Square back resurrection
Page: Previous  1, 2, 3 ... , 11, 12, 13  Next
sunroof
sunroof is offline
PostPosted: Tue May 27, 2025 9:27 pm    Post subject: Re: Square back resurrection Reply with quote
If you're keeping the car stock height, you'll want to find the 9* one, as it helps control the bump stop motion of the front end (why VW put it in). Here in the states we can order them from Autozone, NAPA, and a couple of other places.
I am guessing there is a 9 degree angle to the threaded part that goes into the tie rod. Correct?
Anyways I can't find a picture or information in the manual that suggests this.
I will order 4 straight ones for now, I just need the car to be mobile.
Don
Better and better mistakes!
notchboy
notchboy is offline
PostPosted: Wed May 28, 2025 5:06 am    Post subject: Re: Square back resurrection Reply with quote
You may need to bend one as I believe the correct bent one is difficult to locate.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
sunroof
sunroof is offline
PostPosted: Wed May 28, 2025 12:45 pm    Post subject: Re: Square back resurrection Reply with quote
Trevor just send this image
Right tie rod end wrong year. This is a late one so doesn't solve my problem.
OTOH
What have we here?
It is very heavy
Heater boxes!
Saweeeet!
Thank you Arctic Volkswagen all the way from the Yukon.
Don
sunroof
sunroof is offline
PostPosted: Thu Jun 05, 2025 7:15 am    Post subject: Re: Square back resurrection Reply with quote
It's question time again counting on You to set me straight.
What are these for, I have four of them
Another bunch of bushings I have no idea where they go
And these?
I'm guessing these are the sway bar bushings
Finally what are these things? I suspect front suspension but don't know how
https://www.youtube.com/watch?v=P5Dhkz7471E
Don
Zwitterkafer
Zwitterkafer is offline
PostPosted: Thu Jun 05, 2025 12:13 pm    Post subject: Re: Square back resurrection Reply with quote
1st pic: Spring plate bushings, they are L & R handed, so be careful to fit them in the right places.
2nd pic: Look like subframe to body bushings
3rd pic: Look like front axle mounting bushings
4th pic: I dunno
5th pic: Stop brackets that bolt to sides of front axle.
- Zeuxius, 400 BC
Bobnotch
Bobnotch is offline
PostPosted: Thu Jun 05, 2025 12:48 pm    Post subject: Re: Square back resurrection Reply with quote
4th pic: I dunno
I think those are for either the upper or lower trailing arms, and are for wear (they fill the gap, which is why they're covered in grease).
The others are correct. You should also have 2 flat rubber pieces about an 1/8th inch thick (about 2 by 3 rectangular) for the rear sub to the floor pan mounts.They go between the two parts with short 10mm bolts. Of course at this point in time they might be stuck to either the rear sub, or the pan.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
sunroof
sunroof is offline
PostPosted: Thu Jun 05, 2025 4:19 pm    Post subject: Re: Square back resurrection Reply with quote
I'm pretty sure they are for the sway bar trailing arms.
Any pictures of how these bolt up?
Don
sunroof
sunroof is offline
PostPosted: Fri Jun 06, 2025 4:17 am    Post subject: Re: Square back resurrection Reply with quote
CIP1.ca was good to their word and acknowledged their mistake and gave me a credit to get the correct tie rod ends.
Bought a couple of taps, M14 x 1.5 right and left hand thread
I media blasted the rods, POR15'd them and tapped the ends and assembled it all
On to these things. I don't know if they are worth cleaning up. Can't imagine where I would get new ones if they are too thin to use
OAN I was hunting through the parts pile hoping for a 6 volt coil for my beetle and found these:
A set of new grub screws, waddya know!
Don
Bobnotch
Bobnotch is offline
PostPosted: Fri Jun 06, 2025 1:14 pm    Post subject: Re: Square back resurrection Reply with quote
Don
Those go on the lower bolt hole of the opposite lower torsion bar (sandwiched between the bolt head and the beam), with the long ear over the trailing arm lip. If you do a search, you can see how they go, and how they work. They're a keeper to keep the trailing arm from coming out/off. I don't have any pics of them, but the Bentley manual does in the front end section.
Tram wrote:
Tram wrote:
sunroof
sunroof is offline
PostPosted: Fri Jun 06, 2025 4:20 pm    Post subject: Re: Square back resurrection Reply with quote
OK so...
OOOO not good
Nope not good at all
Would this rotor work on my early 1966 type 3?
https://www.cip1.ca/vwc-311-405-583-a/
Don
sunroof
sunroof is offline
PostPosted: Sat Jun 07, 2025 5:59 am    Post subject: Re: Square back resurrection Reply with quote
Anyways....The front end is as assembled as it is going to get
On to the rear assembly
This should be interesting.
