Cheryl’s first bus
Page: Previous  1, 2, 3, 4
Jacks
Jacks is offline
PostPosted: Thu Mar 06, 2025 12:47 pm    Post subject: Re: Cheryl’s first bus Reply with quote
Probably from water settling in the lowest spots Sad
Jack Staggs
Actual name
Mykez
Mykez is offline
PostPosted: Sat Mar 15, 2025 2:51 pm    Post subject: Re: Cheryl’s first bus Reply with quote
It done much really. Started stripping the interior to paint the floor and lay down some sound deadening.
Mykez
Mykez is offline
PostPosted: Sun Mar 16, 2025 10:45 am    Post subject: Re: Cheryl’s first bus Reply with quote
Got new wheels on. Need smaller tyres though. What tyre size is everyone running on a lowered bay?
NJ John
NJ John is offline
PostPosted: Sun Mar 16, 2025 11:56 am    Post subject: Re: Cheryl’s first bus Reply with quote
Are they 14 or 15” rims?
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
Mykez
Mykez is offline
PostPosted: Sun Mar 16, 2025 12:33 pm    Post subject: Re: Cheryl’s first bus Reply with quote
Hi. They are 15’s
Buggeee
Buggeee is offline
PostPosted: Mon Mar 17, 2025 7:08 am    Post subject: Re: Cheryl’s first bus Reply with quote
That's a sweet trophy! Congratulations
Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out)
Mykez
Mykez is offline
PostPosted: Sun Mar 23, 2025 2:56 pm    Post subject: Re: Cheryl’s first bus Reply with quote
So the floor paint prep, actually went a few steps further than I wanted to. Found a few holes I had to plug up with weld. Then got carried away, stripped absolutely everything out to find myself needing to do a few minor repairs but nothing crazy. Spent a lot of time removing glue.
Some of the interior panels have been painted white with some kind of gloss that looks like it’s been brushed on. I’ve tried cellulose thinners, white sprit. But nothing is budging it
Mykez
Mykez is offline
PostPosted: Mon Apr 07, 2025 1:06 am    Post subject: Re: Cheryl’s first bus Reply with quote
Still removing this white gloss off the interior, having to use nitromors so that will all need repainted. Such a time consuming process. Only wanted to paint the floor lol
Jacks
Jacks is offline
PostPosted: Wed Apr 09, 2025 12:51 am    Post subject: Re: Cheryl’s first bus Reply with quote
Whoa, you’ve really got that stripped out now Shocked
I think the wheels look great!
Jack Staggs
Actual name
Mykez
Mykez is offline
PostPosted: Tue Apr 22, 2025 3:28 pm    Post subject: Re: Cheryl’s first bus Reply with quote
Well this job took longer than expected lol
Mykez
Mykez is offline
PostPosted: Mon Apr 28, 2025 11:37 am    Post subject: Re: Cheryl’s first bus Reply with quote
Not much to update on. Removed all masking tape and paper, had a clean up
oh, fitted a gene berg shifter which I have been wanting for so long
Mykez
Mykez is offline
PostPosted: Mon May 05, 2025 1:19 pm    Post subject: Re: Cheryl’s first bus Reply with quote
First part of the floor is down. Bought an overhead locker from Stanford hall. Don’t seem to be making any fast progress as of late
Jacks
Jacks is offline
PostPosted: Mon May 05, 2025 11:59 pm    Post subject: Re: Cheryl’s first bus Reply with quote
Nice looking cabinet
Jack Staggs
Actual name
Mykez
Mykez is offline
PostPosted: Wed May 07, 2025 7:53 am    Post subject: Re: Cheryl’s first bus Reply with quote
Not bad for £40 so happy with it
Mykez
Mykez is offline
PostPosted: Wed May 07, 2025 12:54 pm    Post subject: Re: Cheryl’s first bus Reply with quote
Did a bit of sound deadening this evening
Buggeee
Buggeee is offline
PostPosted: Wed May 14, 2025 11:04 am    Post subject: Re: Cheryl’s first bus Reply with quote
It's all looking really good. You do good work!
Mykez
Mykez is offline
PostPosted: Sat May 24, 2025 3:27 pm    Post subject: Re: Cheryl’s first bus Reply with quote
Thank you so much
Mykez
Mykez is offline
PostPosted: Sat May 24, 2025 3:28 pm    Post subject: Re: Cheryl’s first bus Reply with quote
Started to put the laminate together to get it cut to size then it started raining
Mykez
Mykez is offline
PostPosted: Sun May 25, 2025 10:58 am    Post subject: Re: Cheryl’s first bus Reply with quote
Finally finished the laminate flooring
Mykez
Mykez is offline
PostPosted: Sun Jun 01, 2025 12:42 pm    Post subject: Re: Cheryl’s first bus Reply with quote
Got the bed back in, threshold cover in place
Can anyone tell me if the brackets on my bed are installed properly? Or should they be pointing down like the second photo?
Page 4 of 4
