RBEmerson Samba Member
Joined: November 05, 2011 Posts: 2221 Location: SE PA
Posted: Thu May 29, 2025 7:43 am Post subject: It's about the heater - '90 Westy |
Long story short, the darn heater won't shut up. I've replaced the OEM valve with a new valve, and tried the Intrepid Overland valve. In the end, there's still too much hot air coming out of the vents.
The obvious question is "what about the shutters?" Short answer: pulling the dash is out of my skill set. The guys I take the Westy to have have pulled the dash in the past, and they say they're afraid that messing with the shutters is going to break more things than it'll fix. I believe them (Scott & Co. are pretty fearless on older cars - if they're worried, I listen).
So, Plan B is to add a shutoff valve, a winter/summer valve, accessible without dropping the spare, but maybe behind the glovebox, or some place that gives a a cable routing with the least friction. Rather than reinvent the wheel, has anybody done something similar?
Plan B, sub-part 1 is to use a solenoid valve of some sort - no cable throw to speak of, closes only when power's applied. Again, has anybody done that? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10295 Location: Mt Lemmon, AZ
Posted: Thu May 29, 2025 7:54 am Post subject: Re: It's about the heater - '90 Westy |
I added a flush tee to the heater hose as shown. Seems like this might be an easy to reach location for a shutoff valve.
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17292 Location: Brookeville, MD
Posted: Thu May 29, 2025 8:25 am Post subject: Re: It's about the heater - '90 Westy |
| Ahwahnee wrote: |
[img] |
Uh, definitely thinking outside of the box. ;D
Seriously, this does suggest something more plausible. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Thu May 29, 2025 8:27 am Post subject: Re: It's about the heater - '90 Westy |
| dobryan wrote: |
I added a Ford heater valve inside, behind the big center panel, and used the stock heater cable to activate it. I left the original valve in place fully open.
[img] |
Sigh... my rusty brain is slowly waking up to the notion there was a similar discussion about Ford valves. Do you recall either the part number or something else that would appease the NAPA folks? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
jimf909 Samba Member
Posted: Thu May 29, 2025 8:47 am Post subject: Re: It's about the heater - '90 Westy |
| RBEmerson wrote: |
Was the Intrepid Overland valve installed so it closed completely? I can't imagine that valve not terminating all coolant flow through the heater core.
As for the Ford and other valves, there's lots of information in these threads, incl. the Ford part# (in the thread titled: Vanagon - View topic - Ford front heater valve.
https://www.google.com/search?client=safari&rl...p;oe=UTF-8 _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
Posted: Thu May 29, 2025 9:13 am Post subject: Re: It's about the heater - '90 Westy |
@jim909 Thanks for the link!
@dobryan Number duly noted - thanks!
Ford front heater valve is definitely the answer to my OP. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2231 Location: Bulli Klinik, Colorado Springs
Posted: Thu May 29, 2025 9:48 am Post subject: Re: It's about the heater - '90 Westy |
I just installed the Intrepid valve. I believe that it's supposed to fully close. It might be in the adjustment of the cable. I'd start with that. _________________ PM me about quality metal-work on your vehicle.
Mike K
Bulli Klinik
Colorado Springs |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4615 Location: East Kootenay, British Columbia
Posted: Thu May 29, 2025 11:09 am Post subject: Re: It's about the heater - '90 Westy |
I have the Intrepid heater hose shutoff valve, it closes completely. The valve is pretty stiff and you need to work it slowly so as to not kink the cable.
You may want to think about adding the Intrepid air flap also, it cuts all airflow through the heater box, shutting down hot summer air (and dust, fumes etc.)
https://intrepidoverland.com/shop/cabin-air-control/
No need to pull the dash to install. _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5902 Location: Bemidji, MN
Posted: Thu May 29, 2025 12:12 pm Post subject: Re: It's about the heater - '90 Westy |
i can't speak to the Intrepid valve but the OE valve has a slight channel in the ball that bleeds thru a small amount of coolant. i suspect this is intended to keep fresh, non-depleted coolant in the heater core. the cure is to increase the non-heated airflow thru the core and ducting so have the levers wide open. that will quickly remove any heat soak from the core and firewall and it will be ambient outside air temp coming out of the ducts.
if you close the bottom, blue lever, it will close off the ducts leading to the door channel and to the vent openings above the slider. this can result in more air flow thru the front ducts at the expense of noise. the ram air effect from the intake scoop is strong, you won't need to run the fan unless crawling at city speeds.
there are 'hot footwell kits' available to insulate the floor from this radiator heat. they work but you can improve the source of the heat by increasing air flow thru the radiator by making sure:
- side card board is in place
- radiator and condenser fins are clean but most importantly, the space BETWEEN the condenser and radiator is clean. this can get a huge accumulation of debris and greatly slow down air flow thru the radiator. this slowed air flow contributes to the hot firewall.
