HSThing Samba Member
Joined: January 29, 2010 Posts: 53 Location: New Hampshire
Posted: Tue Jun 03, 2025 4:38 am Post subject: Front Locker - Would you if you could? |
For those who took a peak at Dante in my previous post, this will make more sense. For others, I'm in the process of importing my German spec T4 Syncro California.
And, before I put in on a boat, I'm debating about adding a front locker. VW never offered a front locker, relying instead on the EDL system, including Syncro models. (I do have the factory rear locker.) There is a speciality shop in the Czech Republic that developed a front locker in house and has been installing them on T4s for several years. The system is only available for Syncros due to how the locking system engages. It's a cool bit of engineering.
But would it serve any practical purpose? I'm fully aware the T4/Eurovan isn't an off road beast and I'm on the fence about this modification. Would you do it if you could? All opinions welcome!
EuroTec Samba Member
Joined: August 24, 2020 Posts: 479 Location: Asheville, North Carolina
Posted: Tue Jun 03, 2025 7:28 pm Post subject: Re: Front Locker - Would you if you could? |
I would not. I wouldn't have a need for it in my travels. The beast does pretty well for traction as is. _________________ If it ain't broke, don't fix it! |
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1422 Location: Bethlehem, PA
Posted: Wed Jun 04, 2025 10:29 am Post subject: Re: Front Locker - Would you if you could? |
It all depends on what you are going to do with it. If you are going to be doing some serious rock climbing then you'll need it. If it's for a daily driver, then no need. |
Posted: Wed Jun 04, 2025 12:43 pm Post subject: Re: Front Locker - Would you if you could? |
I don't plan to do any technical wheeling with it. Where I am in Western Massachusetts we get a lot of snow. As is, it's quite capable on the highway under slippery conditions. However, there are some beautiful forest service campgrounds in the Green Mountains that are technically open all year, but the roads in are not plowed or maintained during the winter months. That's where I'm thinking the added capability of a front locker might come in handy.
The Syncro Vanagon folks with a rear locker have a couple advantages I don't have with the T4. Weight in the rear, and more importantly, the rear axle is the primary drive axle. With mine, the rear locker is behind the viscous coupler. Unfortunately, even though I have a lot of experience with the van, it's all been on-highway. I'm not going to be able to test its limits before I have it shipped over to the States, so I'm flying blind and guessing whether it's worth the effort to add the front locker. I need to decide soon or lose the opportunity. |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2931 Location: North Carolina
Posted: Wed Jun 04, 2025 2:54 pm Post subject: Re: Front Locker - Would you if you could? |
If I was shipping a unicorn to my house, I wouldn’t try to make it more unique first. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Wed Jun 04, 2025 3:35 pm Post subject: Re: Front Locker - Would you if you could? |
mikemtnbike wrote: |
If I was shipping a unicorn to my house, I wouldn’t try to make it more unique first. |
Oh, for sure. The entire endeavor is basically nuts. Even crazier is that I actually committed and bought the van On the sensible side, though, I have a mechanic in Spain willing to help source and send parts as I need them, and a mechanic 30 minutes from me (who posts here occasionally) willing to help keep the unicorn alive. If I was rational, I would have purchased a Metris from Peace Vans  |
shirk Samba Member
Posted: Wed Jun 04, 2025 6:41 pm Post subject: Re: Front Locker - Would you if you could? |
A set of tire chains on the fronts and the rear locking should easily get you through any snow you'd consider.
For non snow tech you'll run into ground clearance issues long before the need for a front locker.
I'd think a Haldex conversion to replace the viscous coupler would be more suitable. You then have the ability to fully lock the center or run it with any level you desire. |
Posted: Wed Jun 04, 2025 7:51 pm Post subject: Re: Front Locker - Would you if you could? |
Can you fit tire chains if you're running, say 215/70R16 with a 3/4 inch lift? The syncro is geared like a tank and fitting slightly oversized tires is a cheap way of getting taller gearing. Plus, it looks cool.
I dug into the Haldex swap, and I like the idea in theory. I got a little spooked when it seems to involve reengineering the prop shaft to better handle the torque transfer. Eurotuning, who also does the front-locker, offers the Haldex retrofit and they replace the flexi-discs with CVs. My thought was having the option to lock the front would actually put less stress on the system overall - at least until I turn the steering wheel.
On the plus side, the Haldex swap is potentially something I could do here in the States at some future date - which likely means never... |
germanoldschool Samba Member
Posted: Fri Jun 27, 2025 5:49 am Post subject: Re: Front Locker - Would you if you could? |
Chains will not fit. Don't do the Frontlocker. It is just not worth it. People (here in germany) just dont get how well the EDL works. Your Van is already toptier by having a rear locker. The only thing i would recommend depending on the mileage is rebuilding+upgrading your viscouscoupling by WerkstattKern. Another thing i would highly recommend ist NOT to drive your Syncro on salty roads and to buy a Metris AWD from Peace Vans
I just found the Dantes thread where i will respond separatly  |