Don
Bobnotch
Bobnotch is offline
PostPosted: Sat Jun 07, 2025 1:13 pm    Post subject: Re: Square back resurrection Reply with quote
sunroof wrote:
OK so...
Don
Yes, those will work. Just use your old bearings and races, so they'll fit your spindles. Remember I mentioned the mid year change in the rear bearing for 68. The rotors are the same from 66 thru mid 71, so you'll be good with them.
Tram wrote:
Tram wrote:
sunroof
sunroof is offline
PostPosted: Sat Jun 07, 2025 2:30 pm    Post subject: Re: Square back resurrection Reply with quote
Excellent, thank you. This mid year stuff is turning into a real pain.
Don
sunroof
sunroof is offline
PostPosted: Sat Jun 07, 2025 5:09 pm    Post subject: Re: Square back resurrection Reply with quote
OK
Done
Getting closer
Of course I can't find the hub caps now.
Don
Bobnotch
Bobnotch is offline
PostPosted: Sun Jun 08, 2025 9:23 am    Post subject: Re: Square back resurrection Reply with quote
The mid year stuff is only a pain if you're not aware of it. Most of the time it's not really a problem, as most people own a car a year or two above or below the change. In your case, the rotors are the same for 4 years, and directly interchange with a Ghia.
Tram wrote:
Tram wrote:
sunroof
sunroof is offline
PostPosted: Sun Jun 08, 2025 6:27 pm    Post subject: Re: Square back resurrection Reply with quote
Started in on the rear assembly today. There was a bag of hardware that came with all the body/suspension mount stuff.
The center mount was super easy to figure out, a couple of rubber bushings and a mounting plate.
Somehow I forgot to take a picture of it all painted nicely.
The other two mounts were a little more challenging, this was all I had to go on:
This kinda looked like it all went together
There was only one bolt like it but I have been taking beetles apart for 46 years and have never discarded a single fastener so a matching bolt was easy to find.
Even a Kamax!
The full set
There that kinda looks like in the book
Tapping nuts and threaded holes and running dies over bolts was the most time consuming part of the whole afternoon
Including the lug bolt holes
These guys are going to take the better part of an hour to make shine again.Including all new split washers. Speaking of which I need to go to the bolt store and buy a bag of 10 mm split washers.
Now I just have to go through the parts stash and find the pair of tranny mounts I know I saw somewhere...
Don
sunroof
sunroof is offline
PostPosted: Sun Jun 08, 2025 10:58 pm    Post subject: Re: Square back resurrection Reply with quote
There you are, I knew I saw you somewhere
That was a days work
Something I found out today which is making me a little unhappy is that both rear drums are stuck solid. Not a hint of movement. I think the big bar might persuade them a little.
Now I just need to find 3 guys to help drop the body on the pan so I can move it around the shop and make room for the beetle which is going to need an engine swap.
Don
sunroof
sunroof is offline
PostPosted: Tue Jun 10, 2025 4:26 pm    Post subject: Re: Square back resurrection Reply with quote
Today a couple of friends came by to help put the body on the pan so I decided to bolt the engine up to the transmission to reduce the cars footprint as much as possible
Body on chassis and car stuffed into corner
I will install the steering column and steering wheel and put the car up for sale. I am officially over fighting with it. It is very tempting to bolt the fenders on too.
Now I can swing the beetle around giving me lots of space to do the engine swap.
Don
Bobnotch
Bobnotch is offline
PostPosted: Wed Jun 11, 2025 11:47 am    Post subject: Re: Square back resurrection Reply with quote
Don
It looks good with the body back on. It's a shame you're going to sell it off, especially with all of the time you've got into it. Oh well, you wouldn't be the first to give up on a big project like this one was.
Tram wrote:
Tram wrote:
sunroof
sunroof is offline
PostPosted: Thu Jun 12, 2025 3:10 am    Post subject: Re: Square back resurrection Reply with quote
It is not the size of the project that has me passing it on, I was expecting to put ~3 years into it, I have no problem with that. This one took me 2 years and nine months
https://www.thesamba.com/vw/forum/viewtopic.php?t=726892&highlight=
No it was the fight. I am sick of fighting with it. From discovering that the heater channels I got with the car were the wrong year to finding out the front suspension had been destroyed because the DPO had completely dismantled it and stuck it outside for years every damn thing is a fight. No, I don't want to fight with it anymore.
Don
Page 12 of 13