- removal of the ac condenser, akin to a holy sin by some, greatly increases airflow thru the radiator itself, providing greater engine cooling AND a cooler firewall. _________________ -dan
www.thefixitworkshop.com |
zululep Samba Member
Joined: August 13, 2016 Posts: 55 Location: Portland, ME
Posted: Thu May 29, 2025 6:34 pm Post subject: Re: It's about the heater - '90 Westy |
My heater valve stopped functioning a few years ago, and the heat was always on. Cable worked fine but something internal was kaput. After reading here how bad the new aftermarket valves were, and how finicky some of the more robust alternatives could be as far as cable travel, etc., I installed a shut off valve in one of the heater hoses. I had deleted my rear heater a few years prior and had connected the heater hose ends with barbed brass connectors. I just replaced one of those with a high temp, quarter-turn ball valve. I can run it open, closed or anywhere in between. It's very easy to reach through the right rear wheel arch. It's not as convenient as an in-cabin control, but I've found you can somewhat control the amount of hot air coming into the van by adjusting the levers and vents, and it's a 30 second pit stop to adjust the valve if you need to. And no crawling under the van is required. You can see the blue valve handle in the pic taken looking through the wheel well. Probably not for everyone, but it works for us.
_________________ 1984 Westfalia with Bostig Zetec |
Posted: Thu May 29, 2025 9:33 pm Post subject: Re: It's about the heater - '90 Westy |
The Ford heater valves are directional, installing with the flow going the wrong way will cause the valve to leak through. There are two Ford style valves that look almost identical, except that one is the mirror image of the other, with one being for one flow direction and the second for the opposite flow direction.
As for the slit cut into the ball that is common on heater valves, the slit allows for more precise metering when little water flow is required.
If the cables are messed up in the dash the valve can not be shut fully either. This is an easy mod to get better function of the valve. Just shorten the inner wire of the cable so it protrudes no more than necessary from its sheath. This will stiffen the cable lessening the chance it will bend.
This is how the cable was originally. This cable had been kinked and mostly straightened.
I originally did the mod nearly twenty years ago, and have had zero trouble with the cable kinking since.
harvgwen Samba Member
Joined: February 11, 2021 Posts: 308 Location: Okanagan Valley, British Columbia
Posted: Fri May 30, 2025 9:42 pm Post subject: Re: It's about the heater - '90 Westy |
Wild things, I think that’s exactly what my cable needs. My valve moves very freely on its own, but the cable has a hard time pushing it without bending. _________________ 1986 Westfalia Vanagon, 2.2 Subaru
Okanagan Valley, British Columbia |
WillRB Samba Member
Posted: Sat May 31, 2025 5:32 am Post subject: Re: It's about the heater - '90 Westy |
I just put a ball valve and inline with heater hose behind glove box and use it as a seasonal shut off. _________________ 1984 Vanagon Westfalia w/ Subaru Conversion (99 Legacy 2.2 Phase II) 2WD 4speed 4.57 R/P (.828 straight cut 4th) GT TBD |
Posted: Sun Jun 01, 2025 5:15 pm Post subject: Re: It's about the heater - '90 Westy |
| Wildthings wrote: |
| As for the slit cut into the ball that is common on heater valves, the slit allows for more precise metering when little water flow is required.. |
this is entirely correct. those that have put a ball valve in place for heater regulation know how friggin' touchy the control is to modulate the heat. the groove and ball shape allow small coolant flow adjustments in the early stages.
i'm calling my initial statement about the groove allowing a small bleed of coolant thru the core for corrosion protection BS. blowing thru the closed valve with my mouth, there is a SLIGHT passage of air, not by design of the groove which ends before it meets the shell, but by tolerance of the plastic ball. the BTU contribution is negligible considering the slow passage of cooling-as-it-moves fluid thru a 10' hose with just a few milliliters per minute of flow.
pictures...
Posted: Sun Jun 29, 2025 12:30 pm Post subject: Re: It's about the heater - '90 Westy |
The rest of the story: Installed a separate cutoff valve that accepts the heater slider cable, and no more unwanted hot air out of the heater. A little improvising was needed to get the sense of the slider correct (i.e., slide to HOT to open the valve).
End result, only ambient temp air out of the vents. Sorta.
We still get unwanted hot air coming into the cabin. But that's a topic for another thread. Hot air leaks thread _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
