When to rebuild transmission?
extremebuggy
extremebuggy is offline
PostPosted: Sat May 24, 2025 4:35 pm    Post subject: When to rebuild transmission? Reply with quote
Got a swing axle transmission in a buggy that has been sitting for several years (about 20 years). Worked fine last time it was ran 20 years ago. Should the extended time sitting automatically warrant for a rebuild, or maybe just refresh fluid, fix any leaks and run it? What would you guys do in this case?
oprn
oprn is offline
PostPosted: Sat May 24, 2025 4:37 pm    Post subject: Re: When to rebuild transmission? Reply with quote
Don't fix what ain't broke is my policy.
extremebuggy
PostPosted: Sat May 24, 2025 4:42 pm    Post subject: Re: When to rebuild transmission? Reply with quote
That was kinda my thoughts too. Thanks for the input.
Cusser
Cusser is offline
PostPosted: Sat May 24, 2025 4:51 pm    Post subject: Re: When to rebuild transmission? Reply with quote
Mine too. Monk's too.
jpaull
jpaull is offline
PostPosted: Sat May 24, 2025 10:32 pm    Post subject: Re: When to rebuild transmission? Reply with quote
Is the engine out?
I have started up and tried to run many vw's after sitting for 20+ years. I personally love it. But, From my experience, If you try to run it, the input shaft seal will start to seep gear oil, and the engines main seal will start to leak. Soon, the clutch is saturated and you need to do a clutch cause its slipping.
So the big question, is the clutch good now? if it is, doing a rear main and input shaft seal will save you time and a clutch.
[email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth.
extremebuggy
PostPosted: Sun May 25, 2025 11:26 am    Post subject: Re: When to rebuild transmission? Reply with quote
jpaull wrote:
Is the engine out?
Engine had a top end overhaul, so new rear main seal installed and clutch and pressure in good condition.
bedlamite
bedlamite is offline
PostPosted: Sun May 25, 2025 1:24 pm    Post subject: Re: When to rebuild transmission? Reply with quote
If it ain't broke, fix it 'til it is!
Max Welton
Max Welton is offline
PostPosted: Sun May 25, 2025 1:29 pm    Post subject: Re: When to rebuild transmission? Reply with quote
The time may be ... before the last good guy rebuilding transmissions retires. Wink
Max
1967 Type-3 Fastback
jpaull
jpaull is offline
PostPosted: Sun May 25, 2025 2:23 pm    Post subject: Re: When to rebuild transmission? Reply with quote
extremebuggy wrote:
jpaull wrote:
Is the engine out?
So if the transmission input shaft seal has not been changed, your new clutch might be getting soaked in gear oil after you start driving it again.
esde
esde is offline
PostPosted: Sun May 25, 2025 4:00 pm    Post subject: Re: When to rebuild transmission? Reply with quote
I always found it's 50-50 on wether the seals leak of not, so I don't bother till they do..
First good drive, get the trans oil warmed up and then dump it while it's hot. watch for glitter and shrapnel, and then refill. You'll have an idea of what's ahead based on the condition of the oil and what's floating in it.
modok wrote:
b-man
b-man is offline
PostPosted: Mon May 26, 2025 4:05 pm    Post subject: Re: When to rebuild transmission? Reply with quote
I had a swing axle bus transaxle sitting around for about 30 years, most of the time in dry storage. I took it out of my ‘66 single cab pickup in 1988 while doing a conversion to IRS and finally got around to using it again in 2018. Other than a little gear oil seepage and some bad axle boots it had been working fine.
I ended up installing it in my ‘56 panel using a Fast Fab adapter nosecone from Rancho, new axle boots and a new input shaft seal. Other than that I didn’t really do anything to it, just snugged down all the nuts and put in some high quality SWEPCO 201 80W-90 gear lube. Been working perfectly since I began driving it in June 2019.
If it ain’t broke don’t fix it.
1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle
Dusty1
Dusty1 is offline
PostPosted: Tue May 27, 2025 5:24 am    Post subject: Re: When to rebuild transmission? Reply with quote
When to rebuild your transaxle:
Rebuild your transaxle when someone pays you to rebuild your transaxle. The way that usually works is they pay you to rebuild their transaxle.
For heavy duty offroad use, build a "new" one off season. Toss your old one in your hauler as a back- up.
Otherwise, if it ain't broke, don't fix it. Hey! Is there an echo in here?
Your transmission will let you know when it's tired. It will start popping out of gear. Reverse or the lower gears get tired sooner.
I got over 500k miles on my stock '67 transmission. The stock transmission, generator and starter nave gave me problems. My '67 transmission is waiting for my next '67 project. It's thoroughly tested by now,
Schepp
Schepp is offline
PostPosted: Tue May 27, 2025 7:37 am    Post subject: Re: When to rebuild transmission? Reply with quote
I'd put a new throw-out bearing, starter bushing, fresh seals, change the gear oil and run it. You'll know pretty quick if its good or not.
nsracing
nsracing is offline
PostPosted: Wed May 28, 2025 6:10 am    Post subject: Re: When to rebuild transmission? Reply with quote
About the only time I will say it ain't broke is when I went thru it myself. Laughing
All other parts to me when I bring them home are cores. That is about it.
I will just go thru it and know you are good to go.
Schepp
Schepp is offline
PostPosted: Wed May 28, 2025 7:17 am    Post subject: Re: When to rebuild transmission? Reply with quote
Ns,
I think 99% of people including myself feel that how a transaxle works and goes together is magic. They also don't have the tools to put one back together or have the knowhow to do so.
Its odd that so many of us will build the engine but not the trans.
nsracing
nsracing is offline
PostPosted: Thu May 29, 2025 2:09 am    Post subject: Re: When to rebuild transmission? Reply with quote
The VW trans is the unsung hero. People will dump loads of cash on a motor that lasts 2 days and not a dime on a trans.
The car ain't gonna go far w/o its working trans. And the last thing anyone wants is stuck far away from home.
