrap metal, filings, there is some good material there. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
BarryL  Samba Member
Posted: Thu May 22, 2025 6:23 pm Post subject: Re: Mechanic refused to return old parts |
AnnaTee wrote: |
I have before and after photos and I know exactly what was swapped out. |
Could you please post up photos? |
Posted: Fri May 23, 2025 1:25 pm Post subject: Re: Mechanic refused to return old parts |
BarryL wrote: |
AnnaTee wrote: |
I'm not sure how much I should share on here in case I end up going to court. |
Posted: Fri May 23, 2025 1:30 pm Post subject: Re: Mechanic refused to return old pa |
Abscate wrote: |
Scrap metal, filings, there is some good material there. |
I have moved on, found a new mechanic and do most things myself.
I don't want to deal with the hassle of taking the mechanic to court but I also feel like if I don't speak out about what happened they will do the same to others. I guess I'm seeking support. |
Glenn  Mr. 010
Posted: Fri May 23, 2025 1:57 pm Post subject: Re: Mechanic refused to return old parts |
Care the name the shop so others can be warned? _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri May 23, 2025 4:13 pm Post subject: Re: Mechanic refused to return old parts |
Maybe this will help.
Years ago, my father took his truck in to have it smog checked (a California thing coming to a state near you sooner or later). While he was waiting another customer who had just left returned and said his check engine light had come on. The service guy said they would check it out. Came back in bit and said it was his disgronificator. and for x amount they could fix it. Guy has them do it and leaves. My father gets his truck back and his check engine light comes on. He pops the hood and looks around. He finds a paper clip jammed into something. Check engine light goes out when he pulls out the paper clip He thinks to himself what a bunch of crooks they are and goes on his way. I asked if he reported them to the BAR. He said he didn't want to take the time or trouble. Now myself, I would have because they are going to keep on doing it until someone who catches on reports them.
Later, after we took over care for him (he had Alzheimer's) I was having his 1956 Ford F-100 restored. (I'll include the backstory of the truck at the end of the post for those who might be interested.) When I took the seat out, I discovered under a black seat cover the original seat fabric was still there, which I thought was kind of cool and would make interesting wall art. When I took the seat into the upholstery shop, I also took the original seat fabric to show them how I wanted the new seat stitched up and made it very clear I wanted it back. When I went to pick up the finished seat the shop owner was beaming and proud of how the seat had turned out, which was very good. When I asked for the original seat, he stammered that they had thrown it out. We went to the dumpster and found a couple of pieces of it; they had taken it apart when they were making it and tossed it as they went. I kept my composure, but did express my disappointment. I paid him for his work and didn't pursue any action because the seat only had sentimental value, and nothing was bringing it back.
What I'm offering with those stories is that only you can decide what you want to do, and you don't need validation. Weigh it out and do what you think is right. Best to you in whatever you choose to do.
Okay, backstory on the truck. In October of 1955 my father was working after school bagging groceries. He wanted to buy one of the 1956 pickups that had just come out. The bank told him that because of his age, his parents would have to co-sing the loan. He asked his mother, who told him to forget about it, there was no way on God's green earth it was going to happen. He then asked his father, who told him to give him a couple of days to think about it. My grandfather came back and told him that he would co-sign the loan on one condition, if he missed the first payment, or the last payment, he was to hand over the keys. My father said that was kind of harsh, he was just working part-time after school. My grandfather said that was the offer, take or leave it. My father asked for a couple of days to think about it, then went and asked his older sister, who was working full-time, if she would help him out if he got into a jam. She said yes, he told her not to say anything and went and told my grandfather he was on. My grandmother was ready to kill my grandfather, but my grandfather thought he was going to get a new pickup half paid for. My father never missed a payment or had to ask for help from his sister. He also never got rid of the truck; it was his daily driver into the 1980's. In 1957 he drove my pregnant mother to the hospital and brought me home in that truck, which is sitting in one of my outbuildings. It's too bad he wanted a Ford and not a Splittie! |
Malokin Martin Samba Member
Posted: Fri May 23, 2025 8:02 pm Post subject: Re: Mechanic refused to return old parts |
What.
Parts.
Stocknazi Samba Member
Posted: Sat May 24, 2025 8:04 am Post subject: Re: Mechanic refused to return old parts |
AnnaTee wrote: |
Not surprising at all. Better make sure what you buy now is not junk right out of the box or the wrong part and get that sorted ASAP.
It would be interesting to know how many parts vendors sell every year that are junk/incorrect and the buyer only finds out months/years later with no recourse with the seller??? It happens more than you think.
Almost all the time new parts are inferior to NOS or even used original parts; I'm willing to bet that you'll need at least one of those parts in the near future to swap with the new stuff your "mechanic" installed. _________________ WANTED:
Thomas Jefferson |
finster Samba Member
Joined: May 26, 2012 Posts: 9817 Location: not far from the madding crowd
Posted: Sat May 24, 2025 9:51 am Post subject: Re: Mechanic refused to return old parts |
Glenn wrote: |
Care the name the shop so others can be warned? |
this, surely. _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
RLFD213 Samba Member
Posted: Sat May 24, 2025 10:10 am Post subject: Re: Mechanic refused to return old parts |
What parts were replaced? If it’s things like brakes and spindles, etc if they’re in good condition they probably kept them and then sold them to another customer. I know a few shops that do this. But they do it after the work is done and customer accepts the car back and refuses to takes their old parts back. |
