T1GreyBug Samba Member
Joined: February 19, 2025 Posts: 10 Location: United Kingdom
Posted: Tue May 27, 2025 10:41 am Post subject: Distributor Parts Guidance Please |
Hi from the UK
Please see attached pictures (hopefully)
I am currently recommissioning a August 1968 manufactured 1300 Beetle
I’ve learnt very quickly that getting truly correct replacement parts is a steep learning curve over here but I’m getting there.
The car is completely standard and I am trying to keep it that way as much as possible and I’m after some guidance for the correct replacement part numbers concerning the distributor please. I am after current Bosch part numbers for the parts if possible so I can source spares now I have the car running.
May I thank the collective in advance for their time and help in this matter.
glutamodo  The Android
Joined: July 13, 2004 Posts: 26530 Location: Douglas, WY
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79494 Location: Sneaking up behind you
Posted: Tue May 27, 2025 11:22 am Post subject: Re: Distributor Parts Guidance Please |
You have a 205T, that is most likely not the original distributor. The 205T was originally on a 1970 1600 SP engine.
The correct distributor would be a
VW 113-905-205K (VW part number)
Bosch 0231 137 009 (Bosch part number)
For a 205K the correct part numbers are:
Condensor: 02 007
Rotor: 04 006
Cap: 03 001
For a 205T the correct part numbers are:
Condensor: 02 007
Rotor: 04 033
Cap: 03 010 _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Mben Samba Member
Posted: Tue May 27, 2025 11:49 am Post subject: Re: Distributor Parts Guidance Please |
August 1968 manufacture would be 1969 model year so the 205T might be original.(at least according to the Bosch tune up chart) |
Glenn  Mr. 010
Posted: Tue May 27, 2025 11:58 am Post subject: Re: Distributor Parts Guidance Please |
Mben wrote: |
Sure... why not.
After all I have a 74 Beetle with a factory 75 dash pad. _________________ Glenn
Member #1009
#BlueSquare
viiking Samba Member
Joined: May 10, 2013 Posts: 3155 Location: Sydney Australia
Posted: Tue May 27, 2025 4:04 pm Post subject: Re: Distributor Parts Guidance Please |
T1GreyBug wrote: |
Hi from the UK
I assume you already know of these guys in the UK? A lot of us down in Oz buy from them as well as the established US suppliers.
https://www.heritagepartscentre.com/uk/ _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Tue May 27, 2025 5:16 pm Post subject: Re: Distributor Parts Guidance Please |
Hah, well, that was interesting.
I just got off night shift and had been awake for 22 hours when I got home and saw this post and put in that quick reply about the Tune Up Parts Chart.
I saw the 205T and I know that's 69-70 Bug. Now that I've had a bit of a nap and looked at this thread again, I notice that I forgot to look at the first three digits. It's 111 905 205 T.
All of my Bosch Parts books are USA publications, they do have some international data, especially the older books, but only some, and it does not talk about the 111-T except to cross reference the distributor part number.
I'm actually surprised I overlooked it when I compiled that chart though, but I compiled that several years ago. I need to go and edit it now.
Anyway, the 111-T was concurrent with the 113-T. Introduced August 1968. As talked about above, it uses the modern 03010 (orig 0231522183) cap, the modern 04033 (orig 04012) rotor, the 01013 points and 02069 (orig 02007) condenser.
The big difference between the two is the vacuum advance, it uses the older 07017 vacuum canister instead of the 07024. Which means less advance and 7.5BTDC base timing instead of 0TDC. _________________ Andy T.
"What is Glutamodo, Horror of Toyko, besides total, fiendish, quality-a-you brain!" |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7500 Location: Houston, Texas
Posted: Tue May 27, 2025 5:54 pm Post subject: Re: Distributor Parts Guidance Please |
That's a really nice car. You even have the dark brown cap which is good. _________________ www.vwnos.com [email protected]
wcfvw69 Samba Purist
Posted: Tue May 27, 2025 6:25 pm Post subject: Re: Distributor Parts Guidance Please |
Wow, that is a very original, bone stock engine right there. Very nice.
I'm always amazed at the corrosion VW parts get from the climate in England. I'm just curious, did this bug live near the ocean? I've restored hundreds of those 205T SVA distributors from all over the USA and it's rare that I ever see corrosion like that internally on a distributor that's always been installed on an engine. Of course I do see corrosion on distributors that were pulled out years ago and got wet while in storage. That spring has some serious corrosion on it.
_________________ Contact me at [email protected]
The Samba member since 2004.
Glenn  Mr. 010
Posted: Tue May 27, 2025 6:40 pm Post subject: Re: Distributor Parts Guidance Please |
You call that corrosion?
