Starter purchase
ryansdad03
ryansdad03 is offline
PostPosted: Sun Feb 02, 2025 9:52 pm    Post subject: Starter purchase Reply with quote
I am in in need of a new starter for my car. Is there a huge advantage to buying a $250 Bosch starter versus a lesser expensive starter?
————————I'm your huckleberry————————
67rustavenger
67rustavenger is offline
PostPosted: Sun Feb 02, 2025 10:38 pm    Post subject: Re: Starter purchase Reply with quote
Buy an AutoZone self supporting autostick trans starter and never look back.
They come with a lifetime warrantee. So you'll never have to buy another one if it fails. The are under $200 without a core exchange cost.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
zerotofifty
zerotofifty is offline
PostPosted: Sun Feb 02, 2025 10:57 pm    Post subject: Re: Starter purchase Reply with quote
Aint the auto stick only in 12 volt flavor?
and no, an expensive Bosch new starter is not needed.
you need to ask, 12 volt or 6 volt, and of course which flywheel you have. Some folks like me have a 6 volt flywheel and 6 volt starter, but run it on 12 volts power.
there are some rare instances of a 12 volt starter converted to work on a 6 volt flywheel.
the two types of flywheels have different gear pattern, so you need the correct starter motor gear to mesh with the flywheel you got. VW changed that gear pattern at the time they changed from 6 to 12 volts in 1967*
* however VW did make a rarish 12 volt system on some early car i believe that used the 6 volt gear pattern. Porsche 356 also could come with this set up or folks converted on their own.
I am a bit fuzzy on these details, smarter folks may correct me.
but you need to select the voltage and the gear pattern of the starter.
some also run the 6 volt system starter with a 12 volt solenoid when running on 12 volts, as this reduces the wear on the gears during meshing when running 12 volts on a 6 volt starter.
later bigger engines had a bigger clutch and most all those flywheels are 12 volt gear pattern, although there was a Bus (Micobus) big clutch flywheel that was also 6 volt gear pattern. folks that keep the 6 volt system, but build a bigger engine that needs the bigger clutch will use this Bus flywheel.
But oft you can find some just fine used starters for little money, no need to break the bank on this.
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Sun Feb 02, 2025 11:13 pm    Post subject: Re: Starter purchase Reply with quote
6v or 12v?
If 6v, you might want to have yours rebuilt or consider this one from NAPA (lifetime warranty ... $95).
https://www.napaonline.com/en/p/RAY2444237
If you decide on the 6v remanufactured one from NAPA, keep your old one. 6v components are getting harder to find and a rebuildable core is worth keeping, especially if it is an original Bosch unit.
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Mon Feb 03, 2025 12:39 am    Post subject: Re: Starter purchase Reply with quote
Local generator/starter/motor/armature rebuilding shops -whatever flavor they advertise - can do a good rebuild on your stock starter. If you're not pressed for time, consider bringing yours by a shop and ask them about it.
Robert in Memphis
Engine rebuild thread
pantone149
pantone149 is offline
PostPosted: Fri Feb 07, 2025 1:49 pm    Post subject: Re: Starter purchase Reply with quote
What scrivyscriv says. That way you are 100% certain everything goes back together as expected. No mis-aligned anything.
ZEKE65
ZEKE65 is offline
PostPosted: Wed May 21, 2025 3:32 am    Post subject: Re: Starter purchase Reply with quote
Just bought a new Bosch starter SR15N from Amazon for my beetle. The one they sent does not have the notches to work with the d headed bolt, so you need two people to tighten the bolt. Not sure if all new Bosch are this way, but J Bugs says theirs are also. New Chinese engineering. Sent it back and bought a rebuilt from O'Rieleys.
1965 VW Sedan, 1968 C10 Step BB, 99 C5
Cusser
Cusser is offline
PostPosted: Wed May 21, 2025 6:44 am    Post subject: Re: Starter purchase Reply with quote
ZEKE65 wrote:
Just bought a new Bosch starter from Amazon for my beetle. The one they sent does not have the notches to work with the d headed bolt, so you need two people to tighten the bolt. Not sure if all new Bosch are this way, but J Bugs says theirs are also.
Was this a 6-volt or 12 volt starter?
O'Reilly's is even better than O'Rieleys !!!
matthew henricks
matthew henricks is offline
PostPosted: Wed May 21, 2025 8:45 am    Post subject: Re: Starter purchase Reply with quote
FWIW i bought a rebuilt unit from the FLAPS and it was a Bosch starter with aftermarket solenoid. Done that twice now.
1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat.
chrisflstf
chrisflstf is offline
PostPosted: Wed May 21, 2025 9:19 am    Post subject: Re: Starter purchase Reply with quote
Rockauto has automatic starters for $43, plus 10 for core charge
Fyi... auto starters have high failure rate for solenoids. They arent same as manuals and nobody makes replacements.
zerotofifty
PostPosted: Wed May 21, 2025 2:29 pm    Post subject: Re: Starter purchase Reply with quote
Oh Really?????? Wink
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
ZEKE65
ZEKE65 is offline
PostPosted: Wed May 21, 2025 4:15 pm    Post subject: Re: Starter purchase Reply with quote
12 volt, believe that my problem was the solenoid, and the three different starters that I looked at all had a different type solenoid on them. Could not find a source just for the solenoid.
tasb
The Distributor Distributor
tasb is offline
PostPosted: Wed May 21, 2025 8:47 pm    Post subject: Re: Starter purchase Reply with quote
Have you tried doing a classifieds search here on TheSamba?
Roads Scholar
Member# 2059
Wayne S. Johnson
Wayne S. Johnson is offline
PostPosted: Thu May 22, 2025 10:23 am    Post subject: Re: Starter purchase Reply with quote
I have 12V auto, 12V std. and 6V starters.
Hybrid 6/12 and Hybrid 12/6.
6/12 is for a 12V system on a 180mm flywheel.
12/6 is for a 6V system on a 200mm flywheel.
No core charge
HYBRID STARTER 6/12 https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231
aquifer Premium Member
aquifer is offline
PostPosted: Fri May 23, 2025 10:23 am    Post subject: Re: Starter purchase Reply with quote
This. If your starter is original to the car, you get the benefit of retaining it. There is some satisfaction to that, I've found.
Project vehicles:
1967 Beetle #1. Bought in 2024, mostly original, October 1966 build date. Java Green.
1967 Beetle #2. Bought in the mid 80's, restored myself in the late 90's, June 1967 build date. Java Green.
1998 Jaguar XJR. Bought in 2015, rust free AZ car, refurbished myself. Driven in nice weather.
Parts needed:
Original brown rubber floor mats for a '67
Original gazelle seat upholstery for a ‘67
