steering gears
b4smog
b4smog is offline
PostPosted: Wed May 21, 2025 6:36 pm    Post subject: steering gears Reply with quote
What do you all think of EuroMax or IAP steering gears. My 71 bug is all over the road , all new components except the gear.
baldessariclan
baldessariclan is offline
PostPosted: Thu May 22, 2025 5:25 am    Post subject: Re: steering gears Reply with quote
If you’re referring to the steering box, have you tried adjusting yours, prior to replacing it? Also things like running the correct front tire pressure and good alignment are super important for steady tracking and steering in these cars.
The aftermarket steering boxes from sources like TRW, IAP, Euromax, etc. all tend to have an extremely poor reputation for quality — lots of posts on this forum and others from folks complaining about them. Would recommend you check on the supplier’s return policy (and/or your comfort level w/ losing money on a gamble), before “rolling the dice” on one of those.
About your only option for an acceptable or good quality new steering box nowadays are from sources like VWNOS and Airkewld — not particularly inexpensive, but they both warranty and stand behind what they sell, to best of my knowledge.
b4smog
b4smog is offline
PostPosted: Thu May 22, 2025 2:09 pm    Post subject: Re: steering gears Reply with quote
Thanks for the info, that's what I needed to know. I appreciate the honest response.
Schepp
Schepp is offline
PostPosted: Fri May 23, 2025 6:59 am    Post subject: Re: steering gears Reply with quote
Have you had a professional 4 wheel alignment done after all new components?
If not I'd do that first.
Max Welton
Max Welton is offline
PostPosted: Fri May 23, 2025 8:20 am    Post subject: Re: steering gears Reply with quote
I'm very happy with my vwnos box.
https://www.vwnos.com/113-415-061-c
Max
1967 Type-3 Fastback
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Sat May 24, 2025 3:40 pm    Post subject: Re: steering gears Reply with quote
Have you tried adjusting your box? There is a nut and screw at the top. As long as you can see some thread on that screw you should be able to adjust it.