Member #1009
#BlueSquare
Joined: April 27, 2002 Posts: 6750 Location: Pentwater, Michigan
Posted: Tue May 27, 2025 7:10 pm Post subject: Re: Distributor Parts Guidance Please |
And yet another example of why it’s important to pay attention to the first three digits in the distributors VW part number. The 205 can be completely ignored since all distributors- every single one are 205’s. Ignoring this fact puts you at risk of giving inaccurate or wrong information. The 111 905 205 T and the 113 905 205 T are not the same distributor as Glutamodo points out. The 111 T was used in non USA engines. They are timed differently. The OP is in Great Britain. _________________ Roads Scholar
Member# 2059 |
Posted: Wed May 28, 2025 9:33 am Post subject: Re: Distributor Parts Guidance Please |
Thank you for this I will have a look at it, much appreciated |
Posted: Wed May 28, 2025 9:35 am Post subject: Re: Distributor Parts Guidance Please |
Glenn wrote: |
Condensor: 02 007
Rotor: 04 006
Cap: 03 001
Condensor: 02 007
Rotor: 04 033
Cap: 03 010 |
Thank you for this information, I also noted your comment later about production and years, for reference the car was first registered in March 69 in the UK |
Posted: Wed May 28, 2025 9:37 am Post subject: Re: Distributor Parts Guidance Please |
Mben wrote: |
This is what I believe with this car and I believe it to have had a very sheltered life with it being standard when I acquired it,many thanks |
Posted: Wed May 28, 2025 9:43 am Post subject: Re: Distributor Parts Guidance Please |
viiking wrote: |
T1GreyBug wrote: |
Hi from the UK
https://www.heritagepartscentre.com/uk/ |
Thanks, I am aware and have used them and others in the recommission to get the car running again, but I have had to go to specialist suppliers with genuine good quality second hand parts to achieve the correct running or operation. As an example I got 2 fuel pump Bakelite spacers that were supposed to be exact replacements from 2 suppliers,they were awful,undersized in thickness an tapered resulting in a homemade gasket 1mm thick until I sourced a original part which was correct thicknesses and parallel, worked a treat.
Hence why I’d like the correct info regarding the distributor and it’s items. |
Posted: Wed May 28, 2025 9:47 am Post subject: Re: Distributor Parts Guidance Please |
glutamodo wrote: |
The big difference between the two is the vacuum advance, it uses the older 07017 vacuum canister instead of the 07024. Which means less advance and 7.5BTDC base timing instead of 0TDC. |
I have rebuilt the fuel pump, carburettor, cleaned the tank ,replaced fuel lines, set points with feeler gauge,cleaned the plugs and oil bath and static timed it to 7.5 as per the sticker on the tin and she runs a treat ,many thanks for your information and anything else you would recommend I will gladly take onboard |
Posted: Wed May 28, 2025 9:50 am Post subject: Re: Distributor Parts Guidance Please |
heimlich wrote: |
That's a really nice car. You even have the dark brown cap which is good. |
We are so pleased with it especially as we can’t find any modifications to it other than some consumables and the cherry on the cake is it’s the same colour as my late father's when I was a child in 1971
Posted: Wed May 28, 2025 9:57 am Post subject: Re: Distributor Parts Guidance Please |
wcfvw69 wrote: |
I believe it’s not lived by the ocean, but we do have 4 proper seasons, I believe it has been sat for a while in a clean garage unused properly for 20 plus years with only a drive up and down a short road occasionally
Regarding the spring are these obtainable? Is it worth me investing in a complete back up of the whole distributor system ?
Many thanks for your knowledge and time it’s much appreciated |
Posted: Wed May 28, 2025 9:59 am Post subject: Re: Distributor Parts Guidance Please |
tasb wrote: |
And yet another example of why it’s important to pay attention to the first three digits in the distributors VW part number. The 205 can be completely ignored since all distributors- every single one are 205’s. Ignoring this fact puts you at risk of giving inaccurate or wrong information. The 111 905 205 T and the 113 905 205 T are not the same distributor as Glutamodo points out. The 111 T was used in non USA engines. They are timed differently. The OP is in Great Britain. |
Many thanks for your help it is much appreciated and the reason why you and the rest of the collective on the forum are a great help to owners around the world |
Posted: Wed May 28, 2025 12:24 pm Post subject: Re: Distributor Parts Guidance Please |
T1GreyBug wrote: |
wcfvw69 wrote: |
If you have distributor restorers over in England, they can restore that original to the VW distributor. When I restore those distributors, the springs are one of the parts that are stripped and re-zinc plated for corrosion resistance. If that distributor has never been restored, it would benefit from being disassembled, cleaned and then relubricated. Often times, the points pivot plate doesn't pivot easily due to lack of grease, dirt and corrosion. This puts extra stress on the vacuum canister that has to pivot it to advance the timing.
If you can't find anyone over there to restore it, I do restore parts sent from Europe too. I also do have spare springs for that distributor as well. _________________ Contact me at [email protected]
