ddutch Samba Member
Posted: Sun Apr 13, 2025 3:03 pm Post subject: Re: Nova Scotian 54 standard restoration |
Sublime A-pillar surgery, the disassembled patient should be happy. |
Burlyhammer Samba Member
Joined: March 07, 2002 Posts: 1702 Location: Great north woods Maine
Posted: Thu Apr 17, 2025 2:18 am Post subject: Re: Nova Scotian 54 standard restoration |
Awesome work Stan!!! |
sgellis Samba Member
Joined: July 06, 2016 Posts: 2161 Location: SW Nova Scotia, Canada
Posted: Thu Apr 24, 2025 6:38 pm Post subject: Re: Nova Scotian 54 standard restoration |
Still have a few details to finish on the A pillar but started a new piece anyway.
Kick panel had quite a bit of rust on the left side and needed that side of the lower rib replaced. 3D printed some bead roller dies to get the perfect shape.
I put a lip on each side of my replacement part and stretched the lips to get the correct curve. After rolling in the rib I needed to add a little more curve. Part came out better than expected on first try.
Now I will print dies to press the termination.
_________________ My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings) |
myklsmyth Samba Member
Posted: Tue May 06, 2025 11:00 am Post subject: Re: Nova Scotian 54 standard restoration |
I have a pretty messed up support that has 3 holes, all which appear to be symmetrical, however they are in a slightly different placement than yours so I don't think that will help and I can't confirm whether it is original or not either. I would like it if someone could confirm as well.
I put tape behind the holes to highlight them in this photo
Posted: Wed May 07, 2025 2:39 pm Post subject: Re: Nova Scotian 54 standard restoration |
Thank you sir |
Posted: Sun May 11, 2025 2:30 pm Post subject: Re: Nova Scotian 54 standard restoration |
Dash beam roughed out.
Biggest problem was the center patch. With a bunch of hand forming, stretching and wheeling I got the front curve. After I added the lower lip. If I had made it in two parts it would have been much easier. It took me almost 3 hours to make and fit that patch.
Was a bit of work to keep it perfectly straight when welding all the patches in. Very happy with how it is coming along.
One unknown is how far up the windshield it extends on the a pillars. With the rough welds and rust I can't see exactly where the panel ends. One side looks like it extends up about 10mm but the other looks closer to 25mm. My 64 looks to be about 20mm but I changed the dash it it so not original.
Käfer2 Samba Member
Joined: December 30, 2019 Posts: 63 Location: Germany
Posted: Sat May 17, 2025 10:13 am Post subject: Re: Nova Scotian 54 standard restoration |
Looks good! I'm following your thread with admiration. |
brass gears Samba Member
Joined: October 21, 2013 Posts: 99 Location: Calgary,AB
Posted: Tue May 20, 2025 7:31 pm Post subject: Re: Nova Scotian 54 standard restoration |
Stan, just wanted to chime in and say your Ship of Theseus is coming along nicely. Mad metal work skills. All this takes so much time never mind producing and editing videos and then there is the CAD files!
Enjoying the videos. Nice presentation followed by the time lapse of the procedures. Saturday afternoon you tube staple.
-Rob _________________ ‘70 transporter
‘ 64 beetle |
LAGrunthaner  Samba Member
Joined: March 18, 2007 Posts: 5575 Location: 1st Coast
Posted: Wed May 21, 2025 3:20 am Post subject: Re: Nova Scotian 54 standard restoration |
Wow, Stan was lead used on the finish work on busses regularly or just for repairs? I've had friends replicate lead use on restorations as an old school method. _________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Wed May 21, 2025 4:50 am Post subject: Re: Nova Scotian 54 standard restoration |
LAGrunthaner wrote: |
Wow, Stan was lead used on the finish work on busses regularly or just for repairs? I've had friends replicate lead use on restorations as an old school method. |
Lead was used where the B pillars meet the front door headers. It was very ruff so believe it was used to seal the seam and not as much for looks. Once the paint was removed I could see the texture where a rag was used to wipe the lead smooth while hot.
I assume the center post lead was just to seal the seam but could also be for strength. The lead only flowed down between the panels on one side so if for strength they didn't do a very good job. There are a few more seams I suspect lead is used in but haven't investigated them yet.
Before paint I will re-lead the B pillar and any other seams that were originality leaded. I had some old lead bars around but believe they went to recycling years ago.
I don't remember any mention of lead on these. At the time it was a very common practice to lead seams as a form of seam sealer as well as for creating a smooth finish. _________________ My 64 Kombi restoration
scarabee Samba Member
Joined: May 14, 2021 Posts: 130 Location: South Africa
Posted: Thu May 22, 2025 6:30 am Post subject: Re: Nova Scotian 54 standard restoration |
Stan, you ARE the man! Cheesy, I know... |
ddutch Samba Member
Posted: Sat May 24, 2025 4:26 pm Post subject: Re: Nova Scotian 54 standard restoration |
sgellis wrote: |
Windshield frame repair parts made. Not going to be much original frame left. Lot of deep rust on the back side. |
nice to see you're able to re-use most of the vertical parts of the original windshield frame, so there is factory metal in this section of the bus too. The lower horizontal parts of the frame are rusted out on most busses, so repairs or replacement are required in many cases. |
