VW Sand Rail noises... any ideas?
Wisdumb
Wisdumb is offline
PostPosted: Wed May 21, 2025 12:56 pm    Post subject: VW Sand Rail noises... any ideas? Reply with quote
Hello everyone!
I've been working on restoring a sand rail after it was in a fire and I've run into an issue that I can't diagnose. Lots of noises coming from behind me when driving.
I've done a lot of work to this rail recently, but it wasn't drivable before the work so I don't have a reference point to know if any of the new parts are causing the issue. I've replaced all of the engine tins, fan/shroud/hardware, CVs, rotors/calipers, shocks, ball joints, distributor, plugs, wires, carbs, and probably some things I can't remember at the moment.
I recorded the sounds and made a video with subtitles at this link:
https://www.youtube.com/watch?v=hpE4KGiI14w
If anyone has any insights, I am all ears.
Thanks in advance to anyone that spends any amount of time looking at this post. I appreciate all of your knowledge and experience.
jinx758
jinx758 is offline
PostPosted: Wed May 21, 2025 3:13 pm    Post subject: Re: VW Sand Rail noises... any ideas? Reply with quote
Howdy ... & welcome
Maybe CV joints.
Overdue for valve adjustment also.
Possible exhaust leak as well.
Welcome to the madness ... stay safe
jinx
PS :
Cool forum handle, made me chuckle !
" It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor
MrGoodtunes
MrGoodtunes is offline
PostPosted: Thu May 22, 2025 8:27 am    Post subject: Re: VW Sand Rail noises... any ideas? Reply with quote
Hard to say with so many various sounds, but I am hearing what might be the cooling fan scraping inside fanshroud?
While at idle (with parking brake set) grab hold of fanshroud top, then push & pull, to see if any change in sound.
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Thu May 22, 2025 11:42 am    Post subject: Re: VW Sand Rail noises... any ideas? Reply with quote
It seems like you have something creating a harmonic whether that be a CV or bearing that needs attention and it's making everything shake and rattle. The lower frequency rattle sounds like the culprit and I would start by checking the cvs. Make sure ther are clocked correctly and all the cv parts are fitting together right. Google a video on how to do this if you need to.
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
ORANGECRUSHer
PostPosted: Thu May 22, 2025 11:43 am    Post subject: Re: VW Sand Rail noises... any ideas? Reply with quote
I don't think it's the engine. Can't be sure but that's not screaming out at me for some reason.
Brian H.
ORANGECRUSHer
PostPosted: Thu May 22, 2025 11:45 am    Post subject: Re: VW Sand Rail noises... any ideas? Reply with quote
I've also heard something similar when there was a tire issue.
Brian H.
BFB
BFB is offline
PostPosted: Thu May 22, 2025 6:36 pm    Post subject: Re: VW Sand Rail noises... any ideas? Reply with quote
If it burnt if a fire then its probably ghosts
Most experts aren't.
Wulfthang
Wulfthang is offline
PostPosted: Thu May 22, 2025 7:50 pm    Post subject: Re: VW Sand Rail noises... any ideas? Reply with quote
That's just cruel, man! Ghosts. Sheeiit. Obviously, It's not ghosts. Something came back with it from The Other Side. (Insert twilight Zone music here) Some Thing.
BFB
BFB is offline
PostPosted: Sat May 24, 2025 4:46 pm    Post subject: Re: VW Sand Rail noises... any ideas? Reply with quote
Oh shit thats even better!
Maybe it’ll turn out to be like “Christine”
Wulfthang
PostPosted: Sat May 24, 2025 7:44 pm    Post subject: Re: VW Sand Rail noises... any ideas? Reply with quote
Yeah, I've sometimes wondered if my car was a type of Christine, with as much of my blood as she's bled me for.
Wulfthang
PostPosted: Sat May 24, 2025 7:48 pm    Post subject: Re: VW Sand Rail noises... any ideas? Reply with quote
Yes, I am hearing some kind of drive train noise. That clicking on start up might be a bad wheel bearing or a CV joint. Later on, it sounds like the fan is dragging on the housing.
WaterBuggy_24
WaterBuggy_24 is offline
PostPosted: Sun May 25, 2025 12:12 pm    Post subject: Re: VW Sand Rail noises... any ideas? Reply with quote
Wisdumb wrote:
Hello everyone!
The loudest sound of the "clicking/clacking", in my opinion is definitely part of the drive train after the engine. Say like differential or cv joints.
If you let the transaxle slow the vehicle instead of the brakes, how does it change the tone of the sound. Does it quiet or get louder?
One day, I may learn.
Probably not today though.
