58 loose steering
PhilKo
PhilKo is offline
PostPosted: Thu May 22, 2025 11:04 am    Post subject: 58 loose steering Reply with quote
I have a dune buggy with a 58 pan. 8 years ago, I took off the hood to fix some things, including the string coupler. When I put it back together, I found the steering shaft was loose inside the steering shaft tube at the top. I checked the steering column bushing, and it is intact, so I think maybe I left out a part.
I talked to the folks at a reputable VW parts house, and they did not know what it was. Do you have any ideas what I missed?
Thanks for any help:)
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Fri May 23, 2025 1:48 am    Post subject: Re: 58 loose streering Reply with quote
I’m not very familiar with that early of a beetle so apologies in advance. When you say it has movement, is it in and out axial play, or wobbly side to side radial play?
Can you take the steering wheel off and see what the upper bearing looks and feels like?
Robert in Memphis
Engine rebuild thread
Dougy Dee
Dougy Dee is offline
PostPosted: Fri May 23, 2025 6:00 am    Post subject: Re: 58 loose streering Reply with quote
Possibly missing Steering Column Bushing 111415581A
Originally a non-plastic piece (maybe Micarta) like my original but Wolfsburg has a plastic one.
PhilKo
PhilKo is offline
PostPosted: Sun May 25, 2025 3:38 pm    Post subject: Re: 58 loose streering Reply with quote
Thank you for responding:)
The play is side to side/up and down. I have the bushing. It has been a long time, but I feel like it was a thick washer that fit inside to column tube and around the steering column. That makes sense?
Louie Lozano
Louie Lozano is offline
PostPosted: Tue Aug 05, 2025 3:27 pm    Post subject: Re: 58 loose streering Reply with quote
Hello,
I have the same problem, but my beetle is a 1960 that I found sitting in a back yard for 20 years. I am unable to find a upper steering bushing for a 1960. Did that year even have one? Can someone tell me where to find it please!
Thank you in advance.
Lou
Eric&Barb
Eric&Barb is offline
PostPosted: Thu Aug 07, 2025 7:53 pm    Post subject: Re: 58 loose streering Reply with quote
Louie Lozano wrote:
Hello,
Lou
This thread is a must for any 1960-61 beetle owner:
In Stereo, Where Available!
